Site Search
Section Image
Fridge slide
Submitted: Saturday, Oct 01, 2005 at 18:08
Member - John D (WA)
Has anyone got any hints about mounting on engel fridge slide into a gxl 80 series.
Problem being 'clearance over tailgate' and 'longrange tank under floor'.
Advertisement
ThreadID: 26910 Replies: 3
Views: 720 FollowUps: 2
AnswerID: 132625   Submitted: Saturday, Oct 01, 2005 at 18:12
Member - DOZER replied:
Pick up the tie down threads and mount a false floor in the back....bolt the fridge slide to this.
Click Image to Enlarge
b4 you bag me out, walk a mile in my shoes, then your a mile away and have my shoes :)
Reply 1 of 3
FollowupID: 386994   Submitted: Sunday, Oct 02, 2005 at 10:13
Stuck in Hedland posted:
Thanks all. Job done.
AnswerID: 132629   Submitted: Saturday, Oct 01, 2005 at 18:37
Member - Jack replied:
I had the same problem with my 80 Series GXL, and Dozer got it in one. I remved the carpet and cut a false floor in plywood, built up a frame to mount the slide on and bolted it in.
I am now trying to work out how I can have a "bolt in" fitting for the slide that will allow me to remove and replace it in the car whenever I want.
Jack
All power corrupts, but we need the electricity.
Reply 2 of 3
FollowupID: 387004   Submitted: Sunday, Oct 02, 2005 at 12:54
Member - DOZER posted:
Gday Jack
Its a little hard to explain, but imagination is the key..
Im a metal worker, so i weled up two bed plates to unistrut lengths and mounted them to the tie down holes each side, giving me a unistrut running front to back either side of the rear.
I then welded two pieces of flat steel (30mmx10mmx 1.5mm) accross the front of each unistrut opening (which are facing up) to help lock in the false floor.
Under the false floor timber, i screwed 13mm square RHS that locate in the unistrut when floor is ontop.(and sit under that welded steel when in the forward position) This allows whole floor with draws and fridge to be pulled out of the back of the car however far as practical to yourself (some shorties have problems reaching over the tailgate) and it can also be locked in when in transit. To the rear of the false floor i have used two unistrut bolt down fixtures to secure the floor when it is time to
move.
Now, the beauty of this setup is...floor can be removed leaving unistrut, which doesnt interfere with 3rd riow seats.
whole lot can be slid back to allow access when camping
opens the possibility up of hinging the fridge slide so when you pull it back, the fridge tilts back to allow easier access.. :-))))) all it would take is a hinge at the operator and a locking system at the front end when slid forward.
AnswerID: 132644   Submitted: Saturday, Oct 01, 2005 at 21:03
Russ replied:
I have done as the others have suggested in my 100 series.
Left the carpet in, cut out a "plate" from about 8mm ply, used the 4 corner tie down points to secure this.
Have bolted my slide to the plate, also fitted other tie down points for my boxes and Thumper battery.
No need to remove carpet, plate can be removed with a little effort if not required. You have to tilt it to get it out. I cut it to go around the wheel arches, took a little bit of messing around, used 3 mm MDF to make a pattern.
Good luck
Russ
Reply 3 of 3
