Pulling versus lifting capacity for winches
Submitted: Wednesday, Nov 23, 2005 at 14:01
Scubaroo
When a winch is rated at 2400kg pull, 1600kg lift - why is the pull rating higher than the lift? Is pull rating the weight of a static object that can be pulled horizontally across the ground by the winch? If so, how is this meaningful - there's a world of difference between pulling a 2400kg car with the handbrake on or off!
Reply By: glenno(qld) - Wednesday, Nov 23, 2005 at 14:13
Forget all the highfillutin mumbojumbo techie talkin . 1 x 8000lb winch + common sense + use your shovel = Get out of bog free card .
140616
Follow Up By: Scubaroo - Wednesday, Nov 23, 2005 at 15:16
Actually referring to hand
winches - when you're stuck standing next to a cable under tension, it pays to know these things. I was looking at getting a 4000kg winch extension strap until it was pointed out that this could be potentially overloaded with a hand winch and a snatch block. Extension straps seem to have bugger-all safety factor built in - their ratings are the breaking strain, as the 4WD Monthly tests demonstrated.
394234
Follow Up By: glenno(qld) - Wednesday, Nov 23, 2005 at 15:34
Please explain .
394236
Follow Up By: Scubaroo - Wednesday, Nov 23, 2005 at 15:43
Mechanical advantage. Say your hand winch is rated to 2500kg, and you add a snatch block - you can now pull 5000kg, as you have two cables between the anchor and the vehicle, each with a 2500kg max pull. Double the effort, but double the pull. Same principle as being able to lift an engine out of a car with a block and pulley by hand. Stick a 4000kg *breaking strain* winch extension strap in line, and if your vehicle is really hung up or bogged, you could exceed the 4000kg rating of the strap. The strap could let go before the safety pin in the hand winch. I guess any wear and tear on the strap from use could also slowly lower the breaking strain of the strap too, making it more likely with an older strap.
It's unlikely, but the safety factor on paper is so low...
394238
Follow Up By: glenno(qld) - Wednesday, Nov 23, 2005 at 15:52
How exactly is a hand winch rigged up with a snatch block ? Thats what i cannot follow .
394239
Follow Up By: robak (QLD) - Wednesday, Nov 23, 2005 at 18:54
The only time you'd get mechanical advantage is if the hand winch was attached to the vehicle, then the cable pulled through a snatch block and then back to the vehicle. Simply by putting somehing through a snatch block will not give you any advanatge (other then perhaps a change in direction.)
394289
Follow Up By: Scubaroo - Wednesday, Nov 23, 2005 at 20:20
Yes - that was the type of snatch block usage that I was referring to, e.g. hand winch connected to one recovery point (via a short strap, e.g another tree trunk protector), out to the snatch block on the end of a winch extension strap attached to an anchor (e.g. tree), and back to a second recovery point on the vehicle. You've doubled the potential pull that the hand winch can exert on the winch extension strap.
One might ask why use a snatch block if you need the extra length of an extension strap, but you might need the extra pull, and it seems to me that this is really halving the actual load that the wire cable might have otherwise been subjected to, so it would be adding a margin of safety in terms of wire cable breaking?
394309
Reply By: Rosco - Qld - Wednesday, Nov 23, 2005 at 14:24
It's all to do with "factors of safety".
A much higher factor of safety is applied to lifting objects compared to pulling them, due to the consequences of a failure occurring.
That's why all vehicle
winches will state they are not designed to lift personnel.
Ppl lifts have a factor of safety of 8, meaning they can lift 8 times their rated load. ... Not the case with 4WD
winches.
140618
Follow Up By: Scubaroo - Wednesday, Nov 23, 2005 at 15:13
Thanks - that makes perfect sense.
394233
Follow Up By: Snowy 3.0iTD - Wednesday, Nov 23, 2005 at 17:44
Just on factors of safety, as a qaulified and experienced mechanical engineer I feel I need to say something here. Just because your winch may have a design factor of safety of 5 or 6, I would strongly advise against taken this as an invitation to allow your winch to start pulling/lifting loads greater than it is rated too. Factors of safety (FOS) are there to allow for manufacturing defects, design calculation assumptions, deterioration of the winch over its life etc. The original design FOS may be 5, but on your winch it may be less than this when the above-mentioned factors play a part. And short of having it destructively tested in a lab there is no way of knowing exactly what the real FOS is. Having been part of incident investigation where a worker was killed by a winch cable letting go, I can tell you that the results are quite horrific. Stick to the manufacturers guidelines, ensure your equipment is
well maintained and you won't go wrong.
394275
Follow Up By: Ray Bates - Wednesday, Nov 23, 2005 at 19:49
And don't put an extension on the handle. These hand
winches (Tirfor type) Have a specially hard wire rope and snatch blocks should be 33x diameter of the rope
394302
Reply By: Crackles - Wednesday, Nov 23, 2005 at 21:58
There doesn't seem to be any real testing standard that all winch manufactures use so comparing different brands can be difficult. I have seen one test where the claimed maximum rating was how much a winch could pull a rolling load up a 30 degree slope without stalling. Obviously this would be far more than the winch could pull vertically.
I wonder if any experts out there know how the major manufactures currently work out their ratings?????
I suspect that your example of 2.4 tonne pull & 1.6 tonne lift would be a built in safety margin for a suspended load although it may very
well be the maximum lift before the sheer pin lets go.
Cheers Craig.........
140715
Reply By: Bytemrk - Saturday, Dec 03, 2005 at 21:11
All the above answers are very helpful.... but the simple answer to your question is one word.
GRAVITY
lifting you are working against it..... pulling you are not - that is why the different ratings.
142287
Follow Up By: Richard Kovac - Saturday, Dec 03, 2005 at 21:40
Bugger it I was going to say that earlier but could not convice myself I should know better
Richard
395862
Follow Up By: Scubaroo - Sunday, Dec 04, 2005 at 00:33
Hmmm I don't think that's the reason - I reckon the higher safety factor for lifting makes more sense.
You could have a 2400kg mass, bolted to the floor, and a 10,000 kg mass on a trolley - I'll bet the winch will move the 10,000kg mass before it moves the 2400kg mass, regardless of pull rating.
395875
Follow Up By: Bytemrk - Sunday, Dec 04, 2005 at 01:32
The safety factors certainly go to the actual numberthey give
BUT it takes less force to pull 1 tonne horizontally than it takes to lift the same weight (against gravity).
So the amount of force on the components of the winch is greater in a lift than in a pull for exactly the same weight ( or mass)
force = mass x accelleration ( or at least it did when I went to school!) gravity adds to the accelleration as you are working against it. ( so does friction - buts lets not go there - it's too late)
But I have been known to be wrong.... so we can happily agree to disagree...;-)
395876
