18 inch tyres for discovery
Submitted: Friday, Nov 04, 2005 at 23:30
ThreadID: 27835 Views:3307 Replies:3 FollowUps:2
Has anyone replaced their 18 inch tyres (255/55/18) on their discovery?? If so what did you put on ?? I want to fit the most aggresive rubber i can. So far the only option i've come across is 275/65/18 cooper stt, which will involve some fairly extensive work to fit as they are 3 inches larger in diameter.
thanks in advance.
disco_cox
Reply By: Cannon - Friday, Nov 04, 2005 at 23:46
Hi Disco Cox
Firstly, you need to ditch the 18 inch wheels. They are a highway/on-road/show car wheel. Keep them by all means for the 'show car' look, but you need to find yourself maybe some 16inch steel rims (or alloys if you are really going for looks). Ruling out that you have a Discovery 3, if you have a Series 2 Disco, the steel wheels are harder to come by. Series 1, you are laughing.
You can get up to approx 275/75/16 rubber on 16 inch rims on the Disco without panel rework. At 16 inch size, standard specs are 235/70.
You can get all the good US brands at the larger size rubber, eg BFG, Coopers etc.
AnswerID: 137878
Follow Up By: Sky Pilot - Saturday, Nov 05, 2005 at 07:41
Will a 16" rim fit on a Disco3? Their smallest standard wheel is 17". Would 16" clear the disc rotor and caliper?
FollowupID: 391498
Follow Up By: Redback - Saturday, Nov 05, 2005 at 08:49
Sky Pilot, no they won't clear the disc calipar.
Disco cox, hunt around for alloys from a P38 a Range Rover 95 on if you have the Disco 2 alot of Landy places sell them for around $100 to $150 each, steel rims you can get from Rangie spares in Melbourne, i think the last time i heard they were $135 each and there the cheapest, most places sell them for $250 +.
Baz.
FollowupID: 391508
Reply By: simple - Saturday, Nov 05, 2005 at 11:42
one of the tyre companies has an aggressive tyre that goes to 18" rims, i found them in my recent look at tyres, can't remember which brand for the life of me but just browse the websites....
AnswerID: 137907
Reply By: SKP - Saturday, Nov 05, 2005 at 20:46
If you go to www.chronicles.proboards and do a search you will find PCH in Melbourne has fitted 17 aftermarket Alloys with Coopers to his D3. Worked out cheaper than fitting 18" tyres.
Range Rover wheels DO NOT fit the D3, the offset is different.
AnswerID: 137956
