Blow ---Load
Submitted: Wednesday, Dec 07, 2005 at 23:23
ThreadID: 28694 Views:2616 Replies:8 FollowUps:1
..................................................Well.
get your mind above the navel please, this is about airbags again...:)
what do you lot do first,,,,,load up and then blow up,,,,,,or blow up and then load up......?
rick.
Reply By: geocacher (djcache) - Wednesday, Dec 07, 2005 at 23:29
Rick,
Pump em up to full for what ever bags you have.
Load up the rig.
Let air out until rear just starts to sag.
They are not designed to lift.
AnswerID: 142913
Follow Up By: rickwagupatrol - Wednesday, Dec 07, 2005 at 23:58
ta mate.
rick.
FollowupID: 396419
Reply By: Member - Bware - Thursday, Dec 08, 2005 at 00:41
often blow my load on the fun bags but I don't see how it matters which order you do it in.
It's always an estimation of 'normal pressures' and added load.
Brian
AnswerID: 142920
Reply By: Member - Bradley- Thursday, Dec 08, 2005 at 01:16
for internal coil bags - inflate first then adjust, for secondary external bags or primary bags then do as you please.
if for some reason the airbags in the dash blow up - very very bad :-))))
AnswerID: 142927
Reply By: Member - Oldplodder (QLD) - Thursday, Dec 08, 2005 at 09:12
I generally know from previous experience roughly what pressure I want in my airbags. Pump them up first.
Fine tune by letting a little air out after rechecking ride height loaded.
Ride height loaded is a little below unloaded.
With upgraded springs in the rear, run about 15 psi in the bags.
AnswerID: 142935
Reply By: Andrew - Thursday, Dec 08, 2005 at 09:58
Instructions say to blow up first and then let excess out to set your levels after the vehicle is loaded. Apparently this makes sure they are seated in place correctly. The other way apparently increses the possibility of the bage chafing as it works itself into posistion.
regards
A
AnswerID: 142943
Reply By: Tanka - Thursday, Dec 08, 2005 at 12:11
Off topic, but it is interesting to note the number of views this subject has received compared to others.
Tanka.
AnswerID: 142963
Reply By: rickwagupatrol - Saturday, Dec 10, 2005 at 22:43
thanks for all the answers guys and gals. had a chance to play on the weekend just gone and managed to finaly get a rear wheel completely of the ground....:),(its amazing how much flex there is in stock patrol suspension).
with 5psi in the bags they moved of the bottom seat and were sitting in the middle of the coil, but as soon as the patrol was level, they were back where they should be. it will be interesting to see what happens when they are blown up and the patrol is loaded.
rick.
AnswerID: 143292
Reply By: Mad Dog (Australia) - Sunday, Dec 11, 2005 at 00:00
Ya got a fair few views so it worked Rick...good one buddy
AnswerID: 143302
