OziExplorer CE track files
Submitted: Monday, Oct 03, 2005 at 09:48
ThreadID: 26945 Views:4940 Replies:5 FollowUps:3
Hi all,
Whenever I try to either "Save track log to file" or "Save track log (mem)" I get an error message that says "Cannot create track file" after I have selected the location and filename.
I am trying to save a track that I made using moving map. I followed the instructions to the letter. I have also tried searching for the cetrack.plt file and cannot find it. This is meant to be the track log file.
I have never had any success saving tracks with Ozi CE so I have just used my Etrex for tracking. However I currently have a track displayed on Ozi CE that I want to save so I figuring out how to do it has suddenly become necessary.
Any ideas?
I did a search but came up with nothing relevant.
Reply By: geocacher (djcache) - Monday, Oct 03, 2005 at 10:21
Can't help sorry, just tried on mine and saved to file no problem.
It's not a simple syntax error (wrong character or similar) in the file location box is it?
AnswerID: 132794
Follow Up By: Utemad - Monday, Oct 03, 2005 at 10:40
No. Even when I use the offered filename or "hhh" it will still reject the save.
Thanks.
FollowupID: 387097
Reply By: Wizard1 - Monday, Oct 03, 2005 at 10:24
Have you tried contacting OZIEXPLORE or check the FAQ on their website?
I had trouble as my computer only has USB ports and my GPS uses a Com Port cable. I used an adaptor but when I checked the website FAQ all my problems were solved and it works fine.
AnswerID: 132796
Follow Up By: Utemad - Monday, Oct 03, 2005 at 10:42
I have checked all the FAQ and help files and had no luck. I'll try emailing them if I get no joy from here. Might do a reinstall first though. As that will probably be their first guess.
FollowupID: 387098
Reply By: Bonz (Vic) - Monday, Oct 03, 2005 at 10:34
Try a re-install of CE or better remove it completely fron the PDA and do a clean install.
AnswerID: 132797
Follow Up By: Utemad - Monday, Oct 03, 2005 at 10:47
I have downloaded the latest CE to do just that but I imagine I'll lose my track in the process. However I can't think what else I can do.
Will just have to go back and track it again :-)
FollowupID: 387099
Reply By: The Explorer - Monday, Oct 03, 2005 at 13:35
Hello - I have recreated your problem and a couple of possible issues may exist
1. If I try to save to a non existent directory cant save file. Go to File - Configuration - Map & Data Files. Make sure the Data File Path (down the bottom of page) actually exists by brousing to it. This becomes default directory for saving data...you can actually choose another directory when saving data....though I suspect you have already tried this so maybe Im on wrong track:)
2. If the track log does not exist in the first place you will not be able to save it so make sure File - Track Log - Log Track to File has a tick next to it - if it does not have a tick next to it it is turned off. To activate click on it. This does not apply to Track Log (mem)...even a blank track log (mem) can be saved (well by me anyway) and it is recorded whenever you start moving map (assuming track log distance not set to zero). What is your track log distance set to (File - Configuration - Tracks)? If this is set to zero no logging will occur...and no file will be created.
3. Not sure why you can not save existing track showing on screen ie Save Track Log (Mem)..maybe issue 1. above
Hope my suggestions help
AnswerID: 132812
Reply By: Utemad - Monday, Oct 03, 2005 at 16:13
Thanks all. Reinstall fixed it but I have lost the track I was wanting to keep. Oh well. Thanks for the advice.
AnswerID: 132829
