2005 Pathfinder
Submitted: Sunday, Dec 25, 2005 at 18:03
ThreadID: 29161 Views:2228 Replies:3 FollowUps:5
Son has just bought a new pathfinder STL diesel is it normal to see black smoke out of the pipe in a mondern diesel moter.
Regrads
Reply By: hl - Sunday, Dec 25, 2005 at 18:35
No...
Although you may see a cloud of black smoke if you nearly stall it.
AnswerID: 145553
Reply By: Keith_A (Qld) - Sunday, Dec 25, 2005 at 19:42
Hi Para - Black from the exhaust is generally soot ( carbon particles) - a byproduct of combustion of diesel fuel, as you probably know.
In the ideal engine, the mixture of diesel and oxygen from the air, at the correct pressure/Temp, will result in CO/CO2, and no carbon. But no engine is perfect.
Being new, it may take some time (varies) when the rings and bore 'bed' in.
(For my 4.2 TD Patrol, they say it is up to 70,000 klms before fully beded.)
During this time, the fuel burn may not be completely up to specs, and some oil may bypass the rings and be burnt in the combustion chamber, increasing the carbon in the exhaust. In modern engines, I would think this minimal.
During acceleration, or under load (up hill towing a load), the extra fuel load needed results in greater percentage of carbon = black out the exhaust.
So - If under load, it is unavoidable - simply large amounts of fuel (with insufficent oxygen) being burnt by the engine = carbon.
When not under load, I would not expect to see any black smoke.
Obviously a mechanical fault with the engine may lead to sump oil being burnt = black exhaust.
If the injectors are worn, the fuel may not be atomised properly, resulting in a poor burn = carbon rather than CO or CO2.
.Hope this helps..............regards.
AnswerID: 145554
Follow Up By: hl - Sunday, Dec 25, 2005 at 21:51
Rule of thumb with a diesel:
If it's blue smoke, it's stuffed
If it's black smoke, it's over fueling or the injectors need doing.
None of this would apply to a new engine.
The 3.0TD is electronically controlled, and there should be no black smoke at all, however, as I said in my previous post, if you nearly stall it or labour it, you will see smoke.
(and I'd like to see an engine that will take 70,000k's to "bed in")
FollowupID: 399087
Follow Up By: Truckster (Vic) - Sunday, Dec 25, 2005 at 23:05
yea numerous people are saying that they feel it losen up at about 40-50,000klms and it goes better, and drinks less.
FollowupID: 399092
Follow Up By: Exploder - Monday, Dec 26, 2005 at 00:38
Well they say the Ford Powerstroke Diesel can take up to 10,000 Miles so 16,000k’s to be fully run in. If they are leaving a new diesel to idle extensively or using it as a daily driver without putting some load on the engine in the first 1-2 thousand k’s then I could see it taking a long time to break in, 50,000k’s maybe.
As a contrast to that a lot of Modern petrol engines take as little as 300k to be run in, which is why it’s so important to break the engine in right from the first drive.
FollowupID: 399102
Reply By: kesh - Monday, Dec 26, 2005 at 18:34
The answer here has to be yes and no. Yes if you are fully loading the engine at around max. torque revs., no if you are cruising along in a "normal" manner, normal being around 100kph on a level to slightly undulating road.
But there are plenty of diesels incorrectly set for conditions. An N/A diesel requires 10% less fuel per 1000m. altitude it is at to prevent over fuelling smoke at full loads. This is the reason for the altitude compensator on the newer Toyo 1hz units (not to be confused with a turbo boost compensator, works in reverse)
As to the "loosening up" business, well thats just bollocks! Its loosened up in the first 500km. Reckon a semi truck gets driven gently for 50k. just waiting for it to "loosen up", or an earthmover the same for 500hrs.? There ain't no high spots in engines these days, everything floats on a designed film of oil. Its closely related to treating your new toy gently until it gets its first decent line of body scratches then its "what the hell"!
AnswerID: 145617
Follow Up By: Patrick - Monday, Dec 26, 2005 at 19:27
"Its closely related to treating your new toy gently until it gets its first decent line of body scratches then its "what the hell"!"
I have got to agree with this sentiment, as I see it all the time with my 4WDing mates.
FollowupID: 399150
Follow Up By: Exploder - Tuesday, Dec 27, 2005 at 12:30
Mate, under a microscope everything has high and low point’s no machining is perfect, and like you say 500k’s and it loosened up.
But if you baby your engine from new then you can get extensive run in times and other underling issues from this.
FollowupID: 399207
