uhf aerial
Submitted: Monday, Dec 19, 2005 at 15:58
ThreadID: 28991 Views:2826 Replies:6 FollowUps:10
after the recent disappearance of my aerial after the unexpected appearance of a low hanging foxtel cable i'm shopping for a new one.
what advantages/disadantages is there over whip/fibreglass/black rubbery ones.
i understand the dB ratings and how that works. how much difference dous say a 6' make over a 1' aerial.
also i've been told you can buy them cheaper online. anyone know where?
Reply By: Member - Roachie (SA) - Monday, Dec 19, 2005 at 16:06
http://www.olbis.com.au/ap_template/subcat_antennas.asp
AnswerID: 144533
Follow Up By: gramps - Monday, Dec 19, 2005 at 16:11
Ok Roachie, you've got photo posting down pat, wanna up the ante and try for links as well ???
Olbis
FollowupID: 398072
Follow Up By: Member - Roachie (SA) - Tuesday, Dec 20, 2005 at 13:35
Okay.....here is my favourite site:
GOOGLE
FollowupID: 398230
Follow Up By: Member - Roachie (SA) - Tuesday, Dec 20, 2005 at 13:36
HOOOOOO bloody RAY!!!!!!!!!!!!!
It works.......(who says I'm dumb??????hahahahaah)
FollowupID: 398231
Follow Up By: gramps - Tuesday, Dec 20, 2005 at 16:43
Onya Roachie. Now we're all in deep trouble :))))))
FollowupID: 398250
Reply By: Member - Roachie (SA) - Monday, Dec 19, 2005 at 16:16
Not sure how this linking chit works....but seeing as how I managed to get photobucket working (with a fair amount of assistance from Doc Holiday!!!!), I am prepared to keep trying. The bit at the bottom of the screen says: "To Post Hyperlinks:
For links: da da da dee da
For images: da da da dee da
NB: I had to put the "da da da dee da" cos it came up with an error message when I copied and pasted the actual wording at the bottom of this box that I'm currently working on.
Well I just tried that up the top of this response, but it doesn't tell a mug like me where to actually insert the hyperlink that I'm trying to add????
AnswerID: 144536
Follow Up By: Banjo 1 - Monday, Dec 19, 2005 at 16:22
Yep....include this code in your posting....as....
Linked text to do the clicking on !
Text for clicking on can of course be anything you want to say.
Href code in between those quotes is best copied and pasted from a browser's URL (address) line.
Doesn't matter what the web object is - is movie, whole site or page etc.
FollowupID: 398078
Follow Up By: Banjo 1 - Monday, Dec 19, 2005 at 16:27
Duh...Banjo !.....Klutz ........Code line should be hand typed in as (or copied from Dave's eg at the bottom of the post view), and edited....
{a href="http://web_object_to_go to"}Text to be clicked on{/a}
...but actual brackets to be used need to be the less-than/greater-than symbols as Dave has illustrated.
FollowupID: 398080
Follow Up By: gramps - Monday, Dec 19, 2005 at 17:03
Banjo 1,
You're confusing the shyte out of me. I've no doubt you know what you're doing but I'm getting dizzy again LOLOLOLOL
Roachie,
Have you checked out the Hyperlink Procedure in the Member's Filesap area ?
link text
Sand Man has done a good job on documenting it.
FollowupID: 398089
Follow Up By: 120scruiser - Monday, Dec 19, 2005 at 20:38
Roachie just copy and paste the
For Links line at the bottom and delete everything inside the inverted commas. Put in there the web site you wish for people to view which is the www.abcdef.com.au and then type what ever you want it to say in the link text area.
I usually put the web address itself there.
http://www.lakecomm.com.au
The http://www.lakecomm.com.au is inside the inverted commas.
Hope this helps.
120scruiser
FollowupID: 398133
Follow Up By: Banjo 1 - Tuesday, Dec 20, 2005 at 08:43
You're right Roachie - Sandy has done it again............I would never have seen that sheet - I've got domestic (and forum) blindness. There is a lot more than could be coded into posts but Dave has wisely blocked them out - it would be mayhem !
Bye the way - if you have a moment - others here may be interested on this point - re your Yam 1000KVA - can I take it that the 12V outlet and the 240V outlet can be employed simultaneously, to the full output level of each (or does one have to compromise on the outputs at such times) ?
FollowupID: 398190
Follow Up By: Member - Roachie (SA) - Tuesday, Dec 20, 2005 at 13:53
Banjo,
Thanks I think I've got the links things worked out now....(phew!!!).
As regards the gennie I'm sorry I can't advise you as I have never even taken the 12v lead out of it's plastic bag!! I only ever charge batteries using 240v chargers.
Sorry I can't help.
Roachie
FollowupID: 398233
Reply By: Member - Davoe (Widgiemooltha) - Monday, Dec 19, 2005 at 16:22
I have a short wire ariel with it curled into a spring 1/2 way along mounted on a spring base ground independant tube. it has proved up to heavy bushwork
AnswerID: 144538
Reply By: Banjo 1 - Monday, Dec 19, 2005 at 16:31
Prestige Communications in WAseem very good on pricing - free delivery too - comprehensive range of goodies.... some forumites have used them - happily.
AnswerID: 144540
Reply By: Member - Phil G (SA) - Monday, Dec 19, 2005 at 16:49
I have a setup which Electric Bug push hard.
They tell you to go roof mounted because all roof mounted aerials work better than bullbar mounted (higher, line of sight etc).
They sell you a ground independant base and swing down bracket (if you have gutters). Then the aerial you put on top is up to you. For 99% of the time I simply use a 6 inch long rubber stubbie aerial. Its unbreakable and costs about $15. It also works very well - usually get 20km line of sight, and it actually works better in hilly terrain than the tall aerials. I also have a 60cm long whip if I want that extra range out in the flat country. Its a common setup in Adelaide.
AnswerID: 144544
Reply By: Brian Bentley - Tuesday, Dec 20, 2005 at 07:22
I have a black rubber aerial that is about 300mm long mounted on the bullbar of my landcruiser ute, it works really well with coverage and durability because it isnt in the way.
I didnt want a 6ft tall aeriel mounted all over my ute because i dont want to look like a tosser and still have the same signal as my small aerial.
AnswerID: 144632
