NP Pajero
Submitted: Monday, Sep 19, 2005 at 16:36
ThreadID: 26591 Views:5295 Replies:7 FollowUps:7
Looking to cross Simpson in my new standard Paj any comments on suspension /loading or others--Ground clearance needed???
Reply By: Member -Dodger - Monday, Sep 19, 2005 at 17:25
You should do it ok just do not overload. Also make sure that you have enough fuel.
If you can link up with another vehicle or group of vehicles then you will have security and more fun.
Cheers Dodg.
AnswerID: 130847
Reply By: Rob from Cairns Offroad Training & Tours - Monday, Sep 19, 2005 at 19:26
I have trained a few ppl in the new independent suspension Pajeros and ground clearance is a problem. As you may need momentumto climb most of the steeper dunes your suspension will be compressed and ground clearance reduced. I would recommend at least a 2" lift which will also benefit in any offroad conditions.
Cheers Rob
AnswerID: 130868
Follow Up By: David and Jenny - Monday, Sep 19, 2005 at 20:09
Thanks Rob, I have taken that on board --this is the reason I asked , as the stretch for another $1500 ish dollars for OME upgrade is difficult and I was also considering Polyairs to firm the back up when its loaded for the trip at $550 ---Polyairs for now and OME later????David
FollowupID: 385284
Follow Up By: Shaker - Tuesday, Sep 20, 2005 at 11:00
I just did the crossing in a Terrano 2 TDI, standard suspension was not a problem!
Ther is no doubt people get obsessed about lifts etc. much more important is to have 2 spares, tyre repair/changing equipment, radio, enough fuel & water & most important of all .... don't stress & have fun!
FollowupID: 385358
Reply By: MarkTheShark - Monday, Sep 19, 2005 at 19:43
Dear David and Jenny
I have an NP. Haven't done the Simpson but did do the dune everyone mistakenly calls Big Red without a worry, both ways. Have also done the Border track which has dunes with finer white sand. Did them without any problems.
Regards, Mark
AnswerID: 130873
Follow Up By: David and Jenny - Monday, Sep 19, 2005 at 20:04
Standard suspension Mark? Heavy load? Did you srape the infamous intercooler?David
FollowupID: 385283
Follow Up By: MarkTheShark - Monday, Sep 19, 2005 at 20:18
yes (although since changed); moderate; no
FollowupID: 385288
Follow Up By: David and Jenny - Tuesday, Sep 20, 2005 at 05:57
Mark the shark, What suspension did you go to and why?David
FollowupID: 385339
Follow Up By: MarkTheShark - Tuesday, Sep 20, 2005 at 09:05
I changed to Pedders Trakryder to bring the height back to normal when loaded. On a decent trip, in addition to a lot of heavy gear, I am carrying at least 150 litres of fluids and towing a camper trailer so there is a fair load on board. I don't believe in lifting the suspension too much that because that brings handling problems. Of course it sits a little high now when not loaded.
In many years of off-roading (I had a job in Central Australia which took me off-road) clearance has never been an issue. Not letting the tyres down, on the other hand, can be. With traction control in the Pajero, things are just that much easier.
Would I go Pedders again? Possibly. Would I go Trakryder again? Possibly. The ride is just as good as before.
By the way I have fitted a metal bash plate and a gearbox protection plate, both TJM. The gearbox plate is OK in itself but the rear mount to the crossbar is poorly engineered. I reckon even I could design something better.
I have Bridgestone 964s on the vehicle now. I am pleased with them.
FollowupID: 385346
Reply By: David and Jenny - Monday, Sep 19, 2005 at 20:01
Thanks for the replies so far.David
AnswerID: 130886
Reply By: andrewr - Monday, Sep 19, 2005 at 21:35
I went across the Simpson 3 weeks ago in an '05 Pajero with every mod in Christendom bolted to it. We had set off to do the easier rig road but ended up going the whole way on the French Line.
A few days before I left I had the OME heavy duty suspension upgrade. It took a bit to get used to but after 6,000 kms would not go back to std suspension and would recommend it to anyone who does a fair bit of off road or rough road driving. The vehicle was fully loaded and with the suspension rise sat probably just a bit higher than a vehicle with std suspension unloaded. Still, needed all of the clearance to get over some of the dunes and looking back would not like to do the trip in a vehicle with std suspension unless it was virtually empty (going along the easier tracks like the rig road might not be so bad - but I think any crossing will take in a bit of the French Line and QAA line which are one sand dune after another). Made a big difference on the corrugations too.
Realise that this goes beyond your question, but other mods I found useful or wished I had taken, in order of importance:
- Something to fly a sandflag off. A lot of people without solid aerials use old fishing rods taped onto bullbars.
- Cargo barrier. Head ons are a real risk. I met a convey of half-pi**ed muppets coming the other way, no sand flags, yapping on their own channel (i.e. not listening to channel 10). Roll-over risk is high coming down some dunes.
- air compressor.
- tyres - good chance of flats on the gibber to the west.
Decent recovery gear is pretty important, especially if you're on your own and its getting towards the hotter months. I went all out with an electric winch and an ARB PRT. Didn't get used in anger but there were quite a few times that I thought I would have to and knowing it was there made the trip more pleasant. A long-handled shovel and lots of water would probably have been the next best thing.
AnswerID: 130922
Reply By: Blaze - Tuesday, Sep 20, 2005 at 00:47
Couple of things Guys, Is the Paj a 3.2ltr or 3.8ltr The 3.8ltr will suck the juice out there if its been dry. heard last year of one being left for awhile at lone gum until they got some more go juice. Also please use a good flag and run on scan if you are travelling alone. To many cowboys now run on the wrong channel.
AnswerID: 130951
Follow Up By: David and Jenny - Tuesday, Sep 20, 2005 at 05:55
Its a 3.2 deisel.David
FollowupID: 385338
Reply By: Member - MrBitchi (QLD) - Tuesday, Sep 20, 2005 at 10:53
If you're handy with the spanners you can put a new set of springs under it for around $300 (Kings or Lovells). Leave the standard shocks on as they are OK with the heavier springs.
Only takes about half a day.
Cheers.....
AnswerID: 130982
