GPS Location in Nissan Patrol
Submitted: Saturday, Nov 12, 2005 at 14:45
PandJ
Hi Folks,
I have now got a garmin MKT45 mounting bracket for the garmin GPS 12 and want to know from people with the same where and how they have mounted then in their Nissan Patrols.
I do not realy want to drill holes in the dash etc. Your comments would be much appreciated.
Thanks P&J
Reply By: Mark (Geelong) - Saturday, Nov 12, 2005 at 17:36
I have Garmin GPS 72 and got marine mount from Whitworths and used double sided tape and mounted it on RHS top of dash near pillar
No holes were drilled in dash
Works fine and good vision for the driver
I have a GU
Good luck
139104
Reply By: Peter - Saturday, Nov 12, 2005 at 21:38
Have a Garmin E Map mounted in the top centre of the dash of a 2003 GU. Mounted with double sided tape, no holes. Cut a hole through the dash mat to fit. Have had the car over some pretty corrugated roads and even though the GPS vibrates a bit it has never come off. Just bought cheap double sided tape squares from the Warehouse, seems to be better than some of the other cheap stores. Have a couple of stuck on clips to feed the cables through attached to the side of the dash also.
Easy done.
139128
Reply By: Member - Captain (WA) - Saturday, Nov 12, 2005 at 21:54
Hi PandJ,
I have a Garmin V and have it mounted on the steering column with velcro. It works very
well and have not had an issue on rough tracks with the mounting.
!MPG:6!
Captain
139131
Reply By: Kumunara (SA) - Sunday, Nov 13, 2005 at 00:18
I have a Garmin GPS - Mounted to the top of the dash with selastic. When I sell the GU Patrol I will just have to rub the selastic off and you won't be able to tell it was there.
139139
Reply By: Bonz (Vic) - Sunday, Nov 13, 2005 at 10:27
I mounted
mine on the RHS of the driver with double side tape to the windscreen, no mess/hole etc on the dash and its in the line of sight perfectly.
139157
Reply By: PandJ - Sunday, Nov 13, 2005 at 19:55
Thanks to all above, great of you all to reply. I will have to give it some thought as to how I mount it.
Thank you all. P&J
139202
