snorkle for paj
Submitted: Monday, Nov 14, 2005 at 18:12
shane c
Is there any benifit in installing a airtec snorkle for 3.5ltr pajero
Reply By: Marilyn Monroe - Monday, Nov 14, 2005 at 18:49
Yes, just ask Airtec
139370
Reply By: Member - Stephen M (NSW) - Monday, Nov 14, 2005 at 19:48
Hi there shane c, yes and no,if you only take the kids to and from school and the vehicle never leaves the tar then total waste of money,if you intend to take of road and travel on dusty red soil roads and intend doing some
water crossings then yes, but if only doing a dirt road to take the kids down to the
creek then once again wasting your money.Totally up to you,if you just want it for looks then air tec will definately take your hard earned cash ??? Regards Steve M
139379
Follow Up By: shane c - Tuesday, Nov 15, 2005 at 11:25
Hi steve M
safari do not make a snorkle for the 3.5ltr paj that's why I have no choice as to go with the airtec .Also is it true that the fuel economy will
improve?.We do alot of trips to
barrington tops and are planning a trip to
cameron corner ,innaminka,etc.
393172
Follow Up By: Member - Stephen M (NSW) - Tuesday, Nov 15, 2005 at 17:05
Hi there Shane,I have the safari on my'n and can't say that I get any better fuel economy,always round 10L per 100 klm same before I fitted the
snorkel, maybe on the bigger motors might be more noticeable as the 2.8 is definately not a fire breathing motor by any means. Maybe some others might be able to respond to the question about fuel. By the way I was in no terms knocking the air tec product just incase you thought I was, I am surprised that safari dont produce one. I have seen many pajeros with a
snorkel fitted.Have a great day Take care Regards Steve M
393226
Reply By: Member - John C (QLD) - Tuesday, Nov 15, 2005 at 09:00
Been debating this one too.
We do one big trip a year out west,
well at least every 2nd year.
(2 out of 3?)
Not any
deep creek crossings,
well much deeper than 600/700mm.
Don't even get to the top of the rims very often.
So I have 2 uni foam air filters at about $70.00 ea.
Swap them over every 2nd or 3rd day in very dusty (bulldust) conditions usually when I do my morning under bonnet and tyre check.
Milder conditions they run for a week OK.
Wash them out and reoil when we stop for a day catching up.
May go to a
snorkel if we do the cape again, but then you arn't allowed to cross the
jardine like we did in the old 85 model!
PLanning two big trips in the next two years with lots of bulldust, so debating it at the moment.
139447
Reply By: Member - MrBitchi (QLD) - Tuesday, Nov 15, 2005 at 09:02
Only if you're contemplating doing deep
water crossings. Have had
mine over some VERY dusty tracks and the standard setup works fine. Even for deep
water crossings as long as all the deflector bits are in place that are designed to deflect
water, and you use a blind, then you'll have no problems.
Cheers.....
139448
Reply By: Member - Poe L (NSW) - Tuesday, Nov 15, 2005 at 20:04
If you do install a
snorkel, make sure the joints are sealed, as I gather they often are not; no point finding out after a
water crossing.
139542
