tuneit deisel performance
Submitted: Monday, Dec 19, 2005 at 19:01
ThreadID: 28999 Views:4328 Replies:2 FollowUps:1
Has anyone experienced the use of this equipment from awd technologies especially with an after market turbo on a deisel landcruiser
Reply By: prado_95 - Wednesday, Dec 28, 2005 at 14:49
awd technologies are no longer agents for tunit.
There are several other like products, BUT they only work on electronically controlled diesel engines (1HD-FTE in the case of the Landcruiser TD), not the 1HZ engine.
See Hallif you have a 1HZ & want to install a turbo. If you have a 1HD-FTE engien check out the -TEKor other like products.
First up get yourself a 3" aust system, you will be needing that if you fit a turbo.
Daveo
AnswerID: 145791
Reply By: NedKelly - Monday, Jan 16, 2006 at 18:15
AWDTech are no longer dealing with Tunit but have the DPChip instead. Its available at ARB City Southern. Theres a report on a vehicles fitted with one on another forum the dyno shows that it got 35% more power and 53% more torque but had an intercooler fitted as well. They go hand in hand. You need some sort of chip - dpchip, unichip, other to bump up the fuel to take the full advantage of the intercooler but seems to give excellent results when set up right.
AnswerID: 148970
Follow Up By: Outbacktourer - Monday, Jan 16, 2006 at 22:17
Read somewhere the Tunit and DPChip are one and the same, they changed the name because some O/S product was known by the same name.
FollowupID: 402207
