Site Search
Section Image
Which winch
Submitted: Wednesday, Nov 02, 2005 at 12:47
Member - Howard (ACT)
interested in others opinion on which way to go.
I am considering a new winch for an 80 series l/c now I also lug a camper trailer around.
looking at 12000 lb models ,seems there is a choice of 5.5 hp models with 265-1 gearing or 4 hp versions with 450-1 gearing
what are the pros and cons of each.
Fortunately I've only ever used the currrent winch(6000lb) in anger on about 3 occassions and never had to winch more than a vehicle length.
Howard
Nolan Brook -July 2008
Click Image to Enlarge
Retiree in Training
Advertisement
ThreadID: 27750 Replies: 7
Views: 1434 FollowUps: 16
AnswerID: 137425   Submitted: Wednesday, Nov 02, 2005 at 12:55
Redback replied:
What about a X-9 Superwinch 9000lbs Howard, this baby will move trees ;-)))
Reply 1 of 7
FollowupID: 391117   Submitted: Wednesday, Nov 02, 2005 at 13:53
Rod W posted:
So will my 1600kg tirfor, and the electric motor will never burn out.
FollowUp 1 of 6
FollowupID: 391135   Submitted: Wednesday, Nov 02, 2005 at 15:50
Member - Howard (ACT) posted:
hi Baz,
would be happy with a 9000lb+ winch and I know your X-9 shifts trees.
BTW how did last weekend go?
catch up soon
Howard
Retiree in Training
FollowUp 2 of 6
FollowupID: 391185   Submitted: Wednesday, Nov 02, 2005 at 20:14
Outnabout David (SA) posted:
So you have been moving trees with it have you. You are supposed to find a big tree and move the vehicle. Seriously glad it is working to your satisfaction.
We have so little time to enjoy our land
FollowUp 3 of 6
FollowupID: 391234   Submitted: Thursday, Nov 03, 2005 at 08:59
Redback posted:
Rod, it was a inside joke i helped Howard move a tree on his property a few weekends ago ;-)))
David yep works well, thanks i have used it on the car too, lol.
Howard the weekend was good did, Whitemans and Slippery rock, with some slight damage to the rear quarter panels nothing too bad, lol.
The only bad thing was Honey got a tick and nearly died, but she is fine now and home recovering.
I'll let you know in plenty of time about that blokes only weekend.
Baz.
FollowUp 4 of 6
FollowupID: 391243   Submitted: Thursday, Nov 03, 2005 at 09:17
Rod W posted:
Yep, not a problem Redback and Outnabout. I have/do use my come-a-long (Tirfor type but not the Tirfor make) to remove unwanted trees in the backyard. Set-ups with single, double or triple pulls depending on the stubborn-ness of the tree, with sand soils here in Perth it is amazing the grip some trees have. The last one was a 60cm dia stump to which its resistance snapped a winch strap (rated at 4 tonne) that I had in the set-up. But I won in the end.
FollowUp 5 of 6
FollowupID: 391258   Submitted: Thursday, Nov 03, 2005 at 10:36
Redback posted:
Rod i have a 1.6t Big Haul hand winch as well as the vehicle winch, works brilliant.
FollowUp 6 of 6
AnswerID: 137426   Submitted: Wednesday, Nov 02, 2005 at 12:57
fozzy replied:
howard
no idea on what driving and where u go but have you thought of maybe even a 9000 or 10000 lb and carrying cple of snatch blocks. quite a bit slower with snatch blocks but saves a heap of weight over front. something to think. at end of day its all a compromise
fozzy
Reply 2 of 7
FollowupID: 391156   Submitted: Wednesday, Nov 02, 2005 at 18:12
Member - Davoe (Widgiemooltha) posted:
Not enough My 10,000p Warn wont pull my 80 out with a snatch block if your sitting on the diffs and wont even go close with a single pull
you dont need to leave perth to go bush
You dont need to leave Perth to go bush
AnswerID: 137430   Submitted: Wednesday, Nov 02, 2005 at 13:30
Longreach replied:
Haven't got one, and sorry if this isn't quite what you asked, but i've wondered whether the hydraulic (OX) ones are the way to go because you can run them continuously without draining your battery ?
Reply 3 of 7
FollowupID: 391126   Submitted: Wednesday, Nov 02, 2005 at 15:01
signman posted:
If the engine is running. And if the engine is running you won't drain the battery.
At least the electric one will operate with engine not running.
FollowUp 1 of 4
FollowupID: 391130   Submitted: Wednesday, Nov 02, 2005 at 15:31
Longreach posted:
Again, I don't have one but I'm sure I've read that electic winches draw the power faster than the alternator can put it back. Is this true ?
I agree that the hydraulic ones do have this disadvantage of not running if the engine has stopped. Not a good situation if your engine wont start in the middle of a river.
Cheers.
FollowUp 2 of 4
FollowupID: 391133   Submitted: Wednesday, Nov 02, 2005 at 15:41
signman posted:
As with any winching operation- the idea is NOT to give it one continuous pull. Rather winch a bit, then survey the situation, winch a bit more then let the winch (electic or hydraulic) cool a bit etc.
With a decent size battery that all 4wds should have, theres enough power to winch out of a decent boghole.
FollowUp 3 of 4
FollowupID: 391148   Submitted: Wednesday, Nov 02, 2005 at 17:22
Wayne (NSW) posted:
signman,
I had an 9000lb warn winch on the 80 series and now have a OX hydraulic on the Troopie.
With the electric it can be used with out the motor running, but for only a short time, and if the motor is running then the idle has to be set at 1200/1500rpm. Pity they have dropped the hand throttle on most of the vehicles.
The electric can and should only be used for a short amount of time and more time allowed to rest so that the battery can recover and the winch cool down.
The hydraulic has to have the motor running but only at idle, and from what I have seen there is no build up of heat in the winch or the power steering fluid. The winching speed is very slow, but does have a high speed rewind of the cable after use. The winch is rated at 10,000lb and will fit into the space of a 9,000lb electric winch.
Having said that if you are towing a trailer of any kind then a hand winch is a must. It is no good having a winch on the front of the vehicle and the trailer jack knives and needs to be pulled back wards.
The debate could go on forever, but what ever winch is chosen training in the safe use of the winch is a must.
Wayne
Canning Stock Route 2009
Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
FollowUp 4 of 4
AnswerID: 137431   Submitted: Wednesday, Nov 02, 2005 at 13:31
Member - Duncs replied:
I looked at this exact question some time ago. I have a GU and tow a 4x4 camper so our needs are similar.
The answer I came up with was the HS9500 Warn.
Firstly. Most of the times I have been stuck and needed a winch I have not been too badly stuck. Usually I have been able to get out using alternative recovery gear but the winch just made it quicker. Therefore I believe the 9500 would have the grunt and being high speed it is heaps quicker. Compare teh line speed between it and the 12000 you are looking at.
If I am really stuck I am going to be there for a while anyway so out comes the snatch block etc. Even with the block in the 9500 is about the same speed as the 12000.
Second. The weight of the winch. As has been said above those big things, even the little ones put an awful lot of weight right out in front. This must have an effect on vehicle balance, tyre ware and suspension performance. I'd like to keep the winch as light as possible. The 9500 is one of the lighter winches on the market.
Third. Cost. The HS is dearer than other winches of a similar capacity but it is a good bit cheaper than the 12000.
Now all I have to do is convince the missus.
Any ideas how I do that?
Duncs
Eric the Emu at home
Content with where I am but looking for somwhere else to go. Pic 1 Eric the Emu at home Pic 2 camped on Cooper Cr
Reply 4 of 7
FollowupID: 391140   Submitted: Wednesday, Nov 02, 2005 at 16:11
Duncs,
I take on board what you say about the weight of the 1200 v 9500 .
even in the 9500 there is the same choice on HP and gearing.
My basic understanding was that the better gearing the easier the pull but the longer time it will take to move the vehicle a certain distance.
what I am really asking ,given that in my opinion most recoveries are over a relatively short distance,
is whether a bigger hp higher geared winch(assume this draws more power under load) is better or worse than a lower hp lower geared winch which should draw less power but may take a bit longer to complete the task.
what are others experience ?,after what distance/time would one have the advantage over the other?while both have same rating I would have thought that a lower geared winch would be stronger or is it the other way around ?
thanks to those that have responded so far.
Howard
Retiree in Training
FollowUp 1 of 4
FollowupID: 391142   Submitted: Wednesday, Nov 02, 2005 at 16:28
Crackles posted:
Agree completely Duncs.
The power & speed to the weight of the winch is far superior on a 9500lb than any of the big boys (except a 8k high mount). For an item the average bloke will run out less than 5 times a year, the 12000lb is very heavy over the front end & has far less cable length.
Recovering 2 near identical heavily laden Cruisers the 9.5K outpulled the 12K in speed & goes to show a big HP motor & high rated capacity does not necesarally equate to better pulling power. The 12k has so little cable you end up pulling on the 2nd & 3rd layers all the time which are only about 9,000lb anyway.
As they are so slow, when you assist by driving they continually overrun birdcaging the cable.
Only if you are regually winching very heavy loads would I concider a 12k.
Cheers Craig........
Ramsey 9500HS
FollowUp 2 of 4
FollowupID: 391157   Submitted: Wednesday, Nov 02, 2005 at 18:20
I dont understand this fascination with winch speed. Your not going on a warn winch outback challenge are you? Generally when stuck My main concern is to get out not wheather i can save 30 sec doing it. I would certainly go the 12 as anything less wont pull an 80 out if bogged properly (I know for a fact a 10 wont) even better I have found Hi lifts to be far more effective in unbogging badly bogged vehicles
FollowUp 3 of 4
FollowupID: 391344   Submitted: Thursday, Nov 03, 2005 at 22:15
Crackles posted:
Dave I think you missed the point on winch speed. Although relatively fast, a 9.5K HS would not be anywhere quick enough for a winch challenge. They're often running 8K high mounts at 24 volt with with upgraded motors, plasma rope, custom gearing & even water cooling.
Speed is important as I mentioned to avoid over run & to recover a vehicle out of muddy water. (I for one would prefer to get out quickly to avoid filling the car with mud)
After looking at Warns specs the 9.5HS outpulls the 12k right accross the full load range & even when its double blocked it's still quicker at 12.000lb load. Where the big winch wins is it uses around 15% less power but because it's so slow its running for longer so the end power usage is pretty much the same.
& it's not just 30 seconds you save. It takes almost 5 minutes just to wind in all the cable with no load on a 12k & less than half that on a 9.5.
The 12k is 26 kg heavier, slower, more expensive & I question that many bull bars for an 80 series would be rated to take 10 tonne. (full load double blocked)
Agree totally that the high lift is a great unbogging tool only surpased by the mighty shovell;-)
To further answer your question Howard as to which motor size is best in the 9.5K range for example the XP with the big 6hp motor is around 5 to 10% faster under load than the 4.6 hp HS although surprisingly is 60% slower unloaded. This extra speed under load comes at a big cost to power consumption varing between 10 & 60% more.
I suppose what you have to concider is do you need that extra line speed & if so will your battery system supply the extra power?
Cheers Craig.........
FollowUp 4 of 4
Activities Index
4WD Eco and Nature Half Day  -  Blue Mountains 4WD Eco and Nature Half Day - Blue Mountain
Blue Mountains - NSW
Discover the more remote areas of the Blue Mountains World Heritage Area by 4WD.
Boat Trolling Full Day for 2 Boat Trolling Full Day for 2
Snowy Mountains / Jindabyne - NSW
Join us for a full day of trolling on Lake Jindabyne.
1 Day Barista Crash Course 1 Day Barista Crash Course
Sydney - NSW
The Coffee Gang's 1 Day Barista Crash Course teaches you the basics of making a real coffee - grindi
Paintball Skirmish Night Games Paintball Skirmish Night Games
The Murray - NSW
Experience Melbourne and Victoria and Australia's ONLY OUTDOOR 'GLOW IN THE DARK' Paintball field fo
Book Now - Things To Do
AnswerID: 137435   Submitted: Wednesday, Nov 02, 2005 at 14:06
chump_boy replied:
Howard,
Let me say up front I import and sell winches, so I would naturally say you should buy one of mine....lol... but there is no way I will say what brand they are on here, until I have paid for some advertising, or at least become a member!
Seriously, the ones coming out of China these days are pretty good. They are all seeming to come out of a couple of factories, and have been doing so for a few years now. Ours are the 5.5Hp units, weigh about 38kg, and do the job just fine.
Email me at chumpion at tpg dot com dot au if you want one of the 12000lb models, with a few bits and pieces for between $800 and $900 (depending on the bits and pieces). I have a second hand unit available as well that I have replaced the brake inside the drum if you are interested. Cost is around the $600 mark, as it has seen very little use.
Alternatively, we are looking at some new 15000lb hydraulic units for around the $1900 mark, but they will be a couple of months away (factory is not happy with the design yet).
With the Chinese units, some of the sellers on eBay are giving away 24 months warranty. Just make sure the company has an ABN, as the factory warranty expires after 12 months. Repco are selling a similar winch as well, but they don't come with things like a mounting plate, cover or gloves (may not be important for you).
Chump
Reply 5 of 7
AnswerID: 137447   Submitted: Wednesday, Nov 02, 2005 at 15:12
Pattio replied:
Howard,
I installed my new 9500lb winch over the weekend on my GU. Purchased it from 4B.com, an advertiser on this site. Although it has not been used in anger yet, I am very happy with the service, price and quality of the product.(have spooled it in and out in the driveway and it works fine) BTW when I seperated it to rotate the gearbox,
cast into the casing is the name of a more expensive brand of Chinese imports.
Chris
Reply 6 of 7
FollowupID: 391159   Submitted: Wednesday, Nov 02, 2005 at 18:33
ACDC posted:
Would that be a Tmax ! yuk
AnswerID: 137546   Submitted: Thursday, Nov 03, 2005 at 06:16
brian replied:
I have 10000lb ox on gu pulls much more than my mates 9000lb electric simply no comparison,winching speed is unimportant to me,it gets the job done.
Reply 7 of 7
