turbos
Submitted: Monday, Oct 24, 2005 at 11:55
ThreadID: 27504 Views:2662 Replies:4 FollowUps:6
hi all just found out my turbo is stuffed.I know nothing about turbos so the question is if i put a bigger turbo in do i get more power and torque with out to much effect on economy. i have 2.8 turbo diesel rodeo
Regards bigfella
Reply By: Wizard1 - Monday, Oct 24, 2005 at 15:50
www.dencodiesel.com.au
www.safari4x4.com.au
AnswerID: 136029
Reply By: Member - Roachie (SA) - Monday, Oct 24, 2005 at 16:19
G'day mate,
I'm just about to upgrade to a larger turbo (next wednesday, 2/11) and will be looking to off-load the existing one. I have a 4.2L GU Patrol. There's nothing wrong with my turbo, but the concensus is that it's not quite big enough for the 4.2; having been originally used by Nissan on the 3.3L MQ Patrol back in the 80's.
So, if you think it would suit your needs (and providing everything goes according to plan of course), I'll be willing to part with my old one for a couple of hundred bucks if you're interested.
Roachie
AnswerID: 136036
Follow Up By: Nudenut - Monday, Oct 24, 2005 at 16:56
what boost are you pumping now....and what do you expect to get when you fit the new?...there is a limt you know...the power plant can only take so much.
FollowupID: 389858
Follow Up By: Member - Roachie (SA) - Monday, Oct 24, 2005 at 17:20
G'day Nudie,
Thanks for the "O" rings, they turned up today and the bigger of the 2 sizes looks just about spot on....cheers
The turbo (standard) packs about 8psi. I had the mob at Berrima that we aren't allowed to mention on here, tune the truck about 150,000klm ago and the did a minor modification to it which raised the boost to it's current level of 12 psi. All the did was to cut into the rubber hose at the waste gate, insert a "T" piece and run a similar diameter rubber hose up to the air box, to equalise the pressure.....instant 4psi increase.
The bigger turbo is aimed not so much at extra boost (although the bloke at Berry reckons it'll go up to about 14psi), but rather it is hoped the larger exhaust port will aid the "breathing" of the bigger donk than this existing turbo was designed for. He reckons it'll reduce the EGTs (not that they are high at the moment) and will make the fuel economy better. We shall have to wait and see!!
Cheers mate
Roachie
FollowupID: 389863
Follow Up By: Nudenut - Monday, Oct 24, 2005 at 18:02
bloomin hell...12 psi
ahhh what the heck...whats a couple more psi....ramp it up to 14...go on!
FollowupID: 389875
Follow Up By: Nudenut - Monday, Oct 24, 2005 at 18:07
the larger section is 62mm x 4mm
the smaller is 2.5ins. x 1/8 (actually almost 3.5mm....how that happens has got me beat)
any how, note this down......they are available from ludowici at regency park....and others but dont ask me where or who...i only went to ludowici....sorry but you'll have look up the phone no yourself....the kids have left my office phone books inside the house
FollowupID: 389877
Reply By: prado_95 - Tuesday, Nov 08, 2005 at 00:42
IF you have not yet spent your $$, upgrade the exhaust system AND THE DUMP HOUSING first!
That thing is so small you cant push a matchbox thru it!
ENG-TEK
AnswerID: 138378
Reply By: Ford Rodeo - Monday, Nov 14, 2005 at 20:28
Bigfella, Just wondering how u went with your chassis problem a few years ago. I checked the thred from 2002 and it seems to have stopped all of a sudden. Had the same happen to me and I'd love to find out how u went? Thanx
AnswerID: 139386
Follow Up By: big fella - Tuesday, Nov 15, 2005 at 08:40
hi Ford Rodeo my chassis problem was fixed under warranty by holden only after i got in touch with the department of fair trading
Regards bigfella
FollowupID: 393145
Follow Up By: Ford Rodeo - Tuesday, Nov 15, 2005 at 17:34
Big fella, no warranty on mine but I dont think its a warranty problem. More a case of manufactures fault. Dunno if they see it that way!!! Thanx for the info, much appreciated.
FollowupID: 393232
