engel fridge
Submitted: Sunday, Nov 06, 2005 at 13:25
ThreadID: 27865 Views:5670 Replies:5 FollowUps:7
Hello Everyone
Does any one know where in NSW can you get the compressor unit for a 60 litre engel frige.Ours got a hole when something was poked into it and the gas was release. We were told the hole can't be repaired, we have to replace all of the inside part.
Gilly
Reply By: Big Kidz (Andrew & Jen) - Sunday, Nov 06, 2005 at 13:29
I think that there is a list of repairers (who I guess would be able to get you a compressor) on the Engel website and there are a lot of links on this site at the moment to engel. I see that Anaconda in Melbourne have specials on Engel fridges at the moment.
I think that you have to use some sort of vacuum pump to get all the air and moisture out of the lines before you regas them.
AnswerID: 138045
Follow Up By: Nudenut - Sunday, Nov 06, 2005 at 15:16
"I think that you have to use some sort of vacuum pump to get all the air and moisture out of the lines before you regas them."...you are learning....
FollowupID: 391693
Follow Up By: Big Kidz (Andrew & Jen) - Sunday, Nov 06, 2005 at 16:25
Thanks newdy - it is all that helpful advice you have given over the years. I have written down what you have said in a little.... no ...its a huge black book, and also what your son Willem has said, as well, coz I reckon you taught him too!
FollowupID: 391710
Follow Up By: Nudenut - Sunday, Nov 06, 2005 at 16:49
a huge black book!....your sure its all my teachings?
swmbo says I know jack sheit......and if its possible i know any thing any thing at all it'd all fit on the back of a postage stamp!...
mainey probably reckons so too!.....hahaha
FollowupID: 391717
Reply By: Nudenut - Sunday, Nov 06, 2005 at 15:15
you punctured the evaporator?
doubt if you could put a hole in the compressor or condenser unless you were using a drill or a nail and hammer......the evaporator is only alloy and is easilly punctured
AnswerID: 138057
Follow Up By: Mad Dog (Australia) - Sunday, Nov 06, 2005 at 16:27
Can't be repaired nudie ?
FollowupID: 391711
Follow Up By: Nudenut - Sunday, Nov 06, 2005 at 16:41
i have heard people er tradespersons who have said they can repair ie weld the evaporator in the field...but never have I seen one that has been repaired....not saying it cant be done...just that ive never seen one\
seen plenty of evaporators that have had an attempt at repair......all with bigger holes than what they had...the alloy is only 15 or so thou thick....as soon as you put a flame on it...well its like ice melts quickly, leaving bigger holes ...get the picture?...another so called repair was to epoxy the hole....never had long term success at this either...most mechanics will attempt this once or twice in their lives and then give it a miss as it simply does not last.
A replacement evaporator should be available as spare part, and these come with copper tails ( welded or what ever they do in the fabrication process) so one can connect into the existing refrigeration system tubing
condensrs are usually steel and can be silver soldered using blue tip 45% silver
FollowupID: 391713
Reply By: Bat - Sunday, Nov 06, 2005 at 18:21
Peter at Canberra Refrigation fixed engel ,try a caravan place they know whose fixed all sorts of fridgs.Bat
AnswerID: 138081
Reply By: Craig from Engel Australia - Sunday, Nov 06, 2005 at 20:10
If you would like to contact me please call our Ph 1300 302 653 and please get my contact number from our customer call centre and i will gladly solve your little problem.
AnswerID: 138107
Follow Up By: Nudenut - Monday, Nov 07, 2005 at 08:01
this is what is called AFTER SALES SERVICE
FollowupID: 391805
Reply By: Member - Banjo The First (SA) - Monday, Nov 07, 2005 at 09:31
Keep in mind that the same person who tells you that it "can't be repaired" MAY have it running the next day if it was their own fridge ! I don't necessarily condemn your particular contact, but try and tap into other advice as back-up - the indicated labour and parts for a new fitout would virtually mean a new fridge. Sites like this contain hoards of reports the same as yours - people have saved heaps of $ by researching further.
AnswerID: 138183
Follow Up By: D-Jack - Monday, Nov 07, 2005 at 09:43
Good advice there Banjo
Anything can be fixed for a price.
D-Jack
p.s. maybe except some TD Jackaroo fuel injection problems!
FollowupID: 391832
