How toxic is it? ..............
Submitted: Wednesday, Dec 21, 2005 at 20:20
ThreadID: 29058 Views:2650 Replies:10 FollowUps:16
I am referring to that blue and white putty which has a 101 uses when the two colours are mixed together. Once I puttied up a leaking fuel tank with it and it stuck there for ever.
Used a small bit today to fix a denture as the plurry thing keeps on breaking(bad design).
A chemists out there with knowledge?
Reply By: Wayne (NSW) - Wednesday, Dec 21, 2005 at 20:23
Willem,
Reply to this post in 24 hours and I will tell you if it is OK to use on dentures.
Wayne
AnswerID: 144921
Follow Up By: Willem - Thursday, Dec 22, 2005 at 07:54
I am still here, Wayne lol
FollowupID: 398512
Follow Up By: Wayne (NSW) - Thursday, Dec 22, 2005 at 14:34
Willem,
Not the full 24 hours yet, but if the dentures have not stuck to your mouth or have broken again then the glue is alright.
Wayne
FollowupID: 398587
Follow Up By: Willem - Thursday, Dec 22, 2005 at 14:43
Wayne
Hahahahahaha
The experiment did not work as the putty did not stick to the plastic.
It also tasted funny so I would advise anyone to err on the side of caution before putting in mouth lol
Will give superglue another go.
FollowupID: 398590
Reply By: Brew69(SA) - Wednesday, Dec 21, 2005 at 20:23
I hope I am in your will Willem.
AnswerID: 144922
Follow Up By: Nudenut - Thursday, Dec 22, 2005 at 07:42
he's a pensioner!
FollowupID: 398509
Follow Up By: Willem - Thursday, Dec 22, 2005 at 07:55
Yes, Nudie is right. Not going to be much left....mebbe a pair of old socks....( and a very used Nissan) lol
FollowupID: 398514
Follow Up By: Nudenut - Thursday, Dec 22, 2005 at 08:15
give him your false teeth!
FollowupID: 398522
Follow Up By: Willem - Thursday, Dec 22, 2005 at 09:04
And maybe he would like your glasses!
FollowupID: 398526
Follow Up By: Nudenut - Thursday, Dec 22, 2005 at 09:13
he'll be waiting a long time for me to cark it!
FollowupID: 398529
Reply By: Member - JD - Wednesday, Dec 21, 2005 at 20:25
Hi Willem,
I cant answer your question,but my Dad always used tarzan's grip.Hope this helps.
JD
AnswerID: 144923
Follow Up By: Willem - Thursday, Dec 22, 2005 at 07:56
Thanks JD
FollowupID: 398515
Reply By: Lone Wolf - Wednesday, Dec 21, 2005 at 20:45
I would hazard a guess, that seeing you have to mix the two parts, which constitutes a chemical reaction, it should set, in a neutral toxic state. Besides, it's not that much, and you are only perhaps tasting it, if at all.
Wolfie
AnswerID: 144926
Follow Up By: Willem - Thursday, Dec 22, 2005 at 07:59
Thanks Wolfie.
A worthwhile answer.
In fact, I cannot taste it at all
FollowupID: 398517
Reply By: samsgoneagain - Wednesday, Dec 21, 2005 at 21:46
if your using it on dentures ..........................maybe its not going to kill you in the next 15 years
AnswerID: 144946
Follow Up By: Willem - Thursday, Dec 22, 2005 at 08:03
Thanks Sam
FollowupID: 398520
Reply By: Member - Davoe (Widgiemooltha) - Thursday, Dec 22, 2005 at 02:28
what sort of dentures? I glued a snapped denture plate (for front tooth) made out of that plastic / bakerlite stuff which is skin coloured with super glue which did a superb job for weeks (damn hard to get a dentist in these parts) it was as good as new and didnt fail
AnswerID: 144979
Follow Up By: Willem - Thursday, Dec 22, 2005 at 08:08
Davoe
Mine's plastic and metal fused. It now has putty fused in as well :o)
I tried super glue when they first broke in the Simpson Desert.(Bought a tube in Birdsville at 4 times the normal price lol). But it didn't work all that well. Have had it repaired by specialits twice since then and have now resorted to bush methods.
Hope you have a good Christmas out there in the West.
FollowupID: 398521
Reply By: Eric from Cape York Connections - Thursday, Dec 22, 2005 at 07:02
I have never meet you but it was nice knowing you.
Your looking a bit pale.
All the best
Eric
AnswerID: 144982
Follow Up By: Willem - Thursday, Dec 22, 2005 at 08:02
Hi Eric
Actually I have a good sun tan ( all that work in the garden pulling weeds ). But if an obituary notice appears on the forum then you will know you were right lol
Have a good Christmas up north
FollowupID: 398519
Reply By: Wombat - Thursday, Dec 22, 2005 at 11:15
Do the tubes have a breakdown of the chemical composition Willem?
if so, this could help those more knowlegable than us to identify any nasties.
AnswerID: 145031
Reply By: mcgra (VIC) - Thursday, Dec 22, 2005 at 17:58
it works on the basis of the part B contianing a chemical like papi 27 which is a isocyanate. as you kneed the part a and b together they will generate heat.
once cured they are classed harmless but will give of an odour for about 24 hours.
the problem is the part B can desensertise you as your body absorbs the chemical but cannot rid itself of it once its been absorbed. so when you later in life hit that critical limit for your body mass you can become very sick.
gra
AnswerID: 145126
Follow Up By: Willem - Friday, Dec 23, 2005 at 15:17
Geez...thanks for that info mate.
I am already later in life...hahahaha
As mentioned above, the putty didn't stick and had been discarded.
FollowupID: 398786
Reply By: Member - Geoff M (Newcastle) - Friday, Dec 23, 2005 at 15:37
Hello Willem,
Only comment I'd make about the 2 or 3 references to Super Glue and its derivatives is they contain Cyano Acrylates. These are derived from Cyanide as are the Isocyanates.
Probably best not to stick Super Glue in your mouth,
Geoff.
Geoff,
AnswerID: 145266
Follow Up By: Willem - Friday, Dec 23, 2005 at 15:41
Thanks Geoff
Wasn't Superglue invented during WW2 to assist doctors stitching up the wounded?
Anyway I now have thought of using my soldering iron(after cleaning it) to fuse the cracks in the plastic together.
Gotta keep the ideas coming lol
FollowupID: 398790
Follow Up By: Member - Geoff M (Newcastle) - Friday, Dec 23, 2005 at 15:55
Willem,
I'll take your word on the WWII reference.
I've never heard or thought to ask the origins of Super Glue before today.
Good old fashioned plastic welding, suck in those fumes!!
You live and learn,
Geoff.
Geoff,
FollowupID: 398791
