GQ wet weather noise
Submitted: Tuesday, Nov 15, 2005 at 17:52
ThreadID: 28119 Views:1622 Replies:6 FollowUps:1
My 92 Patrol makes a loud thumping noise from the front end somewhere when its under braking or the smallest of bumps, but only if its wet from the rain.Any input would be appreciated
Reply By: tiger60 - Tuesday, Nov 15, 2005 at 19:47
Gday mate, if the thumping noise sounds or feels like its coming from under your feet i would suggest that you may need new body mounts "spacers". A very common GQ problem.
tiger60
AnswerID: 139540
Reply By: Baldrick - Tuesday, Nov 15, 2005 at 21:05
My old 110 Landie did that, was panhard rod bushes.
AnswerID: 139555
Reply By: Member - Duncs - Tuesday, Nov 15, 2005 at 21:19
Wilko,
My 89 GQ did that. I had probs with both body mounts and panhard rod bushes.
If the steering vibrates as well as the thumping noise I would definately start with the panhard rod bushes. I chased that vibration for a couple of years and spent a lot of money not getting it fixed. Eventually a guy in Nyngan found the problem, $50 later and it was fixed.
My GQ had a body lift kit and had a tendency to snap bolts, could have been interesting. They were quite easy to replace as were the bubber bushes in the lift kit. Check the mounts just behind the front bumper and the ones under teh 'B' pillar. They are the ones I had trouble with.
Duncs
AnswerID: 139559
Reply By: Willem - Tuesday, Nov 15, 2005 at 22:11
Have similar problem with 94 GQ. Replaced Radius arm rear bushes but noise still there when in wet conditions. Will have a look at body mounts soon.
AnswerID: 139570
Reply By: Wilko K - Wednesday, Nov 16, 2005 at 20:36
Thanks guys for your input. Ive had the radius arm bushes replaced also, so it must be the body mount bushes, I just hope its not a big job.
AnswerID: 139696
Follow Up By: Truckster (Vic) - Thursday, Nov 17, 2005 at 00:21
Not a big job, but phukin expensive
FollowupID: 393395
Reply By: ladas rule - Friday, Nov 18, 2005 at 19:07
You will be looking at $400 for the 10 mounts and there are 3 different numbers ,
6 of one and 2 of each of the others.
AnswerID: 139982
