Where can you mount recovery hooks on a GQ Patrol?
Submitted: Tuesday, Nov 22, 2005 at 19:43
ThreadID: 28283 Views:3535 Replies:4 FollowUps:7
I've had my GQ for a little over a week now and the time has come to start working on mods underneath. Where do you fit front recovery hooks? There is one that came with the truck; it's welded to a plate that bolts alongside the bull bar mount. I was thinking about grabbing another one for the near side but the bracket is handed so it won't fit neatly.
Where the bull bar does mount, though, near the body mounts, there is a vertical plate on each side with a slot in it. Is it OK to mount a hook there so that both bolts fit through the slot? I realise that it's not the same as having a separate hole for each bolt.
Reply By: Member - Duncs - Tuesday, Nov 22, 2005 at 20:51
What kind of bar do you have?
My GQ had an ARB bar and had two hooks fitted to the bar. They were bolted through the uprights near the centre of the bar, mounted on the inside. They were an ARB item and not handed just put one on the other way up. THey also had a spring to prevent things coming off the hook when un weghted.
One of the biggest advantages of this set up was that I did not have to lie in the mud to attach a strap.
Duncs
AnswerID: 140493
Reply By: Truckster (Vic) - Tuesday, Nov 22, 2005 at 20:55
How many do you need?
on the front, Ive always just used the one on the right side you mentioned.
As Duncs mentioned you can mount 2 hooks on the uprights on the bar, although Im not a fan of them, but as he said, no gettin in the mud.
What are you using for the rear? If you have the hayman reece, you are fine. used mine numerous dozens of times without hassles.
AnswerID: 140494
Follow Up By: NotExcessive - Wednesday, Nov 23, 2005 at 00:42
This has an aluminium cow-catcher type made by East Coast Bullbars. We've done some pretty heavy-duty stuff over the past 3 years with the 60 series and that's not likely to change now with the GQ so yes, I need two hooks in the front to avoid twisting the chassis. I have a standard HR towbar and of course there's always the pintle hook in the rear so I think the back end is covered but I'll probably fit two hooks at the rear anyway.
FollowupID: 394132
Follow Up By: Truckster (Vic) - Wednesday, Nov 23, 2005 at 09:59
If it was me, I'd be lookin for an ARB winch bar and a winch. But snatching is faster sometimes. Also gives more clearance over the cow's.
Ive done plenty of wheelin too, some more fun than others over the years, and never needed more than the 1 mounted under front right side.
FollowupID: 394168
Follow Up By: Bonz (Vic) - Wednesday, Nov 23, 2005 at 10:27
I would be amazed that the chassis would twist on a GQ. I think thats a lot less likely than one of the ARB eyes pulling thru, like I saw on a Disco out near Woods Point.
FollowupID: 394172
Reply By: Kiwi Kia - Wednesday, Nov 23, 2005 at 06:32
Hi 'NotExcessive'
"There is one that came with the truck; it's welded to a plate that bolts alongside the bull bar mount. I was thinking about grabbing another one for the near side but the bracket is handed so it won't fit neatly. "
The above recovery hooks are dangerous! I have seen several that have large cracks running along the weld. This has become apparent when removing them to fit a more substantial recovery point. You need to find someone who can weld a plate on each side of the chassis rail to make it it thicker and then use spreaders inside the rail to stop it collapseing inwards as you tighten up the bolts.
AnswerID: 140531
Follow Up By: NotExcessive - Wednesday, Nov 23, 2005 at 07:46
Yeah I had the feeling that the original didn't exactly look crash hot.
FollowupID: 394144
Follow Up By: Truckster (Vic) - Wednesday, Nov 23, 2005 at 10:32
Ive used mine many dozens of times over the last 5 yrs... Its still going strong. never been a problem
FollowupID: 394177
Reply By: Kiwi Kia - Wednesday, Nov 23, 2005 at 16:11
Just because you have got away with it does not mean that it is safe !! I had one of those hooks in my hand this afternoon and it had a crack about 30 mm long in the weld where it ataches to the mounting plate. Have a GOOD look at yours as soon as you can (clean the dirt off first).
AnswerID: 140635
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 23, 2005 at 17:28
I always snatch using 2 hooks on the front with a bridle (you can use a tree-trunk protector) between them. The hook on the drivers side has never let me down and no sign of any cracks anywhere either....but I'm not disputing this could/does happen. The hook I've mounted on the passenger's side is one of those typical black ones with the sprung retainer and it uses high tensile bolts (this is essential). I drilled an extra hole through the lower section of the bracket that holds the bullbar onto the chassis as well as the oval shaped hole in the lug that hangs down off the chassis which is also used to bolt the bullbar to the chassis.
The idea of using the 2 hooks all the time, not only negates any possibility of twisting the chassis, but also halves the load on the hook/s.
FollowupID: 394270
Follow Up By: Truckster (Vic) - Wednesday, Nov 23, 2005 at 18:15
4wd Victoria Via the Nissan club and others teach people to use that Nissan hook on the front for recoveries.
YMMV
FollowupID: 394280
