4WD Treks Southern NSW
Submitted: Monday, Nov 28, 2005 at 17:19
Ian
Can anybody out there recommend some areas in the South Coast & Illawarra or Southern Tablelands for a camping/4WD trek over 2 weeks departing from
Melbourne. Spent years traversing the magnificent
Vic High Country and now looking for a change. Intend to do it last 2 weeks of Jan 06....
Reply By: bob - Monday, Nov 28, 2005 at 17:47
Ian
Can reccomend
Cooma up to
bendethera (and
cave) and then on to
Braidwood. Check out Araluen, Captains flat and Majors
creek. However having just read the date your going you will need 5 lts of
water per person per day and 10 lts of aeroguard for the flies.
Bob A
141352
Reply By: timglobal - Monday, Nov 28, 2005 at 20:22
Once you've done the Brindabellas as previously advised, you can also swing east towards
Braidwood, the Turpentine Road and the various NPs near the coast. A NP map will show all
routes you need to consider, and Nowra has a great local map in their garages.
After that,
trundle from
Goulburn up to Wombeyan and via Mt Werong, Yerranderie,
Dingo Dell, Kanangra Walls. Have a crack at teh Zigzags, then via BlackFellows Hand Trail west, appearing at Cullen Bullen.
From here you can go for a little bimble via the
Bridle Track to
Hill End. Drop back via Dandenong and you can
trundle back to
Melbourne via
Ballarat, etc. Others can fill that bit in.
Hope this helps your mix'n'match.
Tim
141369
Reply By: ellmcg - Monday, Nov 28, 2005 at 21:40
Tuross Falls and
Bendethera are really nice
camping areas, but I suspect
Bendethera could get a bit busy during holidays, being so close to the coast.
If you want to get (vehicle damagingly) serious I hear that Yahwal is the place to go.
141391
Reply By: Well 55 - Tuesday, Nov 29, 2005 at 07:23
Up the black top to Tumut to
Long Plain, Broken Cart, Brindabella's through the ACT to Bendethra via Captains Flat and
the Big Hole.
Out of Bendethra via Merricmbean Fire Trail, down to the coast. Head south doing a few of the tracks to
Peak Alone Fire Tower. By then you could be almost ready to head home.
141445
Reply By: Ian - Tuesday, Nov 29, 2005 at 08:58
Thanks for all the help... will get the maps out and start planning..
141458
