AnswerID: 146397 Submitted: Wednesday, Jan 04, 2006 at 15:16
revhead307
replied:
Agree, either of the two above sound good.
If you have run a negative from the battery as well...its already earthed and not required to do again...
normally you would just run a + power cable..and then form a solid earth under the seat etc to complete the circuit.
so two earths is redundant...
however...a little built in redundancy never hurts
Rev
Reply 2 of 3
FollowupID: 399938 Submitted:
Wednesday, Jan 04, 2006 at 18:08
Member - Trevor M (SA) posted:
Hi Rev,
The instruction / installation booklet plus previous threads on this
forum disagree with you. There are the 2 power terminals (both direct from battery as recommended) plus a separate lug for grounding the unit itself. I assume this is a safety issue in case there is a short?
From memory a previous thread said that this was necessary for pure sine wave
inverters but not modified sine wave ones.
I'll do a
search and see if I can find the thread again.
Trev
 Click Image to Enlarge |
| GU Patrol |
FollowUp 1 of 3
FollowupID: 399940 Submitted:
Wednesday, Jan 04, 2006 at 18:25
revhead307 posted:
Gday Trev,
Ok, must be specific to type of device etc as its not a normal 12V accessory wiring issue.
Always happy to learn something.
Rev
FollowUp 2 of 3
