air compressor fittings
Submitted: Thursday, Oct 27, 2005 at 09:44
glenno(qld)
Can you use air compressor fittings to run diesel thru them . Say i wanted to quickly disconnect a diesel fuel line by joining the line in the middle with air fittings . Specifically the two rubber fuel lines that go from and too the fuel filter . Would this be safe ?
Reply By: Michael ( Moss Vale NSW) - Thursday, Oct 27, 2005 at 10:13
It would depend on the material the seals or "o" rings are made of. I personally wouldnt do it. Its probably unlikely but it could become uncoupled by a stick or if a rock hit it.. doesnt really feel good to me.. maybe you can find a ststem with a positive locking ring or something that cannot be bumped apart. regards , Michael
136586
Reply By: myfourby - Thursday, Oct 27, 2005 at 10:53
Hi Glenno,
I have used air fittings to run diesel before with good results. - I too was worried that because the diesel would not be under so much pressure - it would leak - however it sealed perfectly. I used it to temporarily install an additional
tank on the tray back when required.
As far as it being safe/legal??... - Can't make guarantees here! Infact I think it would be neither!
-Myfourby
136595
Reply By: scoof - Thursday, Oct 27, 2005 at 11:37
I used Hydralic quick disconnect fittings with normal fuel hose and worm drive clamps.Have had no probs.
Cheers Scoof
136601
Reply By: Member - Bradley- Friday, Oct 28, 2005 at 01:30
some of the higher spec nitto fittings would work, the ones with viton seals.
But i would recommend getting some proper 'dry break' connectors as they are specifically designed for fuel, get some in a dual action if you can - ie - 2 seperate and different actions required to disconnect, this will reduce the chance of them acidentally coming undone on you.
stay clear of the 'aussie' fittings which have chinese adapters, they leak like a sieve.
136719
Reply By: G.T. - Monday, Oct 31, 2005 at 13:42
Have a look at tractor hydralic conectors, they may have what you are looking for.
Regards G.T.
137145
