New Prado
Submitted: Sunday, Nov 13, 2005 at 12:42
Member - Nobby
Without getting into a slinging match, I am looking for opinions on the new Prado TDI. I am thinking of taking the step and would value honest opions. Thanks
Nobby
Reply By: Kalgoorlie Escapee - Sunday, Nov 13, 2005 at 13:46
This has been covered some while back. The current model Prado uses the old indirect injection diesel (96kw and 343Nm). Overseas models utilise the new DDI 3l (as found in the Hilux 123kw and 343Nm) and is due into Aus in the near future - Toyota will probably not indicate as we are a good dumping ground for the old engine (Now approx 10 years old). Some writers, these may be on the take, do not even use the Prado in current comparisons as do not come near - peformace term- as the lates breed of DDI. The new model would come with 5 speed auto and 6 speed manual as found in V6 version.
Although I found my 3l TD Prado did what I required, I would be holding out so as to avoid a rapid depreciation in value.
139172
Follow Up By: prado_95 - Tuesday, Nov 15, 2005 at 21:21
Its sad that Toyota are a bit behind the game with the current diesel engine in the Prado. However fitting one of the many diesel tuning module on the market and a decent exhaust system can resolve that issue satisfactorily.
393261
Reply By: Member - Stan (VIC) - Sunday, Nov 13, 2005 at 20:11
AFAIK the new prado diesel will have the same engine as a current model
Hilux
139205
Follow Up By: Sky Pilot - Sunday, Nov 13, 2005 at 20:16
Seems strange that Toyota's new technology diesel 3.0L only makes 123kW and 343Nm when the Disco3 makes 140kW and 440Nm from 2.7L. You would think Toyota's technology would at least equal that of Ford who designed and built the Disco diesel.
392928
Follow Up By: Turbo Diesel - Monday, Nov 14, 2005 at 13:11
Be patient, patient patient, Prado will receive an upgrade soon, similar to the 100 series new lights etc, but it will retain the old motor, personally i would buy the Hilux.
393012
Reply By: 120scruiser - Sunday, Nov 13, 2005 at 20:51
Nobby
I will offer some opinions
I have a July 2005 model TD auto Prado. It has just covered 12500km including an 8500km Simpson crossing extended trip. It is a very quiet and comfortable car.
It is underpowered and you notice this especially on the highway. It runs out of puff really quickly. It does have plenty of torque though and you notice this around town. I don't use cruise control unless its fairly flat as when in hilly country, for eg central coast NSW it wants to kick down all the time and it just revs. I just drive it manually and if it wants to drop in speed I just let it do the hills at its own pace.
Fuel economy is a little worse than I had expected. I got around 16 litres per hundred over the 8500 km trip. I expected it to be quite a bit better than that but in due respect it did only have 3500 km on it when I left. I do expect it to get better slowly.
It did the rough stuff with no problems at all and they love a
suspension upgrade.
Try my site by clicking here for a little more info. I have to add some more but you may pick something up.
I hope this helps.
120scruiser
139212
Follow Up By: Member - Stan (VIC) - Sunday, Nov 13, 2005 at 21:45
Looks like you need a Dtronic :)
392941
Follow Up By: Member - Nobby - Monday, Nov 14, 2005 at 09:14
Thanks for that info. That is a great site you have there for straight foward information. I will probably go ahead with the purchase.
392967
Reply By: 4145derek - Sunday, Nov 13, 2005 at 23:07
When you need the dual battey system try ABR
139232
Reply By: ShnogDog - Sunday, Nov 13, 2005 at 23:13
I've been trying to find out for some time about any upgrade to the TD Prado, but havent had much luck. I did see an article about the Tokyo Motor show on cars guide and it listed new toyotas for 2006, but there was no Prado. It now seems that what the dealerships are saying (no new TD Prado in the near future) may be right.
One thing I really like about my Prado is the standard 180ltr
tank and the range it allows. The V6 is fairly good on fuel, but I'd like to see what range a diesel would get with 180ltrs. Also the low torque and engine braking of the diesel would be great offroad. I'm just hoping and waiting for a new oiler with a bit more go... Just not ready to change to a Pathy at this point.
139234
Reply By: Member - Phil G (SA) - Monday, Nov 14, 2005 at 21:00
We went away with 2 Prados and six 6cyl TD LandCruisers on the
Hay River in the Simpson this year.
Best fuel consumption was a Prado with 110 litres.
Worse fuel consumption was also a Prado with 140 litres.
All the other LandCruisers were consistent at about 120-130 litres.
I don't know why but the 1KZ-TE varies a heap with its fuel consumption.
I'd be hanging out for the new motor, which has direct injection and much better consumption.
139391
