Toyota Bullbars
Submitted: Tuesday, Nov 08, 2005 at 00:48
ev700
I can get a steel Toyota Bullbar fitted a lot cheaper than the ARB equivalent. It is for the latest 100Series GXL TD.
I am wondering what practical difference is there to justify the extra spend?
Is the build/ looks better?
Thanks in advance
EV700
Reply By: Truckster (Vic) - Tuesday, Nov 08, 2005 at 02:13
do they both or either accept
winches?
138387
Follow Up By: ev700 - Tuesday, Nov 08, 2005 at 09:53
Truckster
Yes, I am awake to that problem.
EV700
392018
Reply By: JohnN - Tuesday, Nov 08, 2005 at 08:57
ev700
I did this same thing a couple of weeks ago. I had a toyota "cruiser alloy bar" (now for sale) and bought the steel winch compatible bar from toyota. $799 without fitting kit.
I was told it was made for Toyota at the arb factory anyway, but cant confirm that and dont care. It is strong and
well made and will take a winch if I want in the future.
JohnN
04 100 TD
138402
Follow Up By: ev700 - Tuesday, Nov 08, 2005 at 10:14
JohnN
ARB say they make the steel Toyota bars. Toyota provides specifications and templates.
The ARB steel bar is $1500 fitted or $1895 fitted, including $200 for colour coded. I am strating to think that ARB must bump up prices to cover all of their advertising.
Thanks for mentioning the price. First dealer quote was $1299 fitted for the IFS steel bar (I have GXL TD, 9/2005 make). The fitting kit was $300.
EV700
392020
Follow Up By: JohnN - Tuesday, Nov 08, 2005 at 10:26
ev700
If you are in
Sydney you may want to get a quote from Pennant Hills Toyota....
I pulled my old one off and put the new one on myself.
JohnN
392022
Follow Up By: ev700 - Tuesday, Nov 08, 2005 at 11:01
JohnN
Brisbane.
But thanks for the thought.
EV700
392024
Follow Up By: warthog - Tuesday, Nov 08, 2005 at 11:15
How much do you expect to get for the alloy bar? I wonder how you will go selling it, as I am considering the same thing with my nissan alloy bar.
392025
Follow Up By: JohnN - Tuesday, Nov 08, 2005 at 11:32
On ebay they seem to go for $100-250.
Mine is 1 year old in VG condition so hopefully around $200-250
we'll see...
JohnN
392029
Follow Up By: warthog - Tuesday, Nov 08, 2005 at 22:18
Thanks John, I thought they may go for more than that. Looks like I'm keeping the alloy for now.
392175
Follow Up By: Member - Bill S (NSW) - Wednesday, Nov 09, 2005 at 19:18
HI JohnN, Mate if you have an alloy bar to suit a 9/05 100td . I am interested as I dont want a winch I have a turfer.
BILLS
392397
Follow Up By: JohnN - Thursday, Nov 10, 2005 at 08:12
Bill
If you like, send me an email off list...
john@childpsychologydotcomdotau
JohnN
392525
Reply By: Member - Duncs - Tuesday, Nov 08, 2005 at 09:20
Guys,
I am not sure about the Toyota bar but on the Nissan the story, as told by the Nissan dealer, was that the steel bar was made by ARB and would accept a winch.
I am still not sure that the bar was made by ARB but it was very limited as to what winch it would accept.
It may be worth checking that the bar on offer will accept the winch you want to use.
Duncs
138408
Follow Up By: ev700 - Tuesday, Nov 08, 2005 at 10:22
Duncs
The Toyota one is made by ARB (said to me by ARB) to Toyota's specs and template.
I guess aftermarket suppliers have more costs adapting a design to suit and then there are advertising costs.
That is a good tip about the winch. I will have to cross that bridge later when I can afford one and when I will probably have to put in heavier springs etc.
Thanks again for your help.
EV700
392021
Follow Up By: madCrow - Wednesday, Nov 09, 2005 at 16:46
Hi guys
the patrol's steel bull bar is most definitely made by "arb" to nissan's specifications.
The supposed only winch that is compatable with the bar is the warn XD 9000 (hope code number's correct), but other
winches will fit perfectly brawn, premier, ox, t-max.
So I can can only assume that the same applies to yota bar.
Just ring around the dealers & you'll be surprised!
madCrow
......(0_0)
\\\\(-><-)///// The large shy bunny with a hair cut, hides in the grass.
The sound of a truck backfiring make him sit up straight!
392371
Reply By: glenno(qld) - Tuesday, Nov 08, 2005 at 12:22
I have a toyota commercial hi mount winch bar on my truck . Some differences i can see are the eyes under the bar are not reinforced like the arb bar . I think arb bars have hi lift jack points incorperated .
138435
Reply By: Outnabout David (SA) - Tuesday, Nov 08, 2005 at 16:26
I assume the Toyota ones are still made by ARB. If you get them side by side you will see the difference. The Arb Tends to be a Deluxe bar with neater welds etc and some have rubber overriders and usually the bar work on the wings goes down through the bumper section and is a lot stronger. The Toyota one tends to be what6 I would call a commercial fleet grade bar.
138480
Follow Up By: ev700 - Tuesday, Nov 08, 2005 at 21:57
Outnabout David
Hi.
I haven't had the opportunity to comparevthem side by side and welding is not my game but I am inclined to agree that the ARB bar is stronger in design.
What I am thinking is that there is probably enough strength in the Toyota bar for the purpose and any additional strength would buckle the chassis even more in a hit big enough to show the difference between the bars.
I am also hoping that the Toyota bar is somewhat lighter.
However I have little idea about bars and would appreciate others opinions.
EV700
392169
