12 volt timer for fridge
Submitted: Tuesday, Nov 29, 2005 at 22:00
ThreadID: 28494 Views:3725 Replies:4 FollowUps:5
Hi all
Reckon I have read something about this here but I'll be blessed if I can find it.
Have an autofridge and want to set up a timer so that I don't have to remember to turn it on and off twice a day-- well to be honest so that I can't forget to turn it off after the evening run.
Can anyone tell me can I set up a timer for it to turn on for an hour in the morning and again in the evening, using 12 volt power source, and if so, how.
Rusty
Reply By: Member - Willie , Epping .Syd. - Tuesday, Nov 29, 2005 at 22:15
Rusty ,
I have one on my Autofridge that I bought from - The 12 Volt Shop - at Auburn in Sydney .If you cannot find the number , let me know and I will look it up in the phone book for you .
It lets me put it on for an hour ( or whatever ) in the morning and the same in the evening . It can be overridden easilly .
I kept forgetting to turn it off too .
Cheers ,
Willie .
AnswerID: 141602
Reply By: Gerry - Wednesday, Nov 30, 2005 at 09:54
I'm a little confused - doesn't an autofridge have a thermostat which automatically turns it on and off according to cabinet temperature? Doeasn't sound very "auto".
Gerry
AnswerID: 141678
Follow Up By: Member - Willie , Epping .Syd. - Wednesday, Nov 30, 2005 at 11:25
Gerry ,
In theory , you are correct of course . I don't know how to explain it , but an hour twice a day is the way to run them and use little power .
The Eutectic design works in such a different manner to normal fridges .
I will ask Nude Nut about it - he is the fridge expert .
Cheers ,
Willie .
FollowupID: 395345
Follow Up By: Nudenut - Monday, Dec 05, 2005 at 08:59
Willie,
a timer is not the reccomended way to keep perishable product.....even eutectic.....
If you do this one must monitor temps to ensure that they are adequate IE cold enough to ensure integrity of food is kept for time span of camping trip.......dont want to get food poisoning do we!!
so unless you want to monitor the temp leave it on thermostat.....and this will do it automaticaly.......if its only drinks its not a problem
FollowupID: 395955
Reply By: Grant- Wednesday, Nov 30, 2005 at 11:50
Any large electrical retailer will have 12volt dc 24hour time clocks in their catalouges anfd will be able to order them in.
Cheers Grumpy
AnswerID: 141701
Reply By: RustyHelen - Wednesday, Nov 30, 2005 at 15:12
Thanks, looks too easy-- off to Jaycar for some more spending.....
Gerry-- auto as in automobile I guess. There are 2 ways to operate such a beast. 1) Set the thermostat on (say) 1 or 2 and leave it on and plugged in and this will maintain temp but with compressor running as needed to maintain the "ice bank". I understand this would use some 16>20 ah per day (yes I know this will depend on ambient, load, how many times the lid is open and etc but this is a roughy from what I can glean)
2) Set the thermostat to full on, plug in for 24>48 hours before leaving home to freeze down the unit, then turn on for an hour or so morning and evening (away from peak ambient temps) which rebuilds the "ice bank" to maintain the temp in the cabinet but only draws 4>8 ah per day (same dependencies as above).
Using the first method I can run the autofridge for 2.5 days on my reserve battery(car not running at all), using the second method I have gone 5 days so far and temp inside cabinet <5C at all times. Now logic says to me that the total load will determine when/how long the compressor is needed to run and thus power useage, regardless of the method used. But I know the above results apply cause I have tested them under "controlled" conditions.
Rusty
AnswerID: 141748
Follow Up By: Member - AdrianLR (VIC) - Wednesday, Nov 30, 2005 at 16:12
Good explanation Rusty
From my experience your testing is accurate.
I thought about the timer for our 39L but have put off making one because I noticed that on really hot days (on the Murray near Mildura) I had to run the fridge for a couple of hours rahter than just one to knock the temp back down to 1C (which I set myself as an arbitary turn off point). If I set a timer for say 2 hours and it only needs one then things freeze.
None of this is a problem tonight though as I am in Winnipeg where the temp is -14C (luckily not camping!)
Adrian
FollowupID: 395398
Follow Up By: Member - Willie , Epping .Syd. - Wednesday, Nov 30, 2005 at 16:32
Adrian ,
What on earth are you doing in Winnipeg ? Work , play ?
Willie .
FollowupID: 395403
Follow Up By: Member - AdrianLR (VIC) - Thursday, Dec 01, 2005 at 09:51
Willie,
Work - they do some very interesting work in disease control here that we have some interest in. Unfortunately I won't have time to play - the snowmobiles would be fantastic to have a go on!
Adrian
FollowupID: 395527
