lucas cav fuel
Submitted: Tuesday, Dec 06, 2005 at 17:06
Member - toohey
g'day all
has anyone fitted a lucas cav filter to a patrol or navara 3.0ltd,that is as
well as the original filter,did i read on this
forum some where that the lift pump on these motors is not strong to support two filters?
cheers toohey.
Reply By: Member - 'Lucy' - Tuesday, Dec 06, 2005 at 21:58
Toohey Mate!
It was only about 4-5 days ago.
get the search tool up and running.
142678
Reply By: Shaker - Wednesday, Dec 07, 2005 at 16:17
I have a Terrano 2 with 2.7 TDI & have no problems at all with the CAV filter/
water trap fitted as
well as standard filter.
142829
Reply By: fourstall2000 - Thursday, Dec 08, 2005 at 11:14
I have a CAV in line with the Nissan standard filter on a 3.0 litre Patrol,no problems at all ,recommended by the service dept of Yarra valley Nissan.
The CAV are a coarser filter than the Nissan type so do not impede flow.
142955
Follow Up By: Member - toohey - Friday, Dec 09, 2005 at 06:08
g'day fourstall
is it before or after original filter
cheers toohey.
396565
Reply By: fourstall2000 - Friday, Dec 09, 2005 at 08:17
Toohey,the CAV goes first as it has the inbuilt
water seperator,the idea is to be able to see the
water as it collects and be able to drain it off before it gets to the original filter.
With the original filter you are not aware of the
water buildup until the inbuilt sensor operates (if it works).
My understanding is that the CAV type has a amaller and coarser element fitted which does not effect the fuel flow to the engine.
143071
Follow Up By: Member - toohey - Friday, Dec 09, 2005 at 16:32
thanks mate
cheers toohey
396624
