Deep Cycle Ignorance
Submitted: Thursday, Oct 27, 2005 at 12:57
CPOCK
Please forgive my ignorance, and yes I have done a search on this
forum but couldn’t find a definite answer. Probably selective blindness.
Having taken delivery of my new C/T with power, I was wondering if I have to keep the DCB fully charged when not in use, if so can any one suggest the cheapest way
(Type of battery charger) to achieve this. I have had an Anderson plug fitted for charging between stops but having only been out for a weekend am not sure how quick this will be charging it ether.
As I said I’m only new at this battery thing so please excuse my ignorance and please explain in cooks terms (read small words)
Cheers & Beers
Brad.
Reply By: Member - Banjo The First (SA) - Thursday, Oct 27, 2005 at 13:17
Yep - the wisdom I've collected says keep the battery fully charged at all times - my CT has an inbuilt charger - I just connect the mains and switch it on, once a month when the CT is not in use. The voltmeter in the CT indicates about 14v+ when full, on charge, then settles back to 13.6 or so at rest. Re the charger type - I'll leave that to the forumnal experts that will pop up soon - the "smarter" the charger though, the better it seems..... knows when to go back to a trickle, after having given the battery a good blast.
136627
Reply By: Member - Ross P (NSW) - Thursday, Oct 27, 2005 at 13:49
I agree that you should fully charge the battery before storing and if possible leave it connected to a "smart" multistage charger. I use a CTEK 7A unit which cost about $300.00 and which are distributed is OZ by Bainbridge Technlogies QLD.
There has been lots and lots of discussion about the pro and cons of different types of batteries, but my personal experience is that I have not been able to fully charge my deep cycle wet cell battery (AGM are different) using the tow vehicle's standard alternator/voltage regulator no matter how long I'm on the road.
When using the mains CTEK 7A charger it gets to about 80% overnight but can take another 48 hours or so before it switches to maintenance mode and is fully charged.
Check out this web site:
http://www.uuhome.de/william.darden/index.htm
or this one:
http://www.windsun.com/Batteries/Battery_FAQ.htm
Regards,
136632
Reply By: phil - Thursday, Oct 27, 2005 at 13:58
Brad,
If you don't mind keeping an eye on things, the cheapest way is just a basic 4 amp battery charger and a cheap digital multimeter. The battery should only need charging every month if there are no parasitic loads from things like radios etc. If the no load terminal voltage drops below 12.6 volts it indicates that the battery is at about 80% charge and that it is time to top up again. Charge at a moderate current (a 4A charger does this anyway) until the terminal voltage is about 14.4 volts.
Another thing to remember is that deep cycle batteries take a very long time to charge at the regulated voltage from a normal vehicle alternator which these days is about 14.2 volt. With the voltage drop which is inevitable from the alternator to your C/T battery it is unlikely that any significant discharge of the C/T battery will be replaced during a normal day's driving. Using your handy digital multimeter will help monitor this.
Phil I
136637
Follow Up By: V8troopie - Thursday, Oct 27, 2005 at 14:28
Another method would be fitting a solar trickle charger panel and connect it direct to the battery, no regulator is needed IF the panels max current output is less than 1/100rd of the battery capacity in Ah.
This usually means a panel size of less than 10Watts. These panels also have fewer solar 'cells' (30 against36) to give a lower maximum voltage, hence they are considered 'self regulating'.
Advantage: you can leave it unattended, no mains power connection required. Price is on par with a small mains charger.
Disadvantage: you have to place the panel where the sun strikes it for the bigger part of the day.
Klaus
390398
Reply By: Mainey (WA) - Thursday, Oct 27, 2005 at 17:12
Reply By: Ingenious - Thursday, Oct 27, 2005 at 21:14
Brad like the others have said, automatic chargers are the best way to go heaps of choices and price ranges though, check out these three stage fully automatic chargers, 6 amp $99.00 or 10amp for $159.00 at
http://www.absorbedpower.com/battery/products/
Also Projector have some automatic low amp maintanance chargers that others on here have found at Bunnings/Kmart on special sometimes.
Cheers.
136689
