Image posting
Submitted: Monday, Dec 12, 2005 at 20:41
ThreadID: 28822 Views:3025 Replies:25 FollowUps:41
As mentioned in PostID: 28709, I have had a look at the image posting system on the site and have mode a few changes.
You can now post images from remote sites directly into the forum threads. You use the same line of code as previous.
When you submit the post the system will check the remote image dimensions and place it in the thread using a set of defined sizing rules. If your image is greater than the max allowed single image size a small version of the image will be shown (click on the image and you will be able to open a window showing full size).
Now there are some rules - Please make sure you understand them and abide by them.
1. One image per line - This is forced via the software so please do not post a load of little icon images in a single line as this will force the threads to be very long. Personally I hate those little icons as they are a waste of space however one per post will be tolerated if you must.
2. The images posted will be centered in the thread
3. The purpose of this feature is to allow for usefull and meaningful images to be displayed directly in threads. All images will fall under the same terms of use and standard moderation conditions as every other post.
4. Members Picture gallery still operates in exactly the same fashion as previous and is designed for people who do not have a website to which they can (or want to) store online images.
I can modify the system furthur if required but please do not abuse this facility. If you have any feedback let us know.
Reply By: Truckster (Vic) - Monday, Dec 12, 2005 at 20:45
AnswerID: 143545
Follow Up By: Truckster (Vic) - Monday, Dec 12, 2005 at 20:45
it actually came up with an error after posting the image..
will try adn replicate it
FollowupID: 397025
Follow Up By: Truckster (Vic) - Monday, Dec 12, 2005 at 20:47
FollowupID: 397027
Follow Up By: ExplorOz Team - David - Monday, Dec 12, 2005 at 20:56
Yeah it does that if you do not post any other text - I will look into it however I did not expect that I would need to look atthat as I would have thought most images would have some supporting text. it is a bug however so I will find and fix it along with the centre issue that I cannot resolve. Will get beck to you soon.
FollowupID: 397033
Follow Up By: Truckster (Vic) - Monday, Dec 12, 2005 at 21:02
The suspension works.
FollowupID: 397035
Follow Up By: Truckster (Vic) - Monday, Dec 12, 2005 at 21:04
FollowupID: 397036
Follow Up By: Voxson (Adelaide) - Monday, Dec 12, 2005 at 21:09
!MPG:4!
FollowupID: 397040
Follow Up By: Eric from Cape York Connections - Tuesday, Dec 13, 2005 at 06:39
FollowupID: 397110
Follow Up By: Eric from Cape York Connections - Tuesday, Dec 13, 2005 at 06:41
Truckster How come I am only getting this picture and none of mine
what am I doing wrong.
All the best
Eric
FollowupID: 397111
Follow Up By: gramps - Tuesday, Dec 13, 2005 at 08:28
Eric,
In Photobucket, under the picture you want to display, there are 3 boxes (Url, Tag, Img)
Left Click once on the box marked Img
Go to Edit on your Browser toolbar line and click Copy
Go to your Browser window for Exploroz and click Edit then Paste for your Reply or Follow-up
You should see a line similar to the second line below "To Post Hyperlinks:" but it should have the title of YOUR photo in it.
Good luck
FollowupID: 397120
Follow Up By: gramps - Tuesday, Dec 13, 2005 at 08:32
Bugger! Now I know why documentation writers are so bloody anal!!!
Sorry Eric, Click once on the box marked Tag. It should highlight the contents of that box.
FollowupID: 397121
Follow Up By: ExplorOz Team - David - Tuesday, Dec 13, 2005 at 11:48
Truckster,
The no text bug should now be fixed. You should not see that error again.
FollowupID: 397143
Follow Up By: Truckster (Vic) - Tuesday, Dec 13, 2005 at 11:56
Eric.
What you did is posted the image name and location of Steves image
Think every image has a different name - like house Numbers
every image is in a folder - like a street.
And they are located in suburbs
www.photobucket.com <<-- suburb (the website where its located)
albums/v453/gob/ <<-- Street (gob is steves own folder name when he registered)
dalyatdawn.jpg <<-- Number (photo name)
When you registered on Photobucket, you entered an account name, what is your account name ?? EG: Eric......
And what are a few names of the images you added to photobucket?
I'll then post you the code to show you the difference in yours and Steves.
FollowupID: 397144
Follow Up By: Eric from Cape York Connections - Thursday, Dec 15, 2005 at 06:47
thanks to all when i get a more spare time I will have another go at this picture thing.
When I work out what all these ARLS VFLS NBLS mean.
Many thanks
All the best
Eric
FollowupID: 397418
Reply By: Lone Wolf - Monday, Dec 12, 2005 at 20:57
David, thank you.
As people can already see, this is like the equivalent of when Australia finally got colour TV. Our forum discussions will now be more informative, I am sure.
You have done well.
Wolfie
AnswerID: 143551
Reply By: ExplorOz Team - David - Monday, Dec 12, 2005 at 21:01
Trying the centering function again after re-write:
Testing
AnswerID: 143552
Follow Up By: Truckster (Vic) - Monday, Dec 12, 2005 at 21:05
Microsoft Cursor Engine error '80040e38'
Row cannot be located for updating. Some values may have been changed since it was last read.
/Forum/EMailA.asp, line 85
FollowupID: 397039
Reply By: Matt (W.A.) - Monday, Dec 12, 2005 at 21:04
Did this work???
AnswerID: 143555
Follow Up By: Matt (W.A.) - Monday, Dec 12, 2005 at 21:05
Coooool!
Wel Done David Great Addition.
Matt
FollowupID: 397038
Follow Up By: Matt (W.A.) - Monday, Dec 12, 2005 at 21:14
I also Noticed you snuck this little Gem in too!
Very Cool.
Matt
FollowupID: 397043
Reply By: Willem - Monday, Dec 12, 2005 at 21:23
!MPG:4!
Old Rosie
AnswerID: 143561
Follow Up By: Willem - Monday, Dec 12, 2005 at 21:25
Much to my surprise...it worked
Well done David (and Willem) lol
FollowupID: 397044
Reply By: Lone Wolf - Monday, Dec 12, 2005 at 21:44
Okay, I just gotta do one!!!!
Connie Sue Beadell. I took this during May his year.
Wolfie
AnswerID: 143563
Reply By: Member - Brian (WA) - Monday, Dec 12, 2005 at 22:30
!MPG:14!
AnswerID: 143569
Follow Up By: Member - Brian (WA) - Monday, Dec 12, 2005 at 22:35
hi all. Just tried this and it worked first time for me ( thats a first ).
Had a sunrise also but it got lost
FollowupID: 397071
Follow Up By: V8Diesel - Monday, Dec 12, 2005 at 22:36
Hey Brian, love the Meeka pic. I sat up the very top the tallest hill for miles at sunset earlier this year near the old Gidgee Goldmine overlooking absolutely nothing for as far as the eye could see. Don't get much better than that.
FollowupID: 397072
Follow Up By: Member - Brian (WA) - Monday, Dec 19, 2005 at 00:09
FollowupID: 397988
Reply By: V8Diesel - Monday, Dec 12, 2005 at 22:32
Testing testing 1,2,3......2....2....2...22222
AnswerID: 143570
Reply By: Member - JohnR (Vic)&Moses - Monday, Dec 12, 2005 at 22:41
Looks good David
AnswerID: 143574
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Dec 12, 2005 at 22:43
only my picture didn't show and no error message
FollowupID: 397075
Reply By: gramps - Monday, Dec 12, 2005 at 23:22
I guess all those"EO sticker/wheelcover spotted" posts will now have photographic evidence attached LOL
AnswerID: 143586
Reply By: Pterosaur - Monday, Dec 12, 2005 at 23:34
Let's see if I can get it to work ?
AnswerID: 143588
Follow Up By: Pterosaur - Monday, Dec 12, 2005 at 23:38
Hmmm ! what about this ????
http://i11.photobucket.com/albums/a183/pterosaur/GunshotCreek1.jpg
FollowupID: 397096
Follow Up By: Pterosaur - Monday, Dec 12, 2005 at 23:41
Or this ???
FollowupID: 397097
Follow Up By: Pterosaur - Monday, Dec 12, 2005 at 23:42
AAAAH ! At Last
FollowupID: 397099
Reply By: Leroy - Monday, Dec 12, 2005 at 23:47
AnswerID: 143592
Reply By: gramps - Tuesday, Dec 13, 2005 at 00:03
Testing and all that
AnswerID: 143593
Reply By: Andrew (Whyalla SA) - Tuesday, Dec 13, 2005 at 08:13
This is a HUGE improvement to the Forum David. Well done.
AnswerID: 143617
Follow Up By: Andrew (Whyalla SA) - Tuesday, Dec 13, 2005 at 08:14
And it works!
Great stuff
FollowupID: 397118
Gee ya snuck that one in under the covers
FollowupID: 397145
Reply By: Big Kidz (Andrew & Jen) - Tuesday, Dec 13, 2005 at 11:35
On the beach at Lombardina
AnswerID: 143642
Follow Up By: Big Kidz (Andrew & Jen) - Tuesday, Dec 13, 2005 at 11:38
Try again!
FollowupID: 397140
Follow Up By: Member - John (Vic) - Tuesday, Dec 13, 2005 at 15:21
Thats a nice photo Andrew.
FollowupID: 397176
Reply By: Member - Omaroo (NSW) - Tuesday, Dec 13, 2005 at 12:01
Brilliant David & team!! Thanks! This brings the forum alive.
AnswerID: 143648
Reply By: Member - Stan (VIC) - Tuesday, Dec 13, 2005 at 13:01
Testing
AnswerID: 143654
Reply By: Nudenut - Tuesday, Dec 13, 2005 at 14:29
my dearest swmbo and navigator
AnswerID: 143666
Follow Up By: ExplorOz Team - David - Tuesday, Dec 13, 2005 at 14:42
Do not ruin it for all others on the first day nudie. This is not the type of image that we will accept in posts.
FollowupID: 397162
Follow Up By: Nudenut - Tuesday, Dec 13, 2005 at 14:50
my apologies dave......
FollowupID: 397165
Follow Up By: Nudenut - Tuesday, Dec 13, 2005 at 14:54
was hoping you wouldnt catch up this til another hour or so...just so the other can ogle in envy
FollowupID: 397167
Follow Up By: ExplorOz Team - David - Tuesday, Dec 13, 2005 at 14:57
It can stay in this post as an example of
WHAT NOT TO DO.
FollowupID: 397170
Reply By: ImEasy - Tuesday, Dec 13, 2005 at 14:51
Who is this pic of
AnswerID: 143670
Follow Up By: Nudenut - Tuesday, Dec 13, 2005 at 14:55
hey! its my mum!
FollowupID: 397168
Follow Up By: Nudenut - Tuesday, Dec 13, 2005 at 14:56
Hi ya mum! why did you leave home
FollowupID: 397169
Follow Up By: ImEasy - Tuesday, Dec 13, 2005 at 15:07
My Child, my Sweet Sweet Child,
I did not want to spend the rest of my life behind bars for taking you, my Dear Sweet Child, out of this world.
That day when the Mid Wife passed you up to my arms after 135 hours of Labour, which near killed me, I just broke down and cried, and cried, and cried, still crying till the day I left home.
You were so Ugly, I could not stay, for I could easily of, well it could of been quite messy.
But I still Love you, like only a Mother could, please forgive me.
FollowupID: 397171
Follow Up By: Nudenut - Tuesday, Dec 13, 2005 at 15:15
I'm Ugly....geezes.... The soft ripples on the ponds’ surface has certainly distorted your vision!
FollowupID: 397174
Reply By: cruiser - Tuesday, Dec 13, 2005 at 15:13
AnswerID: 143673
Reply By: Redback - Tuesday, Dec 13, 2005 at 15:15
OK here's my test, and i must say good work David.
Spring Creek Delta bypass road
Baz.
AnswerID: 143674
Follow Up By: Redback - Tuesday, Dec 13, 2005 at 15:16
OK one at a time eh
FollowupID: 397175
Follow Up By: Redback - Tuesday, Dec 13, 2005 at 15:26
FollowupID: 397177
Reply By: bruce.h (WA) - Tuesday, Dec 13, 2005 at 15:22
AnswerID: 143675
Reply By: Redback - Tuesday, Dec 13, 2005 at 15:34
EO gathering July 05 on top of Big Red
AnswerID: 143678
Reply By: Member - Paul J (ACT) - Tuesday, Dec 13, 2005 at 16:36
Shallow Crossing
AnswerID: 143681
Reply By: Matt (W.A.) - Thursday, Dec 29, 2005 at 00:07
another Tester
AnswerID: 145844
Follow Up By: Matt (W.A.) - Thursday, Dec 29, 2005 at 00:08
FollowupID: 399344
Follow Up By: Truckster (Vic) - Thursday, Dec 29, 2005 at 00:09
you need the code img src as it says below the reply box, not the IMG one
FollowupID: 399345
Follow Up By: Matt (W.A.) - Thursday, Dec 29, 2005 at 00:16
Cheers Truckster,
Finally figured it out!!
Matt
FollowupID: 399349
