Sunday, Nov 13, 2005 at 12:00
I have a GU which is similar size to your 100 series.
I use to be an old school spray person. I considered a long time about going electronic and spoke to alot of people. months of research. Consulted a few of my collegues who are also chemical wizzes. I now have ERPS on my GU and will definitely do it again. You can ask people all the opinions you want but if they're not fitted properly and system is not sufficient, it won't work.
If you ring ERPS at
Gold Coast, they'll tell you their 6 pack beach pack is the way to go. BS.
My GU has 10 pads. 2 on diagonal corners of my chassis, 2 on front of body L and R, 2 in middle of body, 2 at back of body, one on steel bullbar and one on the large rear door.
Remember current will not pass through rubber or any other insulation. So you need to climb under and have a look or have a good installer who knows what they are looking for and where to put the pads.
My GU lives at Fraser Island when possible and it's in perfect condition. I'll actually be going into the shine and shine up at cruiser park next year. if you want to see pics of my GU, go to 4WD monthly
forum and look up My TI patrol.
my bro has 9 pads on his Yota Kluger which also leaves at fraser and moreton. He's not the most thorough person when comes to washing and his beast is in as new condition.
The thing you need to remember is ERPS does not PREVENT RUST. IT slows it down DRAMATICALLY. It emits -ve current which travels via the vehicles PAINT to cover the metal and prevent the chemical reaction of rusting occuring as fast as it normally does.
1. No paint = no protection. best results on new vehicles. may need touch up on areas.
2. You still need to WASH the vehicle. not a garden sprinkler. i throw the meat huggers on with a pair of goggles and climb under the truck. garden hose is all that's required as a strong shower and start washing from top down. above fuel tank, above rails, gear box transfer case, inside chassis rails. Don't use high pressure, you'll blow sand into
places you'll never get out again. and some people wonder why their truck rusts.
My GU is never under shelter. It's in the sun 24/7. the -ve charge has prevented the oxidization of the paint as
well. See my pics for proof.
The guy that looks after the
Eurong beach houses on Fraser has a defender with the aluminium body. so call no rust. because he never washes his vehicle, it just corrodes away. Now with the system and washing it once a fortnight, it has stopped or slowed down heaps.
If you're in
brisbane, let me know.. i'll point you to someone that knows what they're doing. i can even show you my truck if you want to see it.
i didn't go for counteract or coupler tec (same company- different smell) because they only had 2 pads. one in front and 1 at rear. Someone told me they now have 4 APPARENTLY. still not enough. i know each PAD should emit minimum of 440 millivolts. maybe on a Jimny..
Goodluck. i'll definitely do it again.
139169
