Defender...What RPM @ 100kph?
Submitted: Tuesday, Nov 29, 2005 at 10:36
ThreadID: 28472 Views:2549 Replies:5 FollowUps:2
Just wondering if anyone could tell me what RPM a Defender TD5 (2005 model) does at 100kph, please?
Reply By: Redback - Tuesday, Nov 29, 2005 at 11:25
around 2000 give or take, my Disco TD5 sits around this.
AnswerID: 141486
Reply By: Alan H - Tuesday, Nov 29, 2005 at 11:40
Hi brd. I've never taken much notice with mine but I suspect as they have lower gearing than a Discovery, probably around 2200rpm.
Why?
AnswerID: 141488
Reply By: Rosco - Qld - Tuesday, Nov 29, 2005 at 12:39
Brd
From recollection, about 2700 on the tacho. I'll check tomorrow on the freeway and confirm. The final drive ratio is lower than the Disco, so higher revs are to be expected.
AnswerID: 141492
Follow Up By: Rosco - Qld - Wednesday, Nov 30, 2005 at 15:47
3600 in 4th ... and it wasn't real happy.
2800 in 5th
4500 governed max ... but I don't think I want to go there.. ;-)
FollowupID: 395392
Reply By: Nebster - Tuesday, Nov 29, 2005 at 12:56
About 4500 rpm if you hold it out in third ;D
AnswerID: 141498
Follow Up By: Rosco - Qld - Tuesday, Nov 29, 2005 at 14:02
OUCH !!!!!!
FollowupID: 395153
Reply By: Member - Cruisin' Dave (WA) - Tuesday, Nov 29, 2005 at 16:57
brd
try this link:
http://www.osella.com.au/gear-ratios.htm
measure your wheel diameter and your can do cals for each gear, provided you know the ratios.
David
AnswerID: 141544
