Suzuki Vitara '94 JX SWB: will it make it?
Submitted: Friday, Oct 21, 2005 at 23:31
Jimaholic
Hi, I own a suzuki vitara '94 JX short wheel base with 235 000K's and was wondering if anyone had any experience taking a vehicle similar to this on any serious 4WDing trips/expeditions. I've done plenty of fairly rough 4 wheeling in
mine before but don't know how it would cope on a long hourney, probably pulling a trailor. I intend to get a
suspension lift, bigger
wheels and harder
suspension to cope with increased load.
I've currently got a dual battery setup with a 96Amp hour battery, a
UHF radio, high lift jack and a cargo barrier.
I hope to eventually make the trip up to
the tip of
Cape York or the centre after a few minor trips to get things sorted.
SO.. does ayone rekon it will make it and is it worth putting the money into it to it?
Thanks in advance,
Jim.
Reply By: Peter 2 - Saturday, Oct 22, 2005 at 10:45
Jim
I'd be going the light route, don't take anything you don't absolutely need, get good quality lightweight gear like bushwalkers use so to keep weight and bulk to a minimum. I think the trailer would be too much off road for extended trips and would put serious dent in performance, off road ability and economy.
A very small low profile roofrack to take chairs or even a folded tent would eb a better idea.
how many in the vehicle? 1 or 2?
Had a friend who used to travel solo on long outback trips with no problems, removed all the seats except for the drivers, made a false floor system that enabled him to carry extra fuel and
water in jerries and he could sleep in the car in bad weather, as the mattress fitted between the dash and the back door dow the passengers side.
That was in an early 4 stroke Suzuki a whole 1 litre engine capacity and only 4 speed box.
135720
Reply By: Willem - Saturday, Oct 22, 2005 at 10:53
Jim
Suzukis go anywhere. I can attest to that. Go to my website below and click on 4x4 and then at bottom of the page The Spinifex Trail. My Suzuki on that trip had done about 100,000km and was in good working order.
One thing to watch out for is not to over engineer a small vehicle. I had
the springs reset as we were carrying a heavy fuel and
water load for
the desert trek and I broke 7 leaves on the rear ..
Suzki's with high kilometres should have their gearboxes and transfer cases checked as they are only lightly engineered and at high k's they might fail. Also check the universals and repack the front wheel hubs and bearings. The diff's should be OK.
As long as your trailer is lightweight you should not have any problems.
135722
Reply By: Member - Des - Sunday, Oct 23, 2005 at 10:36
Jim,
Had a Vitara Estate (4 door) for 5 years. It was great: reliable simple economical & tough. I would even say fun. The narrow track and relatively short length (even shorter in 2-door) made it very nimble in narrow tracks. And the light weight is a plus in sand.
But we found in the end that clearance and ramp-over angle and carrying capacity were not enough for our needs. Little engine also struggled with a full load. We concluded that it was more viable to upgrade to bigger vehicle than spend $$$ on the Zook.
But that is just my experience. I certainly wouldn't discourage what you are planning if the sums . More clearance/articulation through bigger tyres and a
suspension upgrade would make a world of difference. Would be inclined to add a
snorkel ($400) and diff locks too. Air lockers would be ideal, but the cheaper Detroits etc would do the job. Open rear diff is a significant limitation.
I agree with the others that if you can travel light and avoid towing you will be much better off.
From memory the 2-door only has a small fuel
tank. You would want to add a long-range
tank for long-distance travel.
One of the 4WD mags (Austn 4WD monthly I think) took a Jimny across the Simpson and it went fine. Mind you they had a couple of Patrols in support, no doubt carrying most of the gear!
Good luck,
Des
135811
Follow Up By: Jimaholic - Sunday, Oct 23, 2005 at 10:59
I was thinking abotu getting a long range
tank, it will increase my fuel capacity form 42 to 75ish L which would be a great help.
I don't know about diff lokcers, although there a great bit of kit you think there nessesary?
I also was going to make a home-made
snorkel out of PVC pipe but I'll see hopw that goes. I'm still keen on taking a light trailor, I really don't like the roof option.
The little 1.6 4 cylinder is a limitation. I've got extractors which is apparently the only engine upgrade worth doing to these fine vehicles. I've looked at other upgrades but there all pretty expensive for not much gain.
I'm not sure what year you vehicle is but my Zuk has normal(I assume that's closed) diffs.
Thanks,
Jim.
389692
Follow Up By: Member - Des - Monday, Oct 24, 2005 at 10:50
Ours was 93 model. I think all the Vitaras had open diffs. Not sure whether even Grand Vit has rear LSD. We have had
wheels in the air and no go! With
suspension upgrade and decent tyres, and careful wheel placement, you might get by OK without diff locks, but they would help in tough conditions. There is a lot about them on the
forum. 4WD Monthly did a helpful feature on them last year I think.
Snorkel helped engine performance I found. 75L
tank will also be a good move.
Wise to minimise the expense if possible, because you won't get it back when you eventually sell the car.
Des
389805
Reply By: Jimaholic - Sunday, Oct 23, 2005 at 10:39
Thanks heaps fellas.
I'm taking the backs seats out so it will only carry 2.
I'm a little worried about roofracks though because of the chance of rolling but if theres not much weight it might be ok. Once went for a trip down to the coast in my mates sierra and we had to pack in a roof cage. there was so much strain on the sway bar that when we turned or the car rolled a bit the car would rock back and
forth for a while.
thanks again and nice website willem,
Jim.
135812
