gu patrol 3.0 and 4.2
Submitted: Sunday, Oct 30, 2005 at 21:31
cobes
Hi all,
Just wondering if the drive train is the same in each of these vehicles?
I understand that some of the 4.2 td had problems when towing in 5th gear.
I would like to know when this problem was rectified and if it exists in the 3.0 models.
I also understand that the 3.0 litre models underwent an upgrade in late 02 to rectify engine problems.
Does anyone have any first hand experience with engine failures for the 3.0 from 03 onwards?
Thanks in advance
Chris.
Reply By: wildbill05 - Sunday, Oct 30, 2005 at 21:41
telstra via their fleet mob put out a specific warning to say never to use 5th gear unless the vehicle was basically empty let alone towing anything
137083
Reply By: 120scruiser - Sunday, Oct 30, 2005 at 21:53
Gday cobes
Try my site
here, about Patrols
It may answer some questions.
137088
Follow Up By: V8Diesel - Sunday, Oct 30, 2005 at 22:31
There's some real good stuff in there, nice work.
Do you do write ups on any other vehicles?
390795
Follow Up By: P.G. (Tas) - Sunday, Oct 30, 2005 at 22:56
That link is very informative, but it doesn't really touch on the post 2002 engine problems after the "Nissan fix".
Does this mean Nissan got it right, or isn't any one talking about post 2002 blowups?
Cheers.
390799
Follow Up By: 120scruiser - Monday, Oct 31, 2005 at 08:22
Thanks V8Diesel
I have done Commodores and Prados so far. As time permits I will put more pages together slowly on other vehicles.
P.G I can't comment on post 2002 as most of my customers still have very low km's. My Nissan dealer tells me they are much better but time will tell.
390815
Reply By: muzzgit (WA) - Sunday, Oct 30, 2005 at 22:05
Regardless of drive train, people tow in 5th at their own risk. This is not a problem associated with Nissan only, it applies to all vehicles !!!
Nissan, Yota, Bitsamissin, Honda, Holden, whatever..... ring them if you like, they will all tell you........ DON'T TOW IN OVERDRIVE...manual or auto.
The fact that people do and never seem to have problems appears to be a bit of a lottery. If you only have the vehicle for 3 or 4 years, which is fairly common, they will tell you... "oh yeah, I tow in 5th all the time and never had a problem, don't worry about it, that's an old wives tail"...
I have spoken to people who have had the same vehicle for 8 or more years, towing heavy trailers for work, or big caravans around OZ and one thing comes around......BUGGERED GEARBOX.
If you think I'm full of crap, go and talk to a transmission repairer/specialist, see what they say.
137089
Follow Up By: Member - Captain (WA) - Sunday, Oct 30, 2005 at 22:17
Hi Muzzgit,
I had my 1990 1HZ 80 series for 300,000kms and always towed in 5th gear. While I have no doubt that your experience has resulted in a buggered gearbox, my experience has been different, never had a problem.
I find towing in 5th gear at 100km/hr more appropriate for engine revs (but obviously select gear choice based on terrain).
Captain
390792
Follow Up By: Member - Duncs - Sunday, Oct 30, 2005 at 22:28
I'm with Captain on this one. My GQ did a lot of towing on and off road for about 7 years that I had it I always use 5th.
It had 385,000km on when I sold it and never had a gearbox problem.
Couple of other things got a little exciting but not the gearbox.
The prob with the GU 5th gear was rectified, it was specific to a known period and a vehicle can be checked by comparing the Vin Chassis number to the list at your local dealer.
Duncs
390794
Follow Up By: warthog - Sunday, Oct 30, 2005 at 22:50
I have been given the same advice as you muzzgit, by a mechanic who has worked on many 4wd's. 5th gear is not designed for towing. If you are worried about revs slow down a bit, the fuel saving will be worth it any way.
390798
Follow Up By: Member - Trevor R (QLD) - Sunday, Oct 30, 2005 at 23:12
To Captain and Dunc's,
You can then get the other side of the story and replace three (3) lots of 5th gears on a 100 cruiser in 18 months and 13000km by towing in 5th just ask me.
All work done under warranty and all done because the dealer kept telling me if your at the right revs/speed 5th is ok.
Well I'm here to tell you experience tells me NOT to tow in 5th.
My 2 bobs worth.
390801
Follow Up By: Member - Captain (WA) - Sunday, Oct 30, 2005 at 23:30
Hi Trevor,
A bit hard to know what to do isn't it!!! Some have had no problems, others like yourself have had a heap of issues. Maybe I would have a different opinion if I had some of your problems.
My thoughts on the issue is that my vehicle is rated for 3200kgs tow weight yet I only tow ~1600kg. Nowhere in the manual does it state to only tow in 4th gear, but is does state a recommended speed range for each gear and 5th gear is fine for 100 km/hr.
But if you want to be conservative then arguably a good idea to tow in 4th. And to be even more conservative why not tow in 3rd, or 2nd... Me,
well I reckon if the vehicle has 5 gears, I'll use them all ;)
Cheers mate
Captain
390803
Follow Up By: Bonz (Vic) - Monday, Oct 31, 2005 at 12:35
transmission repairer/specialists know if you're full of crap? I doubt that, how could they all know.......?
390851
Reply By: Member - Roachie (SA) - Sunday, Oct 30, 2005 at 22:29
My understanding is that the manual version of all 3 of the GU's (ie: 3L, 4.2L and 4.8L) have the same drive train with the exception of the diff ratios.
Happy to be corrected.
Just while on the subject, if I decide to go up to 285/75s at next tyre changeover, would I be better off getting the diff ratios changed with a set out of a 3L or 4.8L? I know blokes who have these larger tyres and say the gearing is not too high for them. However, even with the 265/75s on (which are slightly bigger than the standard issue 265/70s), I notice the old girl needs a lot of clutch slip to get off the mark when fully loaded with trailer and roof rack loaded etc, if I'm on even a relatively easy gradient. I like how she is only doing about 2050rpm @ 100kph, but figure I might have to sacrifice some of this low revving with bigger tyres. Anybody got any thoughts?
137094
Follow Up By: Gerhardp1 - Sunday, Oct 30, 2005 at 22:45
If you are having launch problems with 265/75, you will have worse launch problems with 285/75.
To then change diff ratio to ease the launch problem back to close to 265/70 status, would seem a lot of money spent to go nowhere in particular except gain a little more ground clearance and possibly lose your roadworthy status for Insurance and RTA.
For getting off the line you would be better off going back to standard size tyres, although this may preclude using LT tyres which are usually why you go to the /75 from the /70.
390797
Follow Up By: Member - Captain (WA) - Sunday, Oct 30, 2005 at 22:57
Hi Roachie,
I reckon the 285/75's (~33") are the way to go. I had a direct back-to-back comparison in my 80 series when I went from 10.5x31R15 to 10.5x33R15 and the offroad improvement was astonishing. The old 1HZ diesel never used to like beach work, it was always a big effort even at low psi but after going to the 33" tyres, beach tracks that needed say 20 psi could be done at road pressures and 15 psi tracks were now ~20 psi. And when ypu got down to 12 psi, the old girl was unstoppable compared to before. Was enough difference to convince me to change to 285/75's on my brand new GU on the day I picked it up.
When towing in the 80, i never really noticed any difference. The 80 already had a good first gear and the 7% increase did not seem to make a noticeable difference. But as you have already gone from 265/70 (31") to 265/75 (32") and have an issue, the 285/75 (33") will add another 3.5% to your problem. But is it enough to change diff ratios???
Personally, I would fit the 285/75's just for the improvement in off-road performance and then see how it performs on-road with your van. If you find it OK, great, but if not then do the diff ratio change IMHO.
Captain
390800
Follow Up By: V8Diesel - Sunday, Oct 30, 2005 at 23:52
Roachie, I was looking into putting a 6.5V8 into my GU ST4500 and the bloke at Brunswick said that GU's do have different gearboxes and diffs depending on what one you get.
Aparently the petrol 4.5 / 4.8's and the 4.2D's are bulletproof. The 3.0 and 2.8 less so. I think the 2.8 had a cra gearbox in it. Diffs ratios vary too. They swap them out anyway as a matter of course.
Don't quote me, but that was what I was told. The reason I looked into all variations was resale value of the motor to offset the cost of conversion.
390805
Follow Up By: Member - Captain (WA) - Sunday, Oct 30, 2005 at 23:55
Hi V8Diesel,
The 3.0TD has the same gearbox and diffs(but different ratio) as the 4.2/4.5/4.8's. The 2.8 GU has the skyline gearbox and not the trucklike ones in the higher Nm output motors.
Captain
390806
Follow Up By: muzzgit (WA) - Monday, Oct 31, 2005 at 00:11
Roachie, I'm with Captain on this one. I went from 31x10.5R15 to 33x10.5R15 on my FJ62 and found the difference off road
well worth the effort.
390808
Follow Up By: V8Diesel - Monday, Oct 31, 2005 at 09:32
That's right Cap'n, it's all coming back to me. It's the 3.0 auto transmission that was different (the 4.8 is out of the US Titan) the 3.0 manual is the 'truck' number as you say and the 2.8 is the wee one.
390820
Follow Up By: ACDC - Monday, Oct 31, 2005 at 12:21
Drive train is not all the same for starters you get two different size back diffs 3.0 has a small back diff.
390845
Follow Up By: Member - Captain (WA) - Monday, Oct 31, 2005 at 12:37
Hi ACDC,
Depends what you mean by "small" back diffs. They have different diff ratios but can be interchanged i.e. fit bigger tyres to the 4.2TD and you can change the 3.9 ratio to the 4.3(?) from the 3.0TD. But as far as the diff casing and axles go, they are the same.
Captain
390852
Follow Up By: ACDC - Monday, Oct 31, 2005 at 13:00
Check the ARB air locker listing there's two size back diffs most 3.0l have the smaller back diff about the same size as the front diff with a curved bottom centre housing and then the larger diff with a flat section at the bottom of centre housing.
390854
Follow Up By: Andrew (Whyalla SA) - Monday, Oct 31, 2005 at 13:13
ACDC is almost right.
The 4.8 petrol and 3.0TDi manuals have the larger 260mm rear diff, all of the others have the 233mm rear diff. Thois ruleis not absolute as someARB fitters have randomly foung 260 rear diffs in vehicles that shouldnt have them.
Roachie - you"should" have the 233 rear diff so make sure you get the right size centres if you are going to swap.
BTW - 33s are FINE ya big sook 8-))
390857
Follow Up By: Member - Roachie (SA) - Monday, Oct 31, 2005 at 14:34
Thanks everbody for your ideas and responses.
I sort of feel guilty that I stole the thread....sorry...
Andrew, the old girl does already suffer at getting off the line with the trailer on if the road has even a slight incline. I never drove it with the 265/70s on.....had the 265/75s placed on before I picked it up brand new in 2000.
So I can only imagine that the 285/75 (or 305/70 like yours), would make it just that much worse.
Does anyone know how much effort is involved in changing the diff ratios and where would a bloke be likely to get onto a set? Come to think of it, I met a bloke at
Peake on the weekend with a 4.8 petrol who was wanting to get his rig revving less.....he has 315/75s on and it still does 2600rpm @ 100k/h....it was doing 2900rpm when he had the standard rubber on it. Maybe I could do a swap with him??? hhmmmm
Roachie
390866
Follow Up By: ACDC - Monday, Oct 31, 2005 at 16:31
I did say most 3.ol have small back diff as i have found some with big diffs as you say they should'nt have them!
390890
Follow Up By: Andrew (Whyalla SA) - Monday, Oct 31, 2005 at 17:18
ACDC - 3.0TDi manuals should have the 260 diff, 3.0TDi autos should have the 233. In reality it seems a bit of a lottery.
Roachie - The only way you will be able to get the diff ratio from the 4.8 would be to do a rear axle swap. Try and get him to swap the front as
well, then you can have the 4.8s big brakes. LOL. Worth a try. hehehe
390897
Follow Up By: V8Diesel - Monday, Oct 31, 2005 at 17:45
Roachie, speak to engine conversion
places. I know that the Chev V8 diesel swap requires the standard gearing to be changed, so there must be about 10,000 sets of standard gears for every configuration of GU lying around somewhere gathering dust (
well they don't break do they!).
390900
