Dtronic
Submitted: Thursday, Dec 01, 2005 at 19:11
kiwi2
I'm thinking of fitting a Dtronic to a LandCruiser turbo diesel that will be towing a heavyweight caravan. Any thoughts on how good/bad an idea this is? The upside is increased power and torque from optimised fuel timing/mapping. Is there a downside?
Mike
Reply By: Martyn (WA) - Thursday, Dec 01, 2005 at 21:28
kiwi2
Warranty, if your vehicle is under warranty and anything happens your goosed, unless you remember to take the dtronic off before the RAC truck arrives. Only takes five minutes and saves a lot of hassle. Cost of course, downside with everything, they aren't cheap. I like
mine, works in the Nissan treat, you do notice the difference, not earth bleep tering but you notice.
142027
Reply By: brd - Thursday, Dec 01, 2005 at 21:30
Hi Mike
I ran a Dtronic for190,000km and found no downside what-so-ever. The increased off-idle torque was most improtant to me for towing. I can't comment directly on the Toyota application.
Mine was a 2001 3.0L Nissan Patrol diesel...the model which has had so many bad reports.
I had an excellent run with
mine, and the extra power right across the rev range had no adverse effects. Temperature always remained constant, independent of load. I think they've got it right with the Dtronic. I found fuel consumption remained the same.
Brid
142028
Reply By: Trekkie - Thursday, Dec 01, 2005 at 23:08
Mike
I have said previously that the Dtronic is the single most best item I have put on my truck. I also have a 105 series 4.2 TD. Increased power accross the entire range. I tow a
Kimberley Kamper and most of the time I dont even know its there. Cannot say I have noticed any change in fuel consumption. As already said, warranty could be an issue - there are no other downsides I am aware of
142046
Reply By: Davo - Thursday, Dec 01, 2005 at 23:19
Kiwi2,
without sounding like an old computer geek, do yourself a favour, and do a search in the archives; this has been discussed a lot.
I've got one in my 2001 100-series T/D, and a mate has a 2005 T/D sans-D-Tronic.
He has ridden in
mine and now wants to buy a D-Tronic.
Say no more.
Warranty? It's Your call; we can only give you personal perspective on this addition.
If you want to put one in, and you're worried about your warranty, don't do it.
You cannot have your cake and eat it in my opinion. If you're towing a lot, I think it's worth the risk for the added safety when you're towing something HEAVY.
Ten years agao, you would have given your eye teeth to have a STOCK factory engine to put out what the T/D puts out, so I think it's all got to be taken into each inidviduals' perspective.
That's my soapbox for tonight :)
Davo
142049
Reply By: Member - Craig D (SA) - Friday, Dec 02, 2005 at 07:39
kiwi2 I have one in a 2000 Gu 3L and it's not coming out anytime as the car is
well and truly out of warranty. For what it's worth (pun intended) it's still the best accessory I have ever bought for the beasty.
142074
Reply By: kiwi2 - Friday, Dec 02, 2005 at 10:35
Thanks for the comments. I tried putting Dtronic into the search but it came up blank. Must be doing something wrong - I'll try again.
Does anybody know of any problems/disasters arising from using them?
Mike
142100
Follow Up By: ejukated - Friday, Dec 02, 2005 at 10:47
try switching the "post view" to "both"
395711
Follow Up By: Richard & Leonie - Friday, Dec 02, 2005 at 16:57
I have tried several times to do an archive search on a subject and not got the results I expected, ie I knew there had been posts on the subject but they did not show up. You are not on your own.
395746
Reply By: Davo - Friday, Dec 02, 2005 at 18:55
Kiwi
I did a search and found results.
Doing a search on this site/
forum can be tricky though, so try the following:
1. make sure you firstly select BOTH in the "Switch Post View" option box
2. in the keywords section directly above the switch post view box, select topic and body checkboxes
3. enter DTronic (it is not case-sensitive)
4. do another search if you like with D-Tronic
both searches will achieve results.
I tried to attach a screen dump, but cannot do so.
Once you figure out the quirks with the search engine for the
forum, you will be on your way to information nirvana - a lot of people share their lessons learned on this site; which is why I consistently use it for my own research into what people have bought, what broke, what works and what they would do differently with the benefit of hindsight.
Hope the above instructions are of some help to you
Davo
142167
Reply By: 4X4Treker - Friday, Dec 02, 2005 at 20:01
Kiwi2
Dtronic is the best thing that I put on my Nissn GUIV. The main advantage that I have found is the increase in power while towing, it has main towing my off road caravan much better, able to pull up hills in overdrive without any problem, As for the fuel use its like anything the more you push on the load pedal the more you use, that being said fuel consuption around the city without the caravan on has not changed much if anything it is better than it was before I installed the Dtronic
Treker
142173
Follow Up By: angler - Friday, Dec 02, 2005 at 22:56
Best thing I ever purchased for my 3 litre patrol. Great for towing and the low end is greatly improved.
Mine uses slightly more fuel than standard.
Got
mine on ebay for $700.00 lucky me !!!!
395787
Reply By: prado_95 - Sunday, Dec 04, 2005 at 16:11
There are few diesel tuning modules about to improve the performance of late model diesel engines, including dtronic. The manufacturers COULD be achieving similar results from the factory.
They produce more power, they don't all cost the same, they don't all connect the same, they aren't all avail for same vehciles.
See the response topost 28574 for a generic view.
I have a ENG-TEK brand unit, and I'm very happy with the additional performance, without messing with wastegate boost pressures (overboost will definitely be recorded in the ECU for the dealer to find and question you about).
Suffice to say its the one accessory fitted to the car I get benifet from every time I drive.
142346
Reply By: Member - The Crow (QLD) - Monday, Dec 05, 2005 at 16:10
Have a look at this site I found it the other day while browsing
Http://www.steinbauer.com.au there are others around but this one seems to give better output will look into it for myself.
| 200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The CrowLifetime Member My Profile My Blog Send Message |
142474
Reply By: kiwi2 - Wednesday, Dec 07, 2005 at 19:44
Thanks all - I really appreciate the input. And yes, I got the search functioning. Information overload, LOL, but it all seems to be positive.
Mike
142870
