Turbo
Submitted: Friday, Nov 04, 2005 at 16:44
Ross w
With reface to the use of a turbo using roller bearings,
Turbine shafts usually run through white metal bearings witch are centred by engine oil pressure.
My question is how did the manufactures get around the heat transfer problem(meaning heat from the exhaust turbine transferring along the shaft into the roller bearing) witch would have to be contacting the shaft.
Reply By: warthog - Friday, Nov 04, 2005 at 20:47
high flow oil feed
137850
Reply By: Ross w - Monday, Nov 07, 2005 at 10:28
Good morning warthog,
How dose that get away from the high temperatures generated while the turbo is in a boost position?
Ross
138197
