Worklight Wiring.
Submitted: Monday, Dec 12, 2005 at 00:11
ThreadID: 28787 Views:3273 Replies:3 FollowUps:4
I'm wiring up some worklights on the back of the canopy and want to be able to have two switches, in the cab and inside the tray. Easy enough but I want to know if its possible to have the switches so that I can turn it on from one and if need be turn it off with the other. I want it to work like the lights you get in the hallway of some houses where it can be switched on or off at either end.
Matt.
Reply By: Star Bug - Monday, Dec 12, 2005 at 00:42
Yes its easily done with 2 "Single pole Double throw" switches. I'd draw you a diagram but It wouldn't come out on theis message.
Have a look here
http://www.tlc-direct.co.uk/Technical/DataSheets/MK/WiringDiagrams.pdf
AnswerID: 143404
Follow Up By: V8 Troopie - Monday, Dec 12, 2005 at 01:19
One thing to remember when wiring up lights this way is that the switch lever (toggle) position is no indication if the light is on or off. It can be on at either position, depending on the other switches position.
Why is this important? You might not notice the light being on during daytime if you accidentally knock the switch over and possibly give the battery an unwanted workout :-)
Klaus
FollowupID: 396898
Follow Up By: Coyote - Monday, Dec 12, 2005 at 16:44
I'm no electrician either but thought it is a great idea and have wanted to know how to do this for a while as I am about to do the same type of installation. could I ask another question for you Star Bug... in the diagram.. What is the "Three Wire" systems for? I assume that would be for a system that for example had lamps in the swithches?
I guess I'm hoping for advice and osmeone to tell me if my "cunning plan" will work... (I'm plannig on wiring up a reversing/rear work light this way. not an interior light)
I was thinking a switch on the dash with a lamp inside it so it lights up when the work light is on and also a second switch (not necessarily illuminated) in the rear next to the fridge somewhere so you can turn it on from the back of the car to unload or whatever??? Is this possible?/? Cheers for any advice help...
FollowupID: 396980
Follow Up By: V8 Troopie - Tuesday, Dec 13, 2005 at 01:58
Coyote, if you want a dash light as well you just wire it in Parallel with the work light. It then comes on when the work light is on, regardless from which switch its turned on. It does mean running an extra pair of wires to the dash.
The next message shows a very wrong (admitted) drawing so I will try my luck in drawing up this switch wiring thingo
SW1 SW2 Light
+ o-------o o-------------------------o o-----------O---------o -
o--------------------------o
SW 1&2 are single pole double throw switches, imagine the switch contact of SW1 either straight through or diagonally down, SW2 ditto, mirror image.
I hope this makes it a bit clearer to laypersons. If you look at the drawing and operate either switch in your mind you can see that either switch is capable to turn the light on or off.
I omitted the fuse for clarity, it should be ahead of the +
Klaus
FollowupID: 397103
Follow Up By: V8 Troopie - Tuesday, Dec 13, 2005 at 02:01
No, sorry, it did not come out. Insert 13 spaces in front of the second line and the diagram is right. Also, insert spaces to the legends above to shift them right to the appropriate place.
FollowupID: 397104
Reply By: Richard Kovac - Monday, Dec 12, 2005 at 01:27
Hi Matt
You need to wire one switch "NO" on the + side of the light and a "NC" switch on the - side of the light
"+" -------------o NO o--------------light-------------o___NC____o--------- "-"
_______
When you turn the NO switch on the light will work
When you turn the NC switch off the light will go off
NO this will not work
You need a "XOR" logic function
0+0=0
0+1=1
1+0=1
1+1=0
You need two switches with two contacts 1=NC, 1=NO
wire + wire to NO side of both switches from the other side run the wire to the opposite switch NC terminal then from the other side to the light
I can't draw this one
Richard
AnswerID: 143407
Reply By: Member - Trevor R (QLD) - Monday, Dec 12, 2005 at 12:43
Firstly I'll start with I'M NO ELECTRICIAN.
But I would have thought you could have a "Master on/off" switch in the cab and the "Auxillary on/off" switch inside the tray prior to the connection of the lights.
When the Master is on the Auxillary has power to turn lights on/off but when you turn the master off there is no power for the auxillary therefore lights will be off.
If you do it this way you can be certain all lights are off by making sure the master switch is off and no draining off battery unnecessarily will happen.
Hope this is clear enough, Regards Trevor.
AnswerID: 143455
