Kubota AV650 generator
Submitted: Friday, Dec 23, 2005 at 18:22
Utemad
Hi all,
I am fixing up a Kubota AV650 generator that we have ad in the shed for about 10 years unused. It was bought in about 1990. When I first got it out of the shed I checked the oil and fuel and then pulled the starter and it started first go. Only problem was it poured fuel out of the fuel pipe/carby seals. So now I have replaced those it no longer leaks from there. However it does pour fuel out of the air filter.
I was just wondering if anyone has a workshop manual on one of these or if anyone who knows about this sort of thing could have a guess as to why it would overfuel in such a massive way. There are about 3 screws to adjust on the carby but I don't know what they do. Fuel, air/fuel mixture and ???
This is a pic from the net. Bit of overkill to run the radio though I reckon. I can post some specific pics if anyone can help.
Reply By: Member - Omaroo (NSW) - Friday, Dec 23, 2005 at 18:28
Actually - the generator pictured was not there to power the boombox. The reel on the rod is actually a really small, but powerful winch.
145309
Reply By: Shaker - Friday, Dec 23, 2005 at 18:38
3 screws ...... one may be idle speed, one will be high rev mixture & the other one low rev mixture. Is it diaphragm carby? May have a pinhole in it.
145311
Reply By: Utemad - Friday, Dec 23, 2005 at 19:31
Thanks for the reply guys but I have it sorted. After frigging with it on and off all day I did what any self respecting 26 year old does. I rang my Daddy. He is a mechanical engineer after all. He reckoned that there would be something blocking the pin valve doohicky that is attached to the float in the carby. So I pulled the carby apart and lo and behold there is a peice of black plastic jamming the pin valve open. So once I had removed the plastic junk and put it all back together again it ran like a charm.
As for the screws I know one is the idle control as it idled up when I turned it. As for the others I didn't think it was wise to play with them now it is running sweet.
I checked the power output with my multi meter under no load and it read all over the
shop for AC (I ouldn't get a good connection though) and 11.8v DC. It ran my 240v drill fine so I guess it works but I will have to load it up later to check to see if it idles up like I remember it used to all those years ago on Moreton.
So now I have a cool generator at my disposal. For the grand price of $4.50 for the replacement gaskets :-) Although I didn't need one before and can't see me needing one anytime soon. Oh
well it is nice to have.
145316
Reply By: Member - JohnR (Vic)&Moses - Saturday, Dec 24, 2005 at 08:50
Now it's going you will really be able to alienate fellow campers ;-)
Hope you don't.
145374
Follow Up By: Utemad - Saturday, Dec 24, 2005 at 12:00
I don't like being annoyed by other peoples generators either. Can't see myself taking it
camping. If nothing else it is frigging heavy!
398909
Follow Up By: Shaker - Saturday, Dec 24, 2005 at 23:29
I don't see the difference between running a generator or running a vehicle to heat an in car shower.
Or loud music, or noisy kids, or noisy kids on mini bikes, or loud drunks, so why does everybody comment on generators?
399012
Follow Up By: Utemad - Sunday, Dec 25, 2005 at 00:00
Because generators drone on for hours at a time and are used to run other noisy things like stereos and air conditioners.
I don't have an in-car shower, loud music, any kids, no mini bikes or large bikes and I'm not a loud drunk. I'd hate to
camp next to anyone who did.
However I might be taking it to Fraser as I may have to man a radio point for a boat race. We will need back up power just in case of battery/alternator failure. However that will be up at
Sandy Cape and I would only use it if I had to.
399022
