Tyres
Submitted: Monday, Nov 07, 2005 at 20:17
ThreadID: 27911 Views:3777 Replies:9 FollowUps:17
Hi all , can anyone tell me the theory on weight distribution on a fat tyre in sand and why a thin tyre is better in mud, I cannot see how this works.
Regards Luggy
Reply By: Exploder - Monday, Nov 07, 2005 at 20:56
The surface aria that is covered by a wide and tall set of tyres when compeered to a set of skinnies is far greater. Therefore the weight of the vehicle is distributed over a larger surface aria and so the tyres float over the sand and don’t sink in as much. But tyre pressure plays a big role in this as well, and I think it has got more to do with the rolling diameter rather than the width of the tyre.
I don’t totally agree with the second statement, but I suppose it could be because the skinny tyres will find the harder base (if there is one) a lot faster than fat ones and then they don’t need to move as mush slush to power throe it.
However I feel a fat and tall tyre will prefer better in both situations
AnswerID: 138321
Follow Up By: Frank_Troopy - Tuesday, Nov 08, 2005 at 11:28
Hi Exploder,
I think you are perpetuating a popular myth.
It is a misnomer that wider tyres have a bigger contact patch than skinnies. The size of the footprint is determined by the tyre pressure, irrespective of the width of the tyre. Skinny or wide, for a given pressure and weight, the contact patch will have the same area. With a skinny tyre the shape of the footprint will be stretched fore and aft. With a wide tyre the major dimension will be more lateral.
If you have 15 psi in your tyre, you will have 15 psi on the ground.
The main advantage of the big balloon sand tyres is that they have a large volume. The bigger the volume of the tyre, the lower the pressure that can be run. A balloon tyre running 5psi has twice the footprint of a tyre that can only be deflated to 10 psi.
Width of tyres for road use also is misunderstood. If you look at the formula for friction (f = &mu N), the only variables are the contact force and the coefficient of friction for the materials in contact; area is not included. Wider tyres give advantages in terms of decreased heat buildup and improved wear and enable use of softer compounds. They also have a bearing on steering and handling, but do not give a larger contact patch if the pressures are the same.
Cheers Frank.
FollowupID: 392026
Follow Up By: robak (QLD) - Tuesday, Nov 08, 2005 at 11:56
Wow frank, now you got me thinking.
So what you're saying is that if you're going to run say 10 psi for driving in the sand you'll be better off with skinny tyres because that will give you the same contact surface area which is skinnier but longer. And it'll give the effect of those things that army tanks use (what are they called?). BUT with skinny tyres there might not be enough air to let down that much so you'll be riding on your rims,. Right?
My rode bike (push bike) runs on half inch wide tyres at about 100 psi. Say if i put my car tyres on my bike and pump them up to to 100 psi and keep the same weight then the contact area should be the same as with the standard half inch bycycle tyres. Is that right?
Maybe I'll do an experiment and just swap the tyres between my road bike and my mountain bike.
R.
FollowupID: 392033
Follow Up By: MATT.D(WA) - Tuesday, Nov 08, 2005 at 12:55
Frank,
Two tyres with the same rolling diameter but different widths at the same pressure on the same vehicle won't have the same contact area on the ground.
Matt.
FollowupID: 392042
Follow Up By: robak (QLD) - Tuesday, Nov 08, 2005 at 13:28
Say my car weighs 2000kg. That's 4400 pounds.
When my tyres are at 30 psi, my contact area is 146 square inches(4400pounds / 30psi), or 36 square inches per tyre.
When my tyres are at 15 psi, my contact area is 293 square inches (4400pounds / 15psi), or 73 square inches per tyre.
Now at 15 psi:
A skinny tyre (say 8 inches wide) will have a footprint of
8 inches x 9.1 inches (width x lenght)
A fat tyre (say 16 inches) will have a footprint of
16 inches x 4.5 inches (width x lenght)
So, a wider tyre (at the same psi) will not give a bigger footprint. It'll just give a wider but shorter footprint.
FollowupID: 392045
Follow Up By: Frank_Troopy - Tuesday, Nov 08, 2005 at 15:50
Hi Matt,
The pressure in the inside and outside of the contact patch has to be the same for the tyre to be in equilibrium. The car will settle to that point. Robak's example is spot on in my view.
Of course there are some slight differences due to the spring effect of the sidewalls, elasticity of the tyre and so forth. Just about all the rules of physics really only work for a perfect system and have slight flaws in the real world. Einstein's famous E = mc^2 is really incorrect, however the inaccuracies compared with the real formula (E = mc^2/(1 - SQRT( v^2 / c^2))) are too small to worry about unless the velocity is very high. In our case the errors are unlikely to be significant, unless say Robak does put his car tyres on his bicycle. I suppose it depends on how pedantic you choose to be.
Of course, if you can explain how the footprint areas can be different Matt, I'd be very interested to hear it.
Cheers Frank.
FollowupID: 392085
Follow Up By: Exploder - Tuesday, Nov 08, 2005 at 20:35
Ok. What i am now interested to know then, is if skinnies are better then why are the majority of 4Wders running fatter tyres like Tour operators, general public, Tuff truck competitors, 4WD mags.
As for the on road contact/Grip augment this was answered by a engineer from Bridgestone on behalf of this forum and his answer is completely opposite to what you are now saying.
FollowupID: 392152
Follow Up By: Frank_Troopy - Tuesday, Nov 08, 2005 at 23:58
Hi Exploder,
I'm sorry if I didn't make myself clear. The myth I was referring to was regarding width/footprint, not what's better or worse.
What's better is a "horses for courses" argument I wouldn't buy into here.
Cheers Frank.
FollowupID: 392238
Follow Up By: robak (QLD) - Wednesday, Nov 09, 2005 at 10:49
"why are the majority of 4Wders running fatter tyres" - That's the question we're all trying to work out. Don't forget that rally drivers use skinny tyres. (on the hard but slippery surfaces)
I reckon, in sand, at the same psi skinnies would have a greater advantage BUT, and it's a big but, you can't let down skinnies as far as you can fats. Skinnies will fold in on themselves, come off the rims and the sidewalls will get a much bigger workout and eventually fail.
Going back to my two pushbikes. I ride my mountain bike at 45-60 psi and my road bike at 100 psi. There is absolutely NO WAY I could drop the road bike tyres to 45 psi. I'd be riding on the rims.
To take it to the extreme, Why can't I put my bicycle tyres on my car?
From above - my car at 30 psi requires 36 square inches of tyre contact (per tyre). You can't get that much surface area out of a bicycle tyre and therefore, once again, you'd be riding on your rims.
Just my thoughts.
R.
Also - I think frank and Mr Bridgstone are saying the same thing.
FollowupID: 392304
Follow Up By: MATT.D(WA) - Wednesday, Nov 09, 2005 at 13:50
Frank,
Finally got my head around your physics lesson and I stand corrected.(thats why I gave up physics after a week)
At least we all agree that it's the length of the footprint that matters more than width.
Cheers Matt.
FollowupID: 392349
Reply By: Wayne (NSW) - Monday, Nov 07, 2005 at 20:57
Luggy,
When a tyre is at road pressure it may have a footprint of say 100 square centimetres The weight of the vehicle is spread over this area. For this, lets say that the vehicle weighs 2000kg, so each tyre has 500 kg of weight, and has 5kg / square centimetre.
If the tyre is deflated the foot print is now larger, say 200square centimetres. The vehicle weight is still the same but now spread over a larger area.
Tyre weight= 500kg foot print= 100 square centimetres 5kg/ square centimetre
Tyre weight= 500kg foot print= 200 square centimetres 2.5kg/ square centimetre
The wide tyre on sand is not as good as a narrow tyre. A wide tyre even though it has a large footprint, also has a wide area across the tyre. This causes a wedge of sand that the tyre is trying to go over all the time. A narrow tyre has a smaller wedge to try and roll over so there is less effort to drive on the sand.
The footprint of the tyre should be long and narrow.
Mud tyre or tyres that have an open block are not as good as road tyres, and tyres that don't have much tread are even better.
As for skinny tyre in mud, it is the same as spreading the weight over a small area, more weight / square centimetre.
Wayne
AnswerID: 138323
Follow Up By: MATT.D(WA) - Tuesday, Nov 08, 2005 at 02:55
Wayne,
I think you'll find that it's not the width of the wedge but the gradient of it that makes it harder to get over. To me I would think that a skinny tyre would sink in more than a fat tyre, therefore creating a sharper wedge to climb over. I disagree with you in that the tyre should be long and narrow. The footprint should be long for sure but if you compare 2 tyres with the same length footprints, I think you'll find that the one with the greater width would perform better in sand. It all comes down to surface area and weight.
matt.
FollowupID: 392001
Follow Up By: robak (QLD) - Tuesday, Nov 08, 2005 at 12:01
Matt,
I think, as frank said above - the surface area of the tyre, at the same pressure, will be the same. Regardless if it's skinny or wide and therefore a skinny will not sink any more then a wide tyre. However a fat tyre can be let down to lower pressures giving you a greater surface area.
R.
FollowupID: 392035
Follow Up By: flashnick - Tuesday, Nov 08, 2005 at 22:37
Lots of theory here but not much practice,
So this is a test and I want simple answers to test your knowledge>
Final word on the wedge in front of the tyre. The wedge will be higher the deeper the tyre sinks into the sand, the idea is to keep the vehicle floating on top of the sand. So what are we going to use here???...............
Fats or thins??
Ever notices the tyres on the poor guys vehicle that is snatching most of the vehicles out of the sand ??
Fats or thins?
Has anybody ever driven through the simpson desert with both wide and narrow narrow tyred vehicles?? Did you notice which got up the dunes easiest??
Fats or thins?
Ever watched the fun while numerous vehicles try to cross a wet clay pan.
Notice which got furthest??
FollowupID: 392191
Reply By: GaryInOz (Vic) - Monday, Nov 07, 2005 at 21:04
1. Floatation. Wide tyres with low pressures in them exert less force on the sand, therby creating less of an indentation in it. You therefore don't have as far to drive "uphill' to get moving, and have generally less chance of digging youself in.
2. Penetration. Skinny "pizza cutter" wheels sink further into the mud for the exact opposite reason of 1. above. They are also able to exert more force onto the hard surfaceat the bottom of the mudpit, giving overall better traction....sometimes.
If the mud is deep, there is some justification for the "float and wellie" approach of lowering the tyre pressures and giving it a bit of right foot to skim over the surface.
AnswerID: 138325
Reply By: gramps - Monday, Nov 07, 2005 at 21:32
Wayne and GaryinOz,
I think I am totally confused with your answers re wide tyres vs skinny tyres in sand. I am not that hard to confuse though :)))) Your answers seem to be diametrically opposed.
AnswerID: 138332
Follow Up By: Wayne (NSW) - Monday, Nov 07, 2005 at 21:58
gramps,
When a vehicle is driving on sand there is a wedge of sand in front of the 4 tyres. Think of this wedge as a wheel chock that they used on aeroplanes to stop them from moving. As the vehicle is moving on sand it build up this wedge and is trying to drive over it all the time.
The heavier the vehicle the deeper the wheel will sink into the sand and the bigger the wedge.If we could reduce the weight of the vehicle the smaller the wedge the easier it would be to drive on the sand. A Suzuki will run around on sand better than a Patrol or Cruiser. We cant change the weight of the vehicle but we can stop the tyres from sinking as far by making the footprint longer. This will spread the weight over a large area and there fore reduce the size of wedge that builds up in front of the tyre.
When we do our driver training course we get the customers to try and drive on the sand with tyre at hi way pressure. They then get out of the vehicle after they have not gone very far and have a look at the front of the tyre. A large wedge has formed, we then get them to let the tyres down and drive. After they stop there is only a small wedge in front of the tyres. We have found this is a easy way to explain why the tyres have to deflated before driving on sand.
Wayne
FollowupID: 391968
Follow Up By: GaryInOz (Vic) - Monday, Nov 07, 2005 at 22:54
Not really related to absolute weight, but to psi exerted on the sand.
Gold Coast tourism operators have some ex-army LARK's as beach tourers. These things would have to weigh in at 10 tonne or so, but are able to get up and down the beach to the water because the only have about 5 psi or so in their tyres (you can push the sidewalls in with your thumb).
I accept that there is a wedge of sand created, but it is as a result of the vehicle weight/surface area of deflated tyre contact patch (ie PSI ground force) rather than the absolute weight of the vehicle. Your engine may/may not work harder depending on how low you can set your tyre pressures safely.
This floatation on the sand is similar in principle to what the Icelandic 4WDers with the crazy large tyres use to drive ON the soft snow (note: the only thing under them is several metres of snow on top of an icecap), also why it is easier to use snow shoes than black leather stillettos
FollowupID: 391984
Reply By: Member - Phil G (SA) - Monday, Nov 07, 2005 at 21:34
A LONG footprint is what counts on sand. Thats achieved either by letting air out, or fitting taller tyres. Width doesn't matter.
And as an aside, ever wondered why the old VWs and Kombis were pretty good on sand???
Mud: it all depends on where you are - if you want the tyre to dig in (often the case in the high country), then skinny will do that better. If you want the tyre to sit on top, (say in the desert) then lower pressures help that.
AnswerID: 138333
Follow Up By: gramps - Monday, Nov 07, 2005 at 21:42
Thanks Phil. I was of the opinion that the length of the footprint was always far more important than the width in sand.
Have'nt had any real mud experience so can't venture an opinion.
FollowupID: 391960
Follow Up By: OLDMAGPIE - Monday, Nov 07, 2005 at 22:36
ive got a large spare tyre & two long footprints & every time i go in the mud i sink up to my neck especially after my brother gives me a big wedgie
FollowupID: 391978
Follow Up By: gramps - Wednesday, Nov 09, 2005 at 00:48
LOL I'm still chuckling over that one Oldmagpie :)
FollowupID: 392250
Reply By: gramps - Monday, Nov 07, 2005 at 22:18
LOL .. I did warn you that I was easily confused :)
1. Luggy, my apologies for taking over your thread.
2. Wayne and Phil G, thanks for explaining it to me so that I finally understand :)
3. GaryinOz, sorry I thought you inferred that wide tyres were definitely better in sand.
Geez I hate being the designated driver when all around me are enjoying themselves. Must have been all those lemon squashes I drank today. Bad for the grey cells :)
AnswerID: 138339
Reply By: Rosco - Qld - Monday, Nov 07, 2005 at 22:50
Phil's on the money here.
When you let air out of a tyre you significantly increase the length of the footprint and only marginally increase the width.
Hence a tall skinny tyre at low pressure is better than a short wide tyre at similar pressure.
The stiffness of the sidewalls prevents sideways bulge.
Similarly skinny tyres in mud will cut through the slush to the firm base ... if there is one.
Unfortunatley bit fats are usually accompanied by something physically similar ... both not necessarily to any real benefit, other than the pose perception.
AnswerID: 138351
Reply By: flashnick - Tuesday, Nov 08, 2005 at 01:23
BEEEEEP
Too many factors to symplify this topic. ( You got to be patient with me here for a bit.)
Grip and surface area are what works. Weight to surface area is the formula that will determine optimum traction. Even on bitumen, too wide a tyre can have less traction for a light vehicle than a thinner tyre - causing spin outs and accidents in the wet. Well documented but not the question asked by Luggy.
But lets sink the tyre in a few inches of mud and sand and see what changes in the equation.
A thin tyre in Mud works well when there is a solid base and you have momentum. and need to keep direction.
Otherwise why do these companies like BFG Mickey Thompson etc sell big fat aggressive Mud tyres and not tall thin ones?? (Im sure it can't all be compensation!!)
So yes I can see why You dont see how thin tyres in mud work. generally they dont.
BUT............Gotta consider. (This will bore some of you so skip over this)
1 The Driver - do you know what your tyres are actually doing - are they gripping or spinning? are they digging??
2 Suspension/Articulation Rigid vehicles will get stuck much sooner than a well articulated vehicle.
3 Drive train diffs LSD lockers etc (Open diffs equate to 2 driving wheels in sand and mud. A Good Rear LSD makes that 3 wheels, a Locker in the front finally makes true 4 wheel drive. So this comes into play before they tyres even get a look in.
4 Tyres - Height , width Aggressivness its not what you've got but how you use it.(any girl will tell you that)
5 Terrain (Sand Mud Soft /Hard Base - No base Dry/Wet Up hill down hill Slippery, better watch myself here - but lubrication makes a lot of difference too)
6 Intention, (Where is this going --Yikes) What you intend to do and expect the best result from your choice of .............tyre.(Long drives on soft sand, (Moonlight roses champaign - oops back to the topic - dont want to be modded) stops starts and turning, recovery, using heaps of power in short distances etc etc (driving off the barge onto soft rising sand on Fraser is another challenge that stumps many high pressured tyres fat and thin on great vehicles)) Intended speed and direction will determine what works best, for some intentions tall and skinny is great, for others tall and fat will work better.
A rigid vehicle may very well spin and dig itself in, a well articulated vehicle will put a wheel down a hollow and keep traction.
In a stock standard 4WD the final word on this will be had by the best driver in the vehicle with the best rear LSD (or even any LSD) with the best surface to weight ratio running the lowest air pressures and having the longest legs (best articulation/suspension.). Elimimnate the best driver and it would then be a toss up between the least aggressive tread and the most aggressive tread. Take out the good LSD The most aggressive tread will win only when excessive wheel spin is eliminated. Otherwise use a less aggressive tread and then rev the brains out of the vehicle - However - same result -- bogged.... but will take 20 seconds longer maybe enough time to think.-
Still comes back to the driver.
Add a diff lock - all the other factors change - so lets just look at the bog ('scuse the pun) standard 4bys on the trail.
So if you have a 4by without a LSD or front lockers go for a non aggressive tall tyre, wide is good, skinny ok too - just dont dig them in. Tall tyres give you that extra clearance till the diff drags. You also get that long foot print - a bit like 4 mini caterpillar tracks. As for the wedge in front of the tyre - great theory but I personally dont find it to be the real determining factor. It may come into play more at low speeds and in determining fuel consumption over long distances.
Too many other things to consider. (The driver with a sense of what the wheel's are doing is going to win here.)
Sorry guys but I have been driving in sand and mud all my life and only on some occasions is a skinny tyre an advantage in really SOFT sand and thats when its low in pressure, the sands not too soft and loose and when you are already moving and want to keep momentum in a fairly straight path. Then you go for the skinny tyre (That is a big advantage of thin tyres when doing long drives in the soft stuff keeping straight - as you loose a lot of momentum when swanning back and forth in somebody else'es meanderings - really best to pick your own path - and if picking your own path - a wide tyre will keep you on top of the sand if its low in pressure - so back to wide tyres in your own track -well you did ask!).
For most stop and start beach work fats will be easier.(as long as you dont dig them in and pressure is low.)
For starting off manouvering and recovery and really low speed stuff - that old surface area will win out every time.
In mud a skinny aggressive tyre finds the depth to a point - but once you are on your diffs - thats it. Break out the winch. Or Get some wide muddies. (10s of thousands of competition junkies cant be wrong) And dont dig them in (too much). On clays and firmer mud, manouvering and stop and go driving aggressive tread and even snow chains will win the day.
The best tip I can give while negotiating that steep muddy hill or uphill sand track - LOW TYRE PRESSURE on any tyre (but preferably a muddie if all the tracks Ive seen recently around the hills after the rain are an indication - lots of road tyres sliding back down the hills and into the gullies)) and know which gear will get you all the way up (even if it seems tooo low), gain momentum and start hard but lift your foot off as you progress so as to maintain maximum traction, (this is where real drivers are defined), dont damage the track, but dont be afraid to give it a nudge if you are slowing. Most importantly - if you stop - dont bother revving the engine - if possible just go back and try again -with more speed - lower pressures and more knowledge, -- or else - break out the winch or snatch strap.
hope this helps
Always driving the last vehicle moving, (Unless we're parked on a headland in the romantic moonlight)
Nick
AnswerID: 138383
Reply By: Rigor - Tuesday, Nov 08, 2005 at 09:11
Another perspective on the above , Basically I think everyone is pretty well spot on
but I will add another dimension to the discussion re sand driving.
better weight distribution (low pressure)
low ramp angle (big diameter tyres)
are the fundamentals on sand IMO.
but add this to the discussion , when you lower the pressure ,the centre of the tread area on the tyre compresses more that the outer tread area , this actually forces the sand to the centre of the tread area from both sides ,this compressed sand creates a "rail" of hard sand directly under the tyre area.
The reverse happens with over inflated tyres with the tread pushing the sand out from the centre (and in front hence the ramp) and therefore digging in instead of riding on the compressed sand
the best I have seen on sand is an old Hilux with 750X16 (razor blades ) let down to 10 PSI , The tyres would fold in on themselves and ride high . Don,t go round corners though.
Dave L
AnswerID: 138407
