lashed out and bought a O2 XDalls PDA
Submitted: Monday, Oct 24, 2005 at 18:12
Nudenut
has any one hooked these up to a gps......Can it be done?
if so what do i require or is it easier and better to get a laptop/tablet ( like i was intending and going to do) and hook it up to a garmin quest or similar
Reply By: Lone Wolf - Monday, Oct 24, 2005 at 18:48
iPod not good enough for you?
lol.....
136074
Follow Up By: Nudenut - Monday, Oct 24, 2005 at 18:56
cheeky bugga lol lol
this has excel...is a phone and has and a lot of other sheit i dont need out in the field.....same goes for music...i work for a living not sing songs so i dont need music
so whats an ipod again!
389894
Reply By: Member - Poe L (NSW) - Monday, Oct 24, 2005 at 19:00
I haven't done it with the IIs, but I've hooked my XDA II Mini to a Bluetooth GPS (GlobalSat BT-338), running both Destinator and Oziexplorer (not at the same time). It has worked very
well, probably as much due to the GPS (which uses the new SiRF-III chipset) as anything else.
You can also get a Garmin or Magellan, but that's older technology, and doesn't lock as
well, not use bounce signal. You many never need it, but was comparing this GPS to a newish Garmin and the new eXplorist 600 indoors; whereas the BT-338 locked onto 4 sats (which Oziexplorer could use), the Garmin and Magellan couldn't lock on to anything.
136076
Reply By: Grungle - Monday, Oct 24, 2005 at 20:41
Hey Nudenut,
I am actually the O2 account manager at the service centre that repairs the O2 in Australia. If you are interested in pinouts for GPS, setting up bluetooth GPS etc, I may be of help. I have had extensive training and exposure to the O2 product and use them myself so am happy to help if required.
David
136098
Follow Up By: Nudenut - Tuesday, Oct 25, 2005 at 07:40
Thanks David....Though I hope I dont have to take you up on that
389976
Reply By: Willem - Monday, Oct 24, 2005 at 22:27
Do you really need it to get to the gun club? lol
136136
Follow Up By: Nudenut - Tuesday, Oct 25, 2005 at 07:41
No!....go there often enough I can do it in my sleep i reckon
389977
Reply By: Coolman - Monday, Oct 24, 2005 at 22:30
Nudenut,
I have the XDAIIs and yes it is easy to connect to a GPS. I have a LeadTek Bluetooth GPS which is stored out of site and no wires connected.
Advantages of the PDA is that it is smaller and easier to use but in theory less 'tough' than a laptop (
Mine has been to the Cape and Back - no problem).
The disadvantage of the Bluetooth is that it can be problematic. My previous XDAII connected everytime without fail and never lost connection. Since upgrading to the XDAIIs the connection is less stable and the GPS needs to be a lot closer to the phone to work better. I actually think there is something wrong with the phone but have not been able to narrow down the problem enough.
You will also need to get a powered mount or car kit for it.
Good luck. Let me know if you have any problems.
(Also great to see David's post!!)
Duane
136137
Follow Up By: Nudenut - Tuesday, Oct 25, 2005 at 07:59
what about moving map ...can it be done?
389978
Follow Up By: Member - Beatit (QLD) - Tuesday, Oct 25, 2005 at 09:44
How good's your eyesight Nudie? I can hear it now, sorry officer I needed to have my face on the dash to see where I was going.
Kind regards
389999
Reply By: Coolman - Tuesday, Oct 25, 2005 at 21:40
Nudenut. It runs WindowsCE so no problem. OziExplorerCE is the one I run using the NatMap and SunMap maps for most of SE Queensland.
Duane
136345
Follow Up By: Nudenut - Tuesday, Oct 25, 2005 at 22:02
so i need ozziexplorer CE eh?
where do i get this hehehe...hint hint hint?
390157
Reply By: Coolman - Tuesday, Oct 25, 2005 at 23:55
Nudenut
You buy it!!!!
http://www.oziexplorer.com/
It does not cost much, about $30 from memory. There is also a demo version which is fully functional for 20mins at a time to try out and confirm all connections are working.
Worth the money..
Duane
136387
Follow Up By: Nudenut - Wednesday, Oct 26, 2005 at 07:43
cough cough choke choke.......BUY IT?!
390183
Reply By: Member - t0me (WA) - Wednesday, Oct 26, 2005 at 17:35
You need the PC version of Ozi too as I don't think you can calibrate the maps without it.
I've got an XDA IIi had the XDA II and gave it to the missus because I wanted the WIFI, the keyboard isn't any use to me. We both live off them and love them.
I use
mine with a BT GPS and it works very
well. Moving map works great, and I have no problem seeing the route and following it on the small screen. I use one of those stalk like mounts with a suction cup on one end and a magnet on the other end. I have bent it so it comes down from the suction cup and rests on the dash and then comes back up to support the phone about an inch and a half off the dash (gives it some shock absorbing). I was getting all sorts of cutouts when using it for GPS and playing music (through a tape adapter on the car sterio) till I changed to a good quality memory card.
If I do it again I won't bother with a BT GPS, its always hooked up to the power anyway so I should really have saved my money, though if I ever want to do anything with the GPS away from the car I'll be happy I've got it. Also I can use the BT GPS with my lappy when I want to (without needing another cable).
You can use it with Ozi and Destinator at the same time if you use GPSGATE.
Personally, I don't take my laptop away with me because its too expensive and the car is just not a safe environment for it. I sort out my maps in advance and stick them on the XDA along with the music I want to hear and take that with me.
There's some great software available for it too, there's a list of some of the best ones (as recommended by the people who are using it) at these links:
HERE (games) and HERE (applications) .
136495
Follow Up By: Nudenut - Wednesday, Oct 26, 2005 at 19:42
thanks for info tOme
be prepared for more questions
390271
