Standard 100 series castor bushes or plates?
Submitted: Sunday, Jan 08, 2006 at 16:00
ThreadID: 29472 Views:2368 Replies:6 FollowUps:0
HI i have a standard model 100 series that has been lifted a couple of inches a now the castor needs fixing am i better of using castor bushes or plates.
Reply By: 120scruiser - Sunday, Jan 08, 2006 at 17:19
If you have to adjust go for the bushes.
AnswerID: 147212
Reply By: yota - Sunday, Jan 08, 2006 at 22:13
I do have to its out by a couple degrees and its all over the road.
AnswerID: 147280
Reply By: udm - Monday, Jan 09, 2006 at 12:07
Depends on how far up you have gone, mostly 2° / 3° bushes for 2" to 4", 4" and up you would want to use 5.5 ° plates.
AnswerID: 147366
Reply By: Member - DOZER- Monday, Jan 09, 2006 at 19:36
Gday
Bushes are for small lifts, the plates are for 4 inch lifts minimum. Plates are a better option, as the bushes are stiffer than the std rubber in there now, so u loose articulation, and in extreme 4wding, can crack the welds on the front diff...., i have a pair of arms with 3 deg correction bushes in them already....u could try them and see...
AnswerID: 147460
Reply By: yota - Monday, Jan 09, 2006 at 20:26
Thanks for the reply's, its only been lifted a couple of inches its been awile since i had the wheel alignment done but i think it was only out 2 or 3 degrees, i dont do a lot of serious 4 wheel driving in it so i thought bushes might be okay.
AnswerID: 147469
Reply By: Rock Crawler - Sunday, Jan 15, 2006 at 09:38
2 deg or 3deg of castor will not make it all over the road. Your toe in will . go get that sorted first and then see if you want castor bushes
AnswerID: 148696
