Fuel Tank repairs.
Submitted: Monday, Oct 03, 2005 at 22:56
ThreadID: 26967 Views:2712 Replies:6 FollowUps:0
Hi all, had the misfortune today to watch a mate lose nearly 150lts of diesel.
he had run over a largish rock that dented his fuel tank, right on the seam.
the result was a multitude of pinprick holes, with no way to stop the leaks.Is there any products on the market that can make temporary repairs to fuel tanks, both aluminium and steel?
rick.
Reply By: Truckster (Vic) - Monday, Oct 03, 2005 at 23:04
You can get 2 part putties..
or you could have used Cake Soap....
AnswerID: 132914
Reply By: Voxson (Adelaide) - Monday, Oct 03, 2005 at 23:09
Like Truckster said 2 part puttys are good....Especially LOCTITE petrol tank repair putty.... Got me outta the crap at the Cape once...
AnswerID: 132916
Reply By: techie - Monday, Oct 03, 2005 at 23:21
I have been told chewing gum works, I think only on petrol though.
Untested and probably an old wives tale - never had to try it myself though.
Techie
AnswerID: 132919
Reply By: Big Kidz (Andrew & Jen) - Tuesday, Oct 04, 2005 at 06:42
I have heard the cake of soap thing - you mash soap into the holes by rubbing a cake of soap over the holes. Apparently it works a treat and lasts quite some time.
AnswerID: 132931
Reply By: Member - John C (QLD) - Tuesday, Oct 04, 2005 at 07:41
Always found minties the best. You know the white sweets.
Need to be slightly warm such as off the dash or a couple of chews, and push them in and around the hole. Seem to stick pretty well to the tank and dry hard.
Came across the idea on our cape trip in 1992 with 7 small cracks in the fuel tank on the folds. Seemed to be stress fractures and only happened on corrugations with more than 3/4 of a tank. Had a packet in the car and the kids used to let them fall out of the packet. Noticed that soft ones were hard to remove off the floor.
Repairs lasted us until we got home, and another 20,000k around brisy until I could afford a replacement tank.
AnswerID: 132934
Reply By: porl - Tuesday, Oct 04, 2005 at 11:23
minties as fuel crack repairers and cheezels as replacement fire starters, amazing, no wonder people keep coming back to this forum ....
AnswerID: 132969
