X-Trail over 110 kph ...
Submitted: Tuesday, Jan 17, 2006 at 11:29
ThreadID: 29780 Views:2807 Replies:8 FollowUps:3
I got a 3-year Nissan X-Trail ST, recently I drove on a freeway, when the speed over 110 KPH, the car started trembling a bit, switching between 2WD/4WD/Auto didn't help. When the speed droppted to 100 KPH it was fine again.
The problem is still there, what part should I have it checked?
Reply By: Russel & Mary - Tuesday, Jan 17, 2006 at 11:36
Deeeeeear Johnny,
Could be a wheel balance problem, you can't always feel it thru the steering wheel due to good power steering or it may be a tailshaft balance. Not likely though unless you suspect that in a previous life it had been rough 4x4 driving(over logs or boulders etc). Rus.
AnswerID: 149110
Follow Up By: johnsunny - Monday, Jan 30, 2006 at 08:13
Have wheel balance and alignment done last week, the problem was fixed perfectly. Cost $85 in total.
Cheers.
FollowupID: 405319
Reply By: cuffs - Tuesday, Jan 17, 2006 at 12:02
You will find help here http://www.australianxtrail.com/
AnswerID: 149113
Reply By: Truckster (Vic) - Tuesday, Jan 17, 2006 at 12:45
you can switch between 2 and 4wd at 110kph?
AnswerID: 149119
Follow Up By: johnsunny - Tuesday, Jan 17, 2006 at 13:14
When the car stopped, of course. :)
FollowupID: 402284
Follow Up By: garrycol - Tuesday, Jan 17, 2006 at 13:47
Doesn't an X trail drop out of 4wd when it gets over 30kph or gets hot or something like that
FollowupID: 402289
Reply By: Member - Shawsie (QLD) - Tuesday, Jan 17, 2006 at 13:46
I had this problem in the Fronty at over 100kph, got a wheel balance and it was perfect :o)
AnswerID: 149138
Reply By: Jeepster-WA - Tuesday, Jan 17, 2006 at 13:52
One part many people don't check is Universal Joints, with wear and tear they will exhibit those symptoms at around 105-110k's, another thought if wheel balance doesn't fix the problem.
Jeepster
AnswerID: 149139
Reply By: D-Jack - Tuesday, Jan 17, 2006 at 14:00
The Jackaroo did it until rotated the tyres - edges were scalloped. Then smooth as silk.
AnswerID: 149141
Reply By: Bitsumishin - Mike (WA) - Tuesday, Jan 17, 2006 at 22:05
move to WA. the speed limit on the Freeway here is only 100kmh. Your problem will instantly be solved
AnswerID: 149238
Reply By: slow mower - Tuesday, Jan 17, 2006 at 23:33
mmmmmmmmmmmmmmm!!!! in any State except NT could be that your car was 'telling you something'. Perhaps you need to get the nut behind the wheel checked!! With the high road death toll over the recent Christmas period, road safety needs to start with keeping within the speed limit.
Cheers (t.i.c.)
AnswerID: 149265
