Repco (chi) winch
Submitted: Monday, Nov 14, 2005 at 16:21
ThreadID: 28086 Views:3706 Replies:5 FollowUps:9
I installed a Repco (chi) winch on a Patrol Gu 3.0TDi (05) on the weekend. Almost blew the whole weekend. If anybody is interested in some of the pitfalls/problems - I will happy to share them. Put it this way - the language got pretty hot at times!!!
Reply By: Member - Hughesy (SA) - Monday, Nov 14, 2005 at 16:30
Come on Fred you have got our attention.......now take a deep breath and get it all out......
AnswerID: 139347
Reply By: Vince NSW - Monday, Nov 14, 2005 at 16:48
Fred my 9,500 lf went on on my ARB bar last Friday. Not a hitch, 2.5 hrs from start to finish. Mounted the control box on the top of the bull bar by taking the supplied mounting bracket off and drillin through the base plate & bolting direct to the bull bar.
Had to turn the winch 90 drgreed so that mounting bolts matched the bar which means the clutch handel is now in a bugger of a place to get to but for the money it is still worth it.
Vince
AnswerID: 139352
Follow Up By: Member - Crazie (VIC) - Monday, Nov 14, 2005 at 18:14
Hey Vince
That clutch handle can be rotated around to any position.
crazie
FollowupID: 393059
Follow Up By: Vince NSW - Monday, Nov 14, 2005 at 19:57
Hi Crazie, more information please ?
I assume that I need to unbolt the end of the housing!!
Vince
FollowupID: 393080
Reply By: Member - Fred L (NSW) - Monday, Nov 14, 2005 at 16:52
Rule 1 Hughesy - when the temperary winch system setup to lift the winch in place decides to fall down - make sure you get your leg out of the way !!!
Vince, I don't like to make things easy by using an ARB bar. I used the standard alloy bar. I guess if I charge my time out at $100 per hour you are way in front.
AnswerID: 139353
Follow Up By: John L G - Monday, Nov 14, 2005 at 17:11
Fred
The best system for holding mine in place whilst mounting were my two sons who couldn't wait to show how strong they were.
John L G
FollowupID: 393045
Follow Up By: Member - Crazie (VIC) - Monday, Nov 14, 2005 at 18:22
Hi Fred
I take it the alloy bar had the Steel cradle to hold the winch? otherwise wont the winch will pull through the alloy?
crazie
FollowupID: 393063
Follow Up By: Vince NSW - Monday, Nov 14, 2005 at 20:00
Fred I cheated with holding the bar up. Used a fork lift in the Warehouse at work. No use being the boss if you can;t get some use now and again
vince
FollowupID: 393083
Follow Up By: angler - Monday, Nov 14, 2005 at 21:08
I was told you can't use an alloy bar with a winch. I have an 8000 warn sitting in the shed that I would really love to put on the patrol but with an alloy bar I thought it was not on.
Pick me, I want to hear more.
FollowupID: 393096
Follow Up By: Peter - Monday, Nov 14, 2005 at 21:32
Had an 89 Pajero with an alloy bar and had an 8000lb winch fitted. Had the steel cradle fitted (from Opposite Lock - Brisbane), and never had a problem with using the winch. Without the steel cradle believe it would have simply ripped through the alloy bar. Wasn't too expensive from memory
FollowupID: 393099
Reply By: Member - Fred L (NSW) - Tuesday, Nov 15, 2005 at 09:10
I mounted the 9500 winch on a steel plate (10mm thick) which is mounted on the chassis rails. The only pressure on the bar will be through the rollers. The winch book says that a 6mm plate would do. The plate is sercured with 3 bolts each side to the rails. I had to jiggy a few things to make it all fit but no real dramas. The problem was the control box which only fitted by attaching it to the plate. I also had to rotate the clutch 90 degrees so now it is very easy to get to through one of the front vents. Also had to raise the number plate a touch. Did this by screwing it in from the bottom not the top using the same holes. As an absolutely non-mechanic I reckon it is OK.
AnswerID: 139449
Follow Up By: Vince NSW - Tuesday, Nov 15, 2005 at 17:15
Fred,
So what do I have to do to rotate the clutch. Don"t tell me that I have to take the bar back off. This is why it only took me 2.5 hours, I missed a step.
Vince
FollowupID: 393228
Follow Up By: Member - Crazie (VIC) - Tuesday, Nov 15, 2005 at 18:50
Vince
Did you get my mem message?
FollowupID: 393244
Reply By: Member - Fred L (NSW) - Wednesday, Nov 16, 2005 at 08:25
That's the bad news Vince. To rotate the clutch you have to first undo the 2 allen bolts holding the thing together then pull the clutch off and there are about 12 smaller allen bolts that have to be taken off. You then just dismantle the thing and turn it whichever way you want and put it all together again. Much easier on a work bench. It had to be done otherwise I would not have been able to engage the clutch because of lack of sapce.
Good luck!
AnswerID: 139613
