Tyre Pressure/Temperature Monitors
Submitted: Tuesday, Nov 29, 2005 at 21:06
ThreadID: 28488 Views:3023 Replies:2 FollowUps:0
Hi all
Does anybody have any performance information on the various tyre pressure/temperature monitoring devices currently available. e.g Sensa Tyres etc.
I would like to know whether anybody has used them and if so how they have found their performance?
Thanks for any info provided.
Paul T
Reply By: Martyn (WA) - Tuesday, Nov 29, 2005 at 21:53
Paul T,
I've got a SensaTyre fitted, pretty impressed, gives accurate tyre pressure readings and temps from what can tell. I have one sensor that doesn't seem as responsive as the rest which is the offside rear sensor. Tyre rotation becomes a challenge, each sensor is specific to each tyre position. Took the sensors originally to a tyre house to fit they wanted $25 per tyre plus the cost of a balance. Told me the fitting of the sensors was a pain in the arse and they weren't that interested in doing the job. I went home and did them myself for nothing in the shed with my R & R beadbreakers all finished in an hour. Just got the balance done after that, the tyre have to be rebalanced they shook a lot.
I can see the uses, more so on beach work, good for working out the if tyre pressures are right when doing highway work, temp increase etc. I was amazed how much hotter the rear tyre run when I've got the camper trailer in tow. Something I didn't know or appreciate.
Are they worth the money, if I ever come close to an accident due to tyre failure and being forewarned yes. Foe me the closest I'm come to anything was a tyre I rolled on the beach deflating on the way home, the alarm went off a long time before I would of noticed the problem. This also comes setting the alarms pretty tight to the running pressures.
My opinions & experiences.
Keep the shiny side up
AnswerID: 141594
Reply By: ACDC - Tuesday, Nov 29, 2005 at 22:23
Paul T,
I also have a Sensatyre unit fitted to my hilux for over 1 year now no problems works great,if you rotate tyres just reprogramme ID codes of transmitters into there new positions.
Ran over a piece of scrap metal on freeway and the alarm went off to warn me of the puncture.
As Martyn said it's amazing how your tyre temperatures change under different situations.
AnswerID: 141605
