Diesel Pathfinder- Service Intervals?
Submitted: Sunday, Nov 06, 2005 at 11:38
ThreadID: 27864 Views:4565 Replies:5 FollowUps:3
Does anyone know what the service intervals are for the new Diesel Pathy?
Reply By: blown4by - Sunday, Nov 06, 2005 at 12:22
For the 3.0 litre turbo Patrol it is 10000k's unless you are drivng under severe conditions, which are listed in the manual, then it is 5000k's. Also Nissan advise against fully synthetic oils in the diesels but semi-synth is OK. Since the Pathfinder is the same mechanicals roughly I don't see why the intervals for it should be any different.
AnswerID: 138038
Follow Up By: TOB - Sunday, Nov 06, 2005 at 12:39
NISSAN MOTOR CO. (AUSTRALIA) PTY. LTD. ABN. 54 004 663 156
Locked Bag 1450, Dandenong South, VIC, 3164 Phone. (03) 9797 4111 Fax. (03) 9797 4400
www.nissan.com.au
The information in this bulletin should not be interpreted as a basis for claims unless so designated.
Part numbers referred to may not always be immediately available.
Always order parts from relevant parts information and not this bulletin.
First Published: 30th September 2004 Bulletin No: MA04-001
Recommended circulation
THIS INFORMATION IS CONFIDENTIAL TO NISSAN DEALERS ONLY
PRODUCT INFORMATION
Re: Revised Engine Oil Specification
Applied Model: Y61 & D22 Applied range: ZD30 Engines
Please be advised that the specification for the oil fill on the ZD30 has been revised. Engine
Oils that meet the specification listed below are the only oils that are permitted for use in the
ZD30 Engine.
Oil Specification: ACEA B3 or JASO DH-1
Nissan strongly recommend that a viscosity rating of 10W40 be used. For specific viscosity
relating to ambient temperature ranges please refer to the viscosity chart in the relevant
workshop manual.
Note: API CG-4 oils must never be used in the ZD30 engine.
To support the revision in oil specification, Nissan has developed a semi-synthetic 10W-40
engine oil that meets all the operational demands of this engine. The revision of the new oil
specification is retrospective and will apply to all ZD30 engines.
The oil will be available from Nissan Parts & Accessories in 5lt and 200lt quantities using the
following part numbers.
5lt - B3005-10W40PK
200lt - B3200-10W40PK
Authorised by:
R Bahn
Manager - Engineering Support
National Service & Engineer
ing Department
these oils meet the spec
Castrol magnatec 10w40
Shell rimula 15/40 do not use
Valvoline durablend 10w/40
Mobil synths 10w40
FollowupID: 391684
Follow Up By: Member - Blue (VIC) - Sunday, Nov 06, 2005 at 12:52
You gotta love this line... "THIS INFORMATION IS CONFIDENTIAL TO NISSAN DEALERS ONLY"
FollowupID: 391686
Reply By: Member - Trevor R (QLD) - Sunday, Nov 06, 2005 at 14:00
Shnog,
I don't know for sure so take this advise and do with it what you will.
If I owned one of these high tech turbo diesels and wanted to keep it for any length of time, I would defineately change the oil and filter/s every 5000km regardles of workshop manual. Maybe I am over conscious regarding this subject but that is my view.
Regards Trevor.
AnswerID: 138049
Follow Up By: Patrick - Sunday, Nov 06, 2005 at 15:03
Ditto....
FollowupID: 391692
Reply By: Notso - Sunday, Nov 06, 2005 at 18:47
The pathfinder has a new common rail diesel so the oil spec could be quite different to the Y61
AnswerID: 138083
Reply By: Truckster (Vic) - Sunday, Nov 06, 2005 at 20:29
Your local Nissan dealer would.
AnswerID: 138111
Reply By: DaveB - Monday, Nov 07, 2005 at 10:33
Had a test drive of the new Pathfinder diesel, fitting an auxiliary battery would appear to be a bit of a problem.
AnswerID: 138199
