GQ owners advice.
Submitted: Tuesday, Sep 20, 2005 at 09:30
ThreadID: 26614 Views:2617 Replies:7 FollowUps:2
Ok guys,
what oil are you using for your GQ transfer case? Interested to see the feedback here.
Reply By: Member - Chrispy (NSW) - Tuesday, Sep 20, 2005 at 09:36
Hi Ange!
I use Castrol Syntrans 75w85. It has racing heritage (Mitsu Evo's and Jaguar XJ220), so it has some development behind it. Apart from that, it smells nice.
AnswerID: 130970
Follow Up By: Member - Crazie (VIC) - Tuesday, Sep 20, 2005 at 11:06
Evertime i look, you had added another GQ hahahaha
FollowupID: 385360
Follow Up By: Member - Chrispy (NSW) - Tuesday, Sep 20, 2005 at 11:25
Yeah... I saw that too! Dang things are everywhere!!
FollowupID: 385365
Reply By: joc45 - Tuesday, Sep 20, 2005 at 13:46
My old 88 Maverick aka GQ specified 75/80 multigear oil and I ran that for its whole life, but I note that my GU now uses Dexron III transmision fluid for the transfer case, tho multigear can still be used. (maybe a change in design?). Anyway, I'd stick with the former.
cheers, Gerry
AnswerID: 131009
Reply By: Vinnie - Tuesday, Sep 20, 2005 at 20:55
I'm using Dexron II in my '92 Mav -- (4.2 Diesel)
I was told by a Nissan mechanic of many years, any series 2 GQ or Maverick - built after July '92 would be better to use the Dexron II in the transfer
I have been using it for some years - about 100,000 plus and change it every 20,000. It still comes out a redy colour and no whines or grinds from the transfer
Vinnie
AnswerID: 131071
Reply By: ACDC - Tuesday, Sep 20, 2005 at 22:36
If you go to www.bp.com.au they have a great lube chart! with all the info.
AnswerID: 131092
Reply By: Member -Hank (NSW) - Tuesday, Sep 20, 2005 at 22:38
Penrite Manual Gear Oil 80 with ProMa MBL additive.
AnswerID: 131093
Reply By: Swine Hunter - Wednesday, Sep 21, 2005 at 00:30
Haines Manual states all 4.2 both Petrol & Diesel manufactured AFTER Oct 1991 should use Dexron II/III.
Wayne
AnswerID: 131119
Reply By: warthog - Wednesday, Sep 21, 2005 at 22:54
My mechanic told me that although 75w90 gearoil is sometimes specified as being applicable to my GU transfer case,atf is the better proposition. His reasoning being that gear oil is too thick to adequately lubricate the links in the chain drive to the front output shaft. If your GQ has a chain drive then it would stand to reason that atf would be better in it also.
AnswerID: 131292
