Air con drain
Submitted: Saturday, Dec 31, 2005 at 16:12
Member - David (WA)
Compliments of the season to all:
Can someone tell me where the a/c condensation drain pipe is on an '96 80 series cruiser? I can't find it under the vehicle as I am not sure where it comes thru the firewall. I think there maybe a split in the pipe as I am getting moisture under the floor matting after using the a/c.
David
Reply By: fozzy - Saturday, Dec 31, 2005 at 16:21
david
from memory under passenger side dash
thats the rubber tube part anyway.
that was on my 94 80 series
may be different
hope this helps
fozzy
146106
Follow Up By: Member - David (WA) - Saturday, Dec 31, 2005 at 16:33
Thanks Fozzy
I'll have a poke around and see if I can find it.
David
399681
Reply By: Outnabout David (SA) - Saturday, Dec 31, 2005 at 16:21
left hand side in engine compartment. In line with the leading arm.
Water drips down on them near where the arm meets the diff. Probably just blocked which cause
water to back up and enter the passenger compartment. Quick blow with the air hose usually does the trick
146107
Follow Up By: Member - David (WA) - Saturday, Dec 31, 2005 at 16:35
David
Thanks for the info.
I'll have a look and see if I can see it.
David
399682
Reply By: Member - George (WA) - Saturday, Dec 31, 2005 at 17:59
David, also check under the dash where the fan coil is (passenger side) I have had the same problem and it turned out that the hose had come detatched from the fan unit. It is easy to see when you check the back of the unit
146120
Follow Up By: Member - David (WA) - Saturday, Dec 31, 2005 at 18:34
Thanks George
Found the drain hose, all appears to be connected.
I will get the compresser out tomorrow.
David
399703
Reply By: Billowaggi - Saturday, Dec 31, 2005 at 18:22
Hi David, just had a look at
mine, inside engine bay left side it comes out of the firewall right alongside the main body of the starter motor 12mm pipe runs down and finishes just above chassis . as said above blow out with air.
Regards Ken.
PS.
mine is 1HZ motor.
146123
Follow Up By: Member - David (WA) - Saturday, Dec 31, 2005 at 18:35
Thanks Ken
Mine is also 1HZ and I found the hose.
I will blow it out tomorrow.
David
399704
Reply By: Member - George (WA) - Saturday, Dec 31, 2005 at 18:52
David, if you are going to blow it out with compressed air, do it from the fan coil end (disconnect the hose) otherwise you will blowe all the crap inside the fan coil tray
146127
Follow Up By: Member - David (WA) - Saturday, Dec 31, 2005 at 18:57
Thanks, I'll remember that.
399705
