GU Patrol cabling through the firewall?
Submitted: Wednesday, Sep 21, 2005 at 00:25
desertgold
I have a 2004 GU and have installed a CDMA long range antenna and a GPS antenna (on top of the
snorkel). I can't work out where to run the cables into the cabin without compromising the waterproofness. Can you help?
Reply By: Member - Hugh (WA) - Wednesday, Sep 21, 2005 at 00:43
Hi Desertgold,
There is a blind grommet located on LHS firewall (just above cabin floor level). This provides access into cabin. However when removed anything inserted runs into insulation which is hard backed on inside (just below aircon and fan assy). If you stick through something sharp you'll see where it comes through.
If you cut the end off the blind grommet you'll find it gives a good seal against antenna cabling.
Regards,
Hugh
131120
Follow Up By: hl - Wednesday, Sep 21, 2005 at 08:09
The grommet on the passenger side where the wiring loom runs through has plenty of space to put extra cables through.
I run 2x Coax and 4x 8 gauge through that.
385496
