prado 120 sovereign bar winch options
Submitted: Tuesday, Oct 18, 2005 at 20:02
mas
I have a Prado 120 with a Soverign bar (my mistake). To fit a winch I need the toyota winch cradle ( $200 thanks). Toyota tell me that the cradle is designed to suit the superwinch they sell. Does anybody know if the cradle will suit other types of winch? I am looking at the Magnum winch in particular.
Reply By: Outnabout David (SA) - Tuesday, Oct 18, 2005 at 22:10
mas,
The warn
winches and magnums fit Ok. I used to work at a Toyota dealership and we had them fitted to the Sovereighn bar. If you measure up the distance between your chassis rails I may still have a cradle to suit at a much less price than $200.
djs at senet dot com dot au
135137
Reply By: Member - Leith H (NSW) - Wednesday, Oct 19, 2005 at 06:12
Mas
As advised above, I have the 120 with the soverign bar and also have a warn winch fitted. The only problem I had was when I went to fit the fairleads I discovered that only superwinch fairleads will fit in the slot. Good Luck.
135173
Follow Up By: mas - Thursday, Oct 20, 2005 at 10:26
I tried the magnum fairlead in the bar and it seems to fit, withouot knowing exactly the mounting arrangement to the cradle
389329
Reply By: toyota - Wednesday, Oct 19, 2005 at 12:26
if your in vic send me an email im sure i can help you out with a better price
stevet@lanetoyota.com.au
135213
Follow Up By: Member - Stan (VIC) - Wednesday, Oct 19, 2005 at 17:02
Better than trade prices?
389224
Reply By: toyota - Thursday, Oct 20, 2005 at 08:24
$155 including tax i have them on the shelf
135370
