Fuel leak
Submitted: Friday, Dec 16, 2005 at 21:59
jon p qld
Filled the diesel 80 series main
tank last night, then drove 60km home. Noticed oil on the garage floor this morning and found the main fuel
tank is leaking. The
tank was not over filled, just to the piont where the bowser nozzle clicked off. I guess I'll have to drain the
tank and remove it, but just thought I'd ask if anybody else has had this problem? I'm thinking maybe its the seal around the sender unit, or the filler hose.
any advise appreciated. Regards Jon
Reply By: Wayne (NSW) - Friday, Dec 16, 2005 at 22:16
Jon,
I had a fuel leak in my 80 and it would only leak when the motor was running. Turned out to be the return fuel line. The plastic end of the solenoid had snapped and as the fuel was returned to the
tank it would leak. Stop the motor or switch tanks, no more leak.
Priced a new solenoid and they wanted $300, fixed the problem with a little super glue.
Might pay to check when it leaks and if it is not leaking now then the fuel level is below the hole or it could be the same problem I had.
Wayne
144213
Reply By: Member - Jiarna (NT) - Saturday, Dec 17, 2005 at 02:10
Hi Jon
A while back I had a fuel leak from my main
tank, caused by a small stone become wedged between the
tank and the
tank guard and wearing through the
tank. Had to remove the
tank to find the problem and fix it. I used a piece of 2-pack epoxy resin strip over the leak and it's still holding 2 years and many rough km later.
Good luck with yours
144225
