viscous fan blades
Submitted: Monday, Dec 12, 2005 at 09:50
Helen
I've just bought a ford courier diesel ute, had an nrma check and found that the radiator has been repaired due to fan blade damage. I've learnt that during
water crossings the force of the
water pushes the viscous blades onto the radiator and then the damaged is done. I don't want to tarp the front, fold it wet and store it for every
water crossing. I assume that left on would cause overheating.
Can I fix this problem with an after market cowl?
Merry Christmas
Helen
Reply By: Lone Wolf - Monday, Dec 12, 2005 at 10:56
Aren't ALL fan blades vicious?
Oh... I get it...viScous....
Sorry.....
143432
Reply By: Leroy - Monday, Dec 12, 2005 at 11:32
Your engine would definitely overheat if you left the tarp on. You don't really have a choice except to tarp up and fold and store wet. A cowling wont help the situation but I would of thought there should already be one on the radiator.
Leroy
143440
Reply By: tonysmc - Monday, Dec 12, 2005 at 11:34
I had a Hilux a number of years ago that I took the viscous fan completely off and put in an electric thermo fan. I wired it to a switch in the dash and I could just switch it off and on as I liked. Great if you are doing numerous
water crossings. I also noticed a little bit more power after removing the fan. It was the old 2L model so every little bit helped. I don't think the cowl will help as the problem is the fan acts as a propellor once the
water gets up to it and the blades then bend and pull themselves forward into the radiator
Cheers Tony
143441
Reply By: Footloose - Monday, Dec 12, 2005 at 11:44
If you're somewhere where you need to worry about a crossing, surely you'd have a tarp and rope in the back ? One method is to drill a small hole in the blade and tie the blade up temporarily....but it sounds an "interesting" approach. I wonder if the hole might unbalance the blades ?
143445
Reply By: simple - Monday, Dec 12, 2005 at 14:46
the time taken to stop and tarp up might even allow things to cool down so you don't do more damage by just charging in.
i only use a plastic tarp, just a little one so it doesn't hold
water and could be stuffed between the spare and the door or similar if you're worried about it being wet.
slow down soldier. slow and steady wins the race as they say
143471
Reply By: Member - Davoe (Widgiemooltha) - Monday, Dec 12, 2005 at 20:33
The blue plastic tarps of appropriate size cost about 2-3 bucks and can be stored in waterproof green plastic bags that everyplace i work has 000s If it goes mouldy just buy another
143539
Reply By: techie - Wednesday, Dec 14, 2005 at 00:56
I'd go the electric fans - easier to turn off and don't drain the power from the motor.
Techie
143775
