Patrol and cd stacker
Submitted: Friday, Sep 23, 2005 at 13:39
ThreadID: 26702 Views:2389 Replies:5 FollowUps:7
Hi All
Can my std 2002 patrol radio take a stacker for cd's and what is a type that is compatible with this unit
Tim
Reply By: Peter McGuckian (Member) - Friday, Sep 23, 2005 at 13:44
Tim,
Wouldn't an IPOD be the way to go now?
AnswerID: 131511
Follow Up By: Tim (vic) - Friday, Sep 23, 2005 at 13:57
What are the ways you can connect an ipod to the cd player?
Is there a jack in the back of the radio?
FollowupID: 385839
Follow Up By: Peter McGuckian (Member) - Friday, Sep 23, 2005 at 14:06
You attach an FM transmitter to the IPOD and pick the signal up on the radio. There are seevral brands to choose from. Griffin make a neat one that sits on top of the IPOD. This means you don't need to change the player or burn MP3s onto CDs.
FollowupID: 385843
Follow Up By: Penguin (NSW) - Friday, Sep 23, 2005 at 14:24
My son has one, it's called a Griffin RoadTrip. IPod sits in it in a cradle arrangement and it plugs into the cig lighter and transmits to the radio.
Works really well.
FollowupID: 385844
Follow Up By: Member - Roachie (SA) - Friday, Sep 23, 2005 at 16:36
I've just spent about an hour looking over the offerings on ebay for all these ipods/mp3 players etc..........bloody hel, what a minefield of gear!
I am convinced this is the way to go when my ST's CD player starts palying up more than it currently does...(it has the occasional wobbly, when a disk doesn't want to eject, or when it jumps for no apparent reason).
However, I'm confused as to what is the best way to go. Some of the players use AAA batteries and some seem to have their own 240v and USB charging capabilities (which I prefer, as AAAs don't last long). I don't reckon I'd need more than about a 512mb memory, but did see a nice player on there that has no memory, but instead uses SD cards. I would have preferred that one, but it uses AAA's GGGGRRRRRRR hahaha
What have others done in this regard?
My ideal unit would be:
512mb memory (and possibly takes a SD card too)
Inbuilt lithium battery rechargable from a 12v, 240v or USB input
Capacity to connect the FM transmitter so I can play music through car FM radio
The other thing I don't profess to understand is how do you set about getting the music from existing CDs onto the MP3 player/ipod etc? Do I have to transfer the music on the lappy to the hard drive and then attach the player to the USB port? If so, how long is this likely to take to download a CD? I can see this whole job taking several days to load say 260 songs onto a player!!!! Is there a simpler/quicker way?
Roachie
FollowupID: 385855
Follow Up By: Member - MrBitchi (QLD) - Friday, Sep 23, 2005 at 16:59
Roachie, the iPods come with their own software called "iTunes".
It's a snap to configure and is pretty quick to download files. Uses "wma" format which means each song is quite small.
My daughter has a 512MB iPod shuffle (got it as a freebie with a mobile phone, sounds AWESOME!) which holds about 120 songs. You need at least the iPod mini to connect to the FM transmitters others are talking about.
iPods use a proprietary battery which charges from the USB port on your laptop (or the cradle of the Griffin RoadTrip). Battery life is about 3yrs (where have we heard that before?) Mate's went kaput and it was cheaper to buy a new iPod rather than get the old one repaired, so a unit that uses rechargeable AAA's may be a better way to go....
Cheers....
FollowupID: 385860
Follow Up By: Exploder - Friday, Sep 23, 2005 at 18:40
You can also get a 2-year warranty on the Ipod so if the battery calls it a day you get a new one, Or just run it off the Griffin RoadTrip.
FollowupID: 385877
Follow Up By: age - Saturday, Sep 24, 2005 at 15:14
Have a look on eBay/Google for a FM transmitter called an IRock - I scored mine for about $70. Plugs into cigarette lighter (no batteries) and you can plug in any USB compatible storage device (flash memory, portable hard drive etc - IRock also powers these devices) It also accepts any existing MP3 player etc. Has a USB charge outlet to charge phone etc as well. I raided a trashed laptop from work, pulled out hard drive (20gig) placed in external USB housing. Is a ripper and very cheap all up. Even a better model out now than the one I got. Sure IPod etc probably bit better quality, but way more expensive. Just had this one up beach and all worked fine
Age
FollowupID: 385989
Reply By: Member - Robyn J (QLD) - Friday, Sep 23, 2005 at 13:52
Our 2000 GU DX Patrol didn't have a CD player. So we replaced it with a good CD MP3 player with 4 new speakers. Best thing we ever did. We burnt all the Cds plus other music onto about 20MP's, Travelled one trip approx 17,000ks and didnt play all the music we had. Were on some really corrigated roads, no skipping on the MP's. Depending on the cost of the stacker this is the way to go and if you wreck one you just burn aother one and not lose your expensie CD.
AnswerID: 131514
Reply By: Exploder - Friday, Sep 23, 2005 at 15:48
Give Nissan a call and they will tell you if it can take one and what unit’s are compatible with the factory deck, does the factory deck have a Cd button if no then it will not take a CD stacker.
AnswerID: 131525
Reply By: Member - Brian (WA) - Friday, Sep 23, 2005 at 18:57
Hi Tim. I have a IPOD and think they are great. I have two days of non stop music on it, and thats only about 20% of what it can take. Get the FM transmitter tune
your your car radio to it and away you go. Also if in a group and others if close
enough they can also tune into it. And you dont have to carry lots of CD's with you
and it dosent jump on rough roads. cheers brian
AnswerID: 131554
Reply By: GOB & denny vic member - Friday, Sep 23, 2005 at 19:33
as i run the laptop in the truck for mapping /gps purposes i keep mine on the lappy and bought a tape adapter works sort of ok but bthe fm transmitter sounds the go have to see if it will connect to the lappy
steve
AnswerID: 131562
