4WD custom awnings Sydney
Submitted: Wednesday, Jan 11, 2006 at 11:18
ThreadID: 29560 Views:3364 Replies:4 FollowUps:5
G'day,
I read in a forum item some time ago (I have tried a search to no avail) of a couple of companies in Sydney that are economical & also do a good job for a custom made canvas awings.
I am going to set one up that is attached to the ear of my roof rack and would appreciate some feedback
Reply By: Redback - Wednesday, Jan 11, 2006 at 12:03
Bob the Swagman in Woolongong does a good awning at $280 and 2.5mtrs x 4mtrs we have one on our Disco.
A friends GQ
My Disco
Baz.
AnswerID: 147766
Follow Up By: Vince NSW - Wednesday, Jan 11, 2006 at 15:03
Hi Baz. Just Googled for Bob the Swagman & had a look in the yellow pages site. NO luck.
Do you have a Phone No ?
I assume that the 2.5 mt is along the side of the Disco. If so can you pole,say at 3 mt from the car and have a 1 mt wall comming down, or do you have to have it going all the way out.
Forget the last question. Just looked at you first pic again.
Vince
FollowupID: 401107
Follow Up By: Redback - Wednesday, Jan 11, 2006 at 15:15
I'll give you the number when i get home, and yes you can have a pole 2/3rds of the way down as with the top photo.
Baz.
bmfitz at optusnet dot com dot au
FollowupID: 401111
Follow Up By: Vince NSW - Wednesday, Jan 11, 2006 at 15:19
Thanks Baz
FollowupID: 401113
Follow Up By: Redback - Wednesday, Jan 11, 2006 at 17:44
Here ya go Vince
Bob Burrage
Australia Outback
Bush Gear
(02) 4272 3705
Baz.
FollowupID: 401135
Reply By: Dave(NSW) - Wednesday, Jan 11, 2006 at 12:40
Try OFF ROAD SYSTEMS at Smeiten Grange Narrellan PH 0246476322. He can custom build any thing for 4x4s including awnings. DAVE
GU RULES!!
AnswerID: 147771
Follow Up By: Redback - Wednesday, Jan 11, 2006 at 15:17
We looked at his stuff, pretty good work, but a bit expensive.
FollowupID: 401112
Reply By: Member - Jack - Wednesday, Jan 11, 2006 at 18:18
This link may help.
Not custom made, but could prove handy.
Jack
AnswerID: 147834
Reply By: Richard - Wednesday, Jan 11, 2006 at 18:48
I have attached a three piece double ended tent pole to the roof rack with hose clamps leaving the front clamp a little loose so the front pole can slide. I just attach a standard heavy duty tarp and this works well as a side awning. Have used this configuration for five years on two different vehicles with no problems. Its a cheap alternative.
AnswerID: 147840
